<?php
define( "WP_CACHE", true ); // WP Performance
 * The base configuration for WordPress
 * The wp-config.php creation script uses this file during the
 * installation. You don't have to use the web site, you can
 * copy this file to "wp-config.php" and fill in the values.
 * This file contains the following configurations:
 * * MySQL settings
 * * Secret keys
 * * Database table prefix
 * * ABSPATH
 * @link https://codex.wordpress.org/Editing_wp-config.php
 * @package WordPress
// ** MySQL settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define('DB_NAME','wordpress');
/** MySQL database username */
define('DB_USER','root');  // ---> ou pseudo dans base msql créé avec phpmyadmin spéciale accès base base de données wp
/** MySQL database password */
define('DB_PASSWORD','mot dde passe base de données');
/** MySQL hostname */
define('DB_HOST', 'localhost:/run/mysqld/mysqld10.sock');  //c'est l'accès à la base de données sans port ici (local)
/** Database Charset to use in creating database tables. */
define('DB_CHARSET', 'utf8');
/** The Database Collate type. Don't change this if in doubt. */
define('DB_COLLATE', '');
 * Authentication Unique Keys and Salts.
 * Change these to different unique phrases!
 * You can generate these using the {@link https://api.wordpress.org/secret-key/1.1/salt/ WordPress.org secret-key service}
 * You can change these at any point in time to invalidate all existing cookies. This will force all users to have to log in again.
 * @since 2.6.0
// les ddéfine, je ne les met pas
 * WordPress Database Table prefix.
 * You can have multiple installations in one database if you give each
 * a unique prefix. Only numbers, letters, and underscores please!
$table_prefix  = 'wp_';
 * WordPress Localized Language, defaults to English.
 * For developers: WordPress debugging mode.
 * Change this to true to enable the display of notices during development.
 * It is strongly recommended that plugin and theme developers use WP_DEBUG
 * in their development environments.
 * For information on other constants that can be used for debugging,
 * visit the Codex.
 * @link https://codex.wordpress.org/Debugging_in_WordPress
define('WP_DEBUG', false);
/* That's all, stop editing! Happy blogging. */
$pageURL = 'http';
if ($_SERVER["HTTPS"] == "on") {$pageURL .= "s";}
$pageURL .= "://";
if ($_SERVER["SERVER_PORT"] != "80" and $_SERVER["SERVER_PORT"] != "443") {
    $pageURL .= $_SERVER["SERVER_NAME"].":".$_SERVER["SERVER_PORT"];
} else {
    $pageURL .= $_SERVER["SERVER_NAME"];  // lui va récupérer ton nom de domaine pour voi si ça correspond si pas de fuite
if ($_SERVER["HOST"] != "") {
    define('WP_SITEURL', $pageURL);
} else {
        define('WP_SITEURL', $pageURL.'/');
if (!defined('SYNOWORDPRESS'))
    define('SYNOWORDPRESS', 'Synology Inc.');
/** Absolute path to the WordPress directory. */
if ( !defined('ABSPATH') )
    define('ABSPATH', dirname(__FILE__) . '/');
/** Sets up WordPress vars and included files. */
require_once(ABSPATH . 'wp-settings.php');
require_once(ABSPATH . 'syno-misc.php');
define( 'AUTOMATIC_UPDATER_DISABLED', false );
add_filter('pre_site_transient_update_core','__return_null');
