Désoler, j'ai oublié de préciser faut être en root avant, via la commande :
Je met ici les logs obtenus. Le truc qui me parle en premier c'est que la date et l'heure sont aux fraises
Apr 15 07:22:44 DXP4800-910D kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'pe>
Apr 15 07:22:44 DXP4800-910D kernel: pnp 00:04: disabling [mem 0xc0000000-0xcff>
Apr 15 07:22:44 DXP4800-910D kernel: ---mmc_init_card 0722
Apr 15 07:22:44 DXP4800-910D kernel: ext4 filesystem being mounted at /tmp/fact>
Apr 15 07:22:44 DXP4800-910D kernel: FAT-fs (mmcblk0p1): Volume was not properl>
Apr 15 07:22:44 DXP4800-910D kernel: device-mapper: core: CONFIG_IMA_DISABLE_HT>
Apr 15 07:22:44 DXP4800-910D systemd-udevd[366]: /usr/lib/udev/rules.d/60-i2c-t>
Apr 15 07:22:44 DXP4800-910D systemd-udevd[366]: Configuration file /etc/udev/r>
Apr 15 07:22:45 DXP4800-910D blkmapd[586]: open pipe file /run/rpc_pipefs/nfs/b>
Apr 15 07:22:45 DXP4800-910D rpc.idmapd[587]: Setting log level to 0
Apr 15 07:22:45 DXP4800-910D systemd[1]: e2scrub_all.timer: Not using persisten>
Apr 15 07:22:45 DXP4800-910D systemd[1]: logrotate.timer: Not using persistent >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.sock>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.so>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed >
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step N>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result '>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Ker>
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO d>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with res>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service >
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog >
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exi>
Apr 15 07:22:46 DXP4800-910D kernel: ---leds_ht32f52231_detect,chipid:0xc5b2
Apr 15 07:22:46 DXP4800-910D kernel: ---[leds_ht32f52231_probe][1416]addr[0x3a]
Apr 15 07:22:46 DXP4800-910D kernel: ---leds_ht32f52231_probe addr:0x3a finish
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/fact>
set mark: ...skipping...
log file: g --level 3,4
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socke>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - >
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to >
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at >
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with re>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mo>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAME>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exi>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerber>
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devi>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - S>
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-c>
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory>
Apr 15 07:22:48 DXP4800-910D kernel: Set BOOT power off
lines 13-36
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socket ->
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - SSS>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to set>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at ste>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with resul>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mount>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAMESPA>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exit-c>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerberos >
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devices>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result 'e>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - Self>
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can no>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-code>
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory su>
lines 13-36
Ca boucle autour des mêmes messsages en ajoutant de nouvelles lignes jusqu'à :
lines 13-70
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - SSSD NSS Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket - SSSD AutoFS Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - SSSD PAC Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socket - SSSD PAM Service responder private socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - SSSD PAM Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - SSSD SSH Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - SSSD Sudo Service responder socket.
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to set up mount namespacing: /run/systemd/unit-root/var/lib/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at step NAMESPACE spawning /usr/sbin/kadmind: No such file or directory
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mount namespacing: /run/systemd/unit-root/var/lib/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAMESPACE spawning /usr/sbin/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerberos 5 Key Distribution Center.
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devices found to scan
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - Self Monitoring and Reporting Technology (SMART) Daemon.
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can not be accessed, probably does not exist - directive ignored [v8.2302.0 try https://www.rsyslog>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-code'.
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory supports timestamps until 2038 (0x7fffffff)
Apr 15 07:22:48 DXP4800-910D kernel: ---do_color_set color:1, ret:0, name:sys
Apr 15 07:22:48 DXP4800-910D kernel: ---do_color_set color:1, ret:0, name:net
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: Can't bind to dhcp address: Cannot assign requested address
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: Please make sure there is no other dhcp server
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: running and that there's no entry for dhcp or
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: bootp in /etc/inetd.conf. Also make sure you
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: are not running HP JetAdmin software, which
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: includes a bootp server.
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: If you think you have received this message due to a bug rather
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: than a configuration issue please read the section on submitting
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: bugs on either our web page at www.isc.org or in the README file
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: before submitting a bug. These pages explain the proper
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: process and the information we find helpful for debugging.
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: exiting.
Apr 15 07:22:49 DXP4800-910D rpc.statd[1232]: Flags: TI-RPC
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: Can't bind to dhcp address: Cannot assign requested address
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: Please make sure there is no other dhcp server
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: running and that there's no entry for dhcp or
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: bootp in /etc/inetd.conf. Also make sure you
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: are not running HP JetAdmin software, which
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: includes a bootp server.
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: If you think you have received this message due to a bug rather
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: than a configuration issue please read the section on submitting
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: bugs on either our web page at www.isc.org or in the README file
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: before submitting a bug. These pages explain the proper
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: process and the information we find helpful for debugging.
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: exiting.
Apr 15 07:22:49 DXP4800-910D rpc.statd[1232]: Running as root. chown /var/lib/nfs to choose different user
Apr 15 07:22:49 DXP4800-910D systemd[1]: nfs-server.service: Failed with result 'exit-code'.
Apr 15 07:22:49 DXP4800-910D rpc.idmapd[587]: exiting on signal 15
Puis 3minutes plus loin ça boucle sur cette partie :
Apr 15 07:25:50 DXP4800-910D avahi-autoipd(eth0)[4056]: Killing child.
Apr 15 07:25:50 DXP4800-910D avahi-autoipd(eth0)[4056]: Script execution failed with return value 2
Apr 15 07:25:51 DXP4800-910D systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
Apr 15 07:25:51 DXP4800-910D systemd-udevd[366]: /usr/lib/udev/rules.d/60-i2c-tools.rules:1 Unknown group 'i2c', ignoring
Apr 15 07:25:51 DXP4800-910D unknown: start blkdeactivate
lines 13-36
lines 13-36
lines 13-70
