UGREEN UGREEN DXP4800 : plus d'accès après 1er redémarrage
Désoler, j'ai oublié de préciser faut être en root avant, via la commande :
Je met ici les logs obtenus. Le truc qui me parle en premier c'est que la date et l'heure sont aux fraises 🤨
Apr 15 07:22:44 DXP4800-910D kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'pe>
Apr 15 07:22:44 DXP4800-910D kernel: pnp 00:04: disabling [mem 0xc0000000-0xcff>
Apr 15 07:22:44 DXP4800-910D kernel: ---mmc_init_card 0722
Apr 15 07:22:44 DXP4800-910D kernel: ext4 filesystem being mounted at /tmp/fact>
Apr 15 07:22:44 DXP4800-910D kernel: FAT-fs (mmcblk0p1): Volume was not properl>
Apr 15 07:22:44 DXP4800-910D kernel: device-mapper: core: CONFIG_IMA_DISABLE_HT>
Apr 15 07:22:44 DXP4800-910D systemd-udevd[366]: /usr/lib/udev/rules.d/60-i2c-t>
Apr 15 07:22:44 DXP4800-910D systemd-udevd[366]: Configuration file /etc/udev/r>
Apr 15 07:22:45 DXP4800-910D blkmapd[586]: open pipe file /run/rpc_pipefs/nfs/b>
Apr 15 07:22:45 DXP4800-910D rpc.idmapd[587]: Setting log level to 0
Apr 15 07:22:45 DXP4800-910D systemd[1]: e2scrub_all.timer: Not using persisten>
Apr 15 07:22:45 DXP4800-910D systemd[1]: logrotate.timer: Not using persistent >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.sock>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.so>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed >
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step N>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result '>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Ker>
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO d>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with res>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service >
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog >
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exi>
Apr 15 07:22:46 DXP4800-910D kernel: ---leds_ht32f52231_detect,chipid:0xc5b2
Apr 15 07:22:46 DXP4800-910D kernel: ---[leds_ht32f52231_probe][1416]addr[0x3a]
Apr 15 07:22:46 DXP4800-910D kernel: ---leds_ht32f52231_probe addr:0x3a finish
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/fact>
set mark: ...skipping...
log file: g --level 3,4
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket >
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socke>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - >
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to >
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at >
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with re>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mo>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAME>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exi>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerber>
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devi>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - S>
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-c>
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory>
Apr 15 07:22:48 DXP4800-910D kernel: Set BOOT power off
lines 13-36
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket - S>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socket ->
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - SSSD>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - SSS>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to set>
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at ste>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with resul>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mount>
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAMESPA>
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exit-c>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerberos >
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devices>
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result 'e>
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - Self>
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can no>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-code>
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory su>
lines 13-36
Ca boucle autour des mêmes messsages en ajoutant de nouvelles lignes jusqu'à :
lines 13-70
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-nss.socket - SSSD NSS Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-autofs.socket - SSSD AutoFS Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pac.socket - SSSD PAC Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam-priv.socket - SSSD PAM Service responder private socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-pam.socket - SSSD PAM Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-ssh.socket - SSSD SSH Service responder socket.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Dependency failed for sssd-sudo.socket - SSSD Sudo Service responder socket.
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed to set up mount namespacing: /run/systemd/unit-root/var/lib/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D (kadmind)[610]: krb5-admin-server.service: Failed at step NAMESPACE spawning /usr/sbin/kadmind: No such file or directory
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-admin-server.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed to set up mount namespacing: /run/systemd/unit-root/var/lib/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D (krb5kdc)[612]: krb5-kdc.service: Failed at step NAMESPACE spawning /usr/sbin/krb5kdc: No such file or directory
Apr 15 07:22:45 DXP4800-910D systemd[1]: krb5-kdc.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start krb5-kdc.service - Kerberos 5 Key Distribution Center.
Apr 15 07:22:45 DXP4800-910D smartd[628]: In the system's table of devices NO devices found to scan
Apr 15 07:22:45 DXP4800-910D systemd[1]: smartmontools.service: Failed with result 'exit-code'.
Apr 15 07:22:45 DXP4800-910D systemd[1]: Failed to start smartmontools.service - Self Monitoring and Reporting Technology (SMART) Daemon.
Apr 15 07:22:45 DXP4800-910D rsyslogd[623]: $WorkDirectory: /var/spool/rsyslog can not be accessed, probably does not exist - directive ignored [v8.2302.0 try https://www.rsyslog>
Apr 15 07:22:45 DXP4800-910D systemd[1]: upnpd.service: Failed with result 'exit-code'.
