root@Syno-DS920Plus:~# docker exec -t crowdsec cscli decisions list
| ID | SOURCE | SCOPE:VALUE | REASON | ACTION | COUNTRY | AS | EVENTS | EXPIRATION | ALERT ID |
| 9858737 | crowdsec | Ip:xx.xxx.xx.xx | crowdsecurity/http-probing | ban | FR | 3215 Orange | 20 | 3h35m37.910782974s | 740 |
| 9842213 | crowdsec | Ip:xx.xxx.xx.yyy | crowdsecurity/http-probing | ban | FR | 3215 Orange | 20 | 3h18m8.673559166s | 738 |
4 duplicated entries skipped
root@Syno-DS920Plus:~# docker exec -t crowdsec cscli metrics
INFO[30-10-2022 09:34:09 AM] Buckets Metrics:
| BUCKET | CURRENT COUNT | OVERFLOWS | INSTANTIATED | POURED | EXPIRED |
| crowdsecurity/http-crawl-non_statics | - | - | 1.76k | 4.19k | 1.76k |
| crowdsecurity/http-probing | - | 18 | 97 | 510 | 79 |
INFO[30-10-2022 09:34:09 AM] Acquisition Metrics:
| SOURCE | LINES READ | LINES PARSED | LINES UNPARSED | LINES POURED TO BUCKET |
| file:/var/log/nginx/access.log | 118.48k | 118.44k | 38 | 3.05k |
| file:/var/log/nginx/access_adguardhome.log | 138 | 138 | - | - |
| file:/var/log/nginx/access_gitea.log | 1.47k | 1.47k | - | 58 |
| file:/var/log/nginx/access_nextcloud.log | 159.40k | 159.40k | - | 1.40k |
| file:/var/log/nginx/access_tautulli.log | 463 | 463 | - | - |
| file:/var/log/nginx/access_vaultwarden.log | 764 | 764 | - | 71 |
| file:/var/log/nginx/error.log | 2.17k | 1.94k | 229 | 104 |
| file:/var/log/nginx/error_gitea.log | 4 | - | 4 | - |
| file:/var/log/nginx/error_nextcloud.log | 54 | 39 | 15 | 16 |
| file:/var/log/nginx/error_tautulli.log | 2 | - | 2 | - |
| file:/var/log/nginx/error_vaultwarden.log | 11 | 3 | 8 | 1 |
INFO[30-10-2022 09:34:09 AM] Parser Metrics:
| PARSERS | HITS | PARSED | UNPARSED |
| child-crowdsecurity/http-logs | 847.98k | 620.86k | 227.12k |
| child-crowdsecurity/nginx-logs | 285.24k | 282.66k | 2.58k |
| crowdsecurity/dateparse-enrich | 282.66k | 282.66k | - |
| crowdsecurity/geoip-enrich | 282.66k | 282.66k | - |
| crowdsecurity/http-logs | 282.66k | 282.43k | 234 |
| crowdsecurity/nginx-logs | 282.96k | 282.66k | 296 |
| crowdsecurity/non-syslog | 282.96k | 282.96k | - |
| crowdsecurity/whitelists | 282.66k | 282.66k | - |
INFO[30-10-2022 09:34:09 AM] Local Api Metrics:
| ROUTE | METHOD | HITS |
| /v1/alerts | POST | 6 |
| /v1/decisions | GET | 136459 |
| /v1/heartbeat | GET | 14187 |
| /v1/watchers/login | POST | 238 |
INFO[30-10-2022 09:34:09 AM] Local Api Machines Metrics:
| MACHINE | ROUTE | METHOD | HITS |
| localhost | /v1/heartbeat | GET | 14187 |
| localhost | /v1/alerts | POST | 6 |
INFO[30-10-2022 09:34:09 AM] Local Api Bouncers Metrics:
| BOUNCER | ROUTE | METHOD | HITS |
| bouncer-swag | /v1/decisions | GET | 136459 |
INFO[30-10-2022 09:34:09 AM] Local Api Bouncers Decisions:
| BOUNCER | EMPTY ANSWERS | NON-EMPTY ANSWERS |
| bouncer-swag | 135758 | 701 |
INFO[30-10-2022 09:34:09 AM] Local Api Decisions:
| REASON | ORIGIN | ACTION | COUNT |
| crowdsecurity/http-crawl-non_statics | CAPI | ban | 88 |
| crowdsecurity/http-probing | CAPI | ban | 3588 |
| crowdsecurity/http-probing | crowdsec | ban | 6 |
| crowdsecurity/ssh-slow-bf | CAPI | ban | 11393 |
| crowdsecurity/CVE-2022-37042 | CAPI | ban | 1 |
| crowdsecurity/f5-big-ip-cve-2020-5902 | CAPI | ban | 1 |
| crowdsecurity/http-backdoors-attempts | CAPI | ban | 24 |
| crowdsecurity/http-bad-user-agent | CAPI | ban | 2499 |
| crowdsecurity/http-generic-bf | CAPI | ban | 9 |
| crowdsecurity/jira_cve-2021-26086 | CAPI | ban | 2 |
| crowdsecurity/http-cve-2021-41773 | CAPI | ban | 29 |
| crowdsecurity/http-open-proxy | CAPI | ban | 159 |
| crowdsecurity/http-sensitive-files | CAPI | ban | 30 |
| crowdsecurity/nginx-req-limit-exceeded | CAPI | ban | 1042 |
| crowdsecurity/thinkphp-cve-2018-20062 | CAPI | ban | 57 |
| ltsich/http-w00tw00t | CAPI | ban | 4 |
| crowdsecurity/CVE-2022-41082 | CAPI | ban | 496 |
| crowdsecurity/apache_log4j2_cve-2021-44228 | CAPI | ban | 17 |
| crowdsecurity/fortinet-cve-2018-13379 | CAPI | ban | 32 |
| crowdsecurity/http-path-traversal-probing | CAPI | ban | 131 |
| crowdsecurity/ssh-bf | CAPI | ban | 966 |
| crowdsecurity/vmware-cve-2022-22954 | CAPI | ban | 1 |
INFO[30-10-2022 09:34:09 AM] Local Api Alerts:
| REASON | COUNT |
| crowdsecurity/http-probing | 6 |
Souvent un problème reseau, et l'app ou autre spam en 404/403/400 et hop Crowdsec banMais pourquoi ?! Je n'ai pas utilisé différemment l'extension Bitwarden...