Apr 15 07:22:46 DXP4800-910D kernel: ext4 filesystem being mounted at /mnt/factory supports timestamps until 2038 (0x7fffffff)
Apr 15 07:22:48 DXP4800-910D kernel: ---do_color_set color:1, ret:0, name:sys
Apr 15 07:22:48 DXP4800-910D kernel: ---do_color_set color:1, ret:0, name:net
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: Can't bind to dhcp address: Cannot assign requested address
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: Please make sure there is no other dhcp server
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: running and that there's no entry for dhcp or
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: bootp in /etc/inetd.conf. Also make sure you
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: are not running HP JetAdmin software, which
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: includes a bootp server.
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: If you think you have received this message due to a bug rather
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: than a configuration issue please read the section on submitting
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: bugs on either our web page at www.isc.org or in the README file
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: before submitting a bug. These pages explain the proper
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: process and the information we find helpful for debugging.
Apr 15 07:22:48 DXP4800-910D dhclient[1039]: exiting.
Apr 15 07:22:49 DXP4800-910D rpc.statd[1232]: Flags: TI-RPC
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: Can't bind to dhcp address: Cannot assign requested address
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: Please make sure there is no other dhcp server
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: running and that there's no entry for dhcp or
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: bootp in /etc/inetd.conf. Also make sure you
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: are not running HP JetAdmin software, which
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: includes a bootp server.
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: If you think you have received this message due to a bug rather
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: than a configuration issue please read the section on submitting
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: bugs on either our web page at www.isc.org or in the README file
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: before submitting a bug. These pages explain the proper
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: process and the information we find helpful for debugging.
Apr 15 07:22:49 DXP4800-910D dhclient[1223]: exiting.
Apr 15 07:22:49 DXP4800-910D rpc.statd[1232]: Running as root. chown /var/lib/nfs to choose different user
Apr 15 07:22:49 DXP4800-910D systemd[1]: nfs-server.service: Failed with result 'exit-code'.
Apr 15 07:22:49 DXP4800-910D rpc.idmapd[587]: exiting on signal 15
Puis 3minutes plus loin ça boucle sur cette partie :
Apr 15 07:25:50 DXP4800-910D avahi-autoipd(eth0)[4056]: Killing child.
Apr 15 07:25:50 DXP4800-910D avahi-autoipd(eth0)[4056]: Script execution failed with return value 2
Apr 15 07:25:51 DXP4800-910D systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
Apr 15 07:25:51 DXP4800-910D systemd-udevd[366]: /usr/lib/udev/rules.d/60-i2c-tools.rules:1 Unknown group 'i2c', ignoring
Apr 15 07:25:51 DXP4800-910D unknown: start blkdeactivate
Ta log semble être coupé sur le côté droit, ce qui me permet pas de la lire correctement.
Essaie de faire :
journalctl -b0 -p warning > log.txt
Puis lister le dossies des utilisateurs:
Déplacer le fichier log:
mv log.txt /home/<USER>
Ensuite tu va dans le dossier Home de l'utilisateur (Partage) et transmet moi le fichier log.txt
Pour supprimer le fichier :
rm /home/<USER>/log.txt
Je soupçonne un problème de partition:
J'ai du zapper un truc car ça m'inscrit que les logs de ce soir, pas ceux remontant les problèmes de vendredi.
Merci pour ta patience en tous cas.
heuuuu y'a un gros soucis quand même car le moins qu'on puisse dire c'est qu'un NAS est d'office connecté sur un réseau, donc a l'heure et le jour sans soucis !!!
d’après ton log au-dessus il est en mi avril alors qu'on est le 7 juillet :eek::eek:
tu l' acheté recemment il me semble donc perso avec un "bug" pareil c'est retour direct au vendeur :cautious:
y'a p'tete la CPU qui est HS, ou autre gros pbm mais de toute façon ça sera pas facilement récupérable, surtout pour un appareil neuf o_O
Il peut être tout simplement pas à l'heure . (Fuseau horaire en GMT +0)
Peut être le bios aussi.
re,
possible bien sur, mais sur tous les NAS que j'ai installé l'heure était d'office ok, a fortiori sur du neuf !
en tout cas jamais un acheteur d'Ugreen a eu ce pbm ici ...
peut être aussi l'impossibilité de l'appareil de se connecter au réseau, donc pas de synchro date et heure ?
Pour les soucis d'horaires j'ai demandé au support mais de ce que je vois dans les logs c'est que ça a bien basculé sur le bon timecode depuis l'incident du blocage du redémarrage.
D'ailleurs le support Ugreen m'a expliqué comment récupérer tous les logs facilement depuis l'interface du NAS, donc pour les propriétaire de NAS Ugreen qui ne seraient pas au courant, voici l'accès :
-> lancer l'application "support"
-> sélectionner "contact"
-> "outils auxiliaires" dans le menu de gauche
-> générer le diagnostic en un clic.
-> cela télécharge un dossier compressé complet :
@Drthrax74 : si certains éléments peuvent approfondir le problème rencontré n'hésite pas à me le dire.
Par ailleurs le SMART test approfondi de mon disque dur s'est terminé après un peu plus de 30h...
Je ne comprends pas grand chose aux valeurs indiquées mais il y a écrit "bon" à la fin 😅
Sinon pas rencontré de problème particulier depuis à l'usage. Je mise sur un problème software lors du set-up, leur logiciel étant a priori plutôt très récent par rapport à du QNAP ou Synology. En tout cas si je peux éviter de tester leur SAV ça m'arrangerait.
Si tu peux compresser et joindre l'archive car sa risque d'être ce que je recherches pour t'aider.
Sa sent pas très bon .
Messages d'erreur
# 1. Failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
# 1. Failed to load the 'mdraid' libblockdev plugin
# 2. PTE Write access is not set
# 3. I/O error, dev sdb, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Explication:
1. Ce message est généré par le service udisks2 au démarrage. Il indique que le module permettant la gestion des volumes RAID logiciels (mdraid) n’a pas pu être chargé, car la bibliothèque partagée libbd_mdraid.so.2 est absente du système
2. Ce message apparaît généralement dans les logs du noyau Linux lorsqu’il y a un problème d’accès mémoire lors d’une opération DMA (Direct Memory Access) avec l’IOMMU (Input-Output Memory Management Unit). Plus précisément, cela indique qu’une tentative d’écriture mémoire par un périphérique PCI (comme un contrôleur de disque) a échoué parce que la table de pages (Page Table Entry, PTE) n’autorise pas l’écriture à cette adresse.
3. Problème de Lecture/ecriture sur le disque sdb
L'idéal serait faire un backup complet des données du NAS puis de le réinstaller.
Et de réinjecter les données.
Merci beaucoup pour cette investigation. Je suis surpris que cela concerne le raid car je n'ai pas fait appel au raid que je n'utilise pas.
Tu as identifié cela dans un log lors de la 1ère mise en route où c'est une erreur qui remonte encore aujourd'hui ?
Par backup complet tu entends quoi ? Sortir les HDD et faire un reset usine du NAS puis les remettre n'est pas suffisant (l'OS est situé sur la mémoire eMMC du NAS) ?
Bonjour, j'ai exactement le même problème aujourd'hui.
Cela fait trois jours que j'ai installé le NAS est tout fonctionnait bien. J'ai testé la programmation d'extinction et rallumage dans la nuit de (2h à 7h) et ce matin, tout allait bien. J'ai fais un gros transfert de photos et installé les modèles d'IA pour les essayé. C'est à peu près au même moment où j'ai perdu la connexion au NAS et qu'il s'est mis dans le même état que décrit @JuLo (LED qui clignotent séquentiellement). J'ai eu une reconnexion à un moment où l'OS m'indiquait d'éteindre le NAS correctement puis j'ai reperdu la connexion...
Contrairement, à @JuLo, mon NAS se mets à redémarrer et m'affiche une notification d'arrêt anormal
Je ne sais pas trop quoi faire...
Config :
DXP4800+
2 HDD WD Red Plus 4To en RAID 1
1 SSD M.2 Crucial 1To
je réitère ma proposition ... surtout que tu continu à avoir des soucis avec cet appareil, t'imagine dans qlq mois voir hors garantie si ça recommence o_O:eek:
Bonjour PasNAS-c,
Comment as-tu pu résoudre ton problème ?
Disons que je l'ai à moitié résolu. J'ai contacté le support UGreen, qui a été extrêmement réactif (moins de dix minutes pour la première réponse), mais je n'ai pas vraiment eu de réponses significatives (demande de reboot, vérification des branchements, demande de reset).
Ma supposition était qu'il y avait un problème avec le modèle d'IA qui devait faire crasher le NAS. Initialement, je croyais que c'était le redémarrage qui avait un souci mais comme je viens d'avoir le NAS et que je fais un grand nombre de transferts et manipulations, c’est difficile de diagnostiquer rapidement. J'ai + de 1000 photos en format RAW (fichier brut du capteur photos) et je crois que le modèle n'arrive pas à gérer la quantité d'informations. J'ai désactivé les modèles IA sur les répertoires photos et le NAS est redevenu stable.
Réactions: Marino