J’espère que ça ne se reproduira pas tropSouvent un problème reseau, et l'app ou autre spam en 404/403/400 et hop Crowdsec ban
Cela m'arrive parfois également. Meme si c'est en général avec Nextcloud.
Je ne comprend pas trop pourquoi il ne recommande pas de le faire.Et je ne lancerais pas fail2ban car apparemment ça ne cohabite pas très bien :
https://www.linuxserver.io/blog/blocking-malicious-connections-with-crowdsec-and-swag
(Dernier paragraphe)
Qu'ils ne recommandent pas de faire quoi ?Je ne comprend pas trop pourquoi il ne recommande pas de le faire.
Regarde ma citation ?Qu'ils ne recommandent pas de faire quoi ?
Et bien justement, je ne saisi pas ta remarque...Regarde ma citation ?
Donc eux ne le recommandent pas, de faire cohabiter Fail2Ban avec CrowdSec...One word of warning: We don't recommend running CrowdSec and fail2ban in parallel in a production environment, because you may end up with things falling through the cracks as they fight each other to block malicious connections.
Ou encore :Je ne comprend pas trop pourquoi il recommande de ne pas de le faire.
Je ne comprend pas trop pourquoi il ne recommande pas de faire cohabiter Fail2Ban avec CrowdSec.
Ha bah ça je ne sais pasRien compris
Pourquoi il ne faut pas faire cohabiter F2B et CrowdSec ? Les deux sont idenpendant, et font leurs jobs de leur côté, donc je comprends pas. Que se soit l'un ou l'autre par exemple aucun ne va écrire dans les logs, .. Ou autre action qui pourrait venir perturber l'autre. A la limite F2B pourrai être plus réactif sur certaines choses, et Crowdsec pourrai ne pas avoir le temps de le ban, (et inversement) mais ou et le problème ? L'IP étant bien bannie
version: "2.1"
services:
swag:
image: ghcr.io/linuxserver/swag
container_name: swag
volumes:
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/Config:/config
crowdsec:
container_name: crowdsec
image: crowdsecurity/crowdsec
restart: unless-stopped
environment:
- COLLECTIONS=crowdsecurity/nginx
- GID=100
depends_on:
- swag
volumes:
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/Config/log/nginx:/var/log/nginx
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/acquis.yaml:/etc/crowdsec/acquis.yaml
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/crowdsec-db:/var/lib/crowdsec/data/
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/crowdsec-config:/etc/crowdsec/
security_opt:
- no-new-privileges=true
dashboard:
container_name: crowdsec-dashboard
build: ./crowdsec/dashboard
depends_on:
- crowdsec
ports:
- 3000:3000
environment:
- MB_DB_FILE=/data/metabase.db
- MGID=100
volumes:
- /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/crowdsec-db:/metabase-data
OuiTu as donc bien un dossier /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/dashboard avec dedans un fichier Dockerfile ?
root@monnas:/srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/dashboard# ls
Dockerfile
En fait, je suis dans l'interface portainer, et je lance Stacks avec le bouton Actions : "Update the Stack"Tu lance bien la commande docker-compose depuis /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag ?
cd /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/dashboarddocker build -t crowdsec_dashboard . build: ./crowdsec/dashboard
image: crowdsec_dashboard
Comme moi !@EVOTk
Houhaaaa la rapidité ! trop sympa merci
Oui
Code:root@monnas:/srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/dashboard# ls Dockerfile
addgroup: gid '100' in use
adduser: unknown group metabase
su: unknown user metabase
Comme moi !
Et j’ai peur que tu ne t’en sortes pas davantage que moi![]()
ls -alh /srv/dev-disk-by-uuid-d710ceb1-028d-468d-b7eb-22b53d74e619/App/Swag/crowdsec/crowdsec-dbid mon_userHa on peut faire ça !?Ha, le problème c'est portainer. Je ne l'utilise que pour la supervision.
Donc je ne sais faire que en SSH, je ne sais pas si Portainer gère la construction d'image depuis un compose.
En SSH : ( en root ou avec sudo )
puis
Une fois finie, dans ton compose, tu remplace :
Par :Code:build: ./crowdsec/dashboard
Code:image: crowdsec_dashboard
