/etc/apt/sources.list.d/openmediavault.listdeb http://packages.openmediavault.org/public shaitan main
# deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan main
## Uncomment the following line to add software from the proposed repository.
# deb http://packages.openmediavault.org/public shaitan-proposed main
# deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan-proposed main
## This software is not part of OpenMediaVault, but is offered by third-party
## developers as a service to OpenMediaVault users.
# deb http://packages.openmediavault.org/public shaitan partner
# deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan partner
apt install --yes gnupg
wget -O "/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc" https://packages.openmediavault.org/public/archive.key
apt-key add "/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc"
Comment a tu installé OMV6 ? On dirai qu'il te manque les certificats des dépots.
Tu trouvera ci-dessous ce que doit contenir :/etc/apt/sources.list.d/openmediavault.list
Code:deb http://packages.openmediavault.org/public shaitan main # deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan main ## Uncomment the following line to add software from the proposed repository. # deb http://packages.openmediavault.org/public shaitan-proposed main # deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan-proposed main ## This software is not part of OpenMediaVault, but is offered by third-party ## developers as a service to OpenMediaVault users. # deb http://packages.openmediavault.org/public shaitan partner # deb http://downloads.sourceforge.net/project/openmediavault/packages shaitan partner
Pour récupérer les clés du dépots :
Code:apt install --yes gnupgCode:wget -O "/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc" https://packages.openmediavault.org/public/archive.keyCode:apt-key add "/etc/apt/trusted.gpg.d/openmediavault-archive-keyring.asc"
Source : https://forum.openmediavault.org/index.php?thread/39490-install-omv6-on-debian-11-bullseye/
ping -4 -c 4 openmediavault.org, pas d'erreur ?gnupg est bien installé.A tu essayer de faire cette commande avant :apt install --yes gnupg
Pas de soucis sur ce point chez moi :
Si tu fait la commande :ping -4 -c 4 openmediavault.org, pas d'erreur ?
dateLa commande date vous retourne bien la bonne date et heure ?ça c'était bon.
# deb cdrom:[Debian GNU/Linux 11 _Bullseye_ - Official Snapshot amd64 LIVE/INSTALL Binary 20211107-12:44]/ bullseye contrib main non-free
deb http://deb.debian.org/debian/ bullseye main
deb-src http://deb.debian.org/debian/ bullseye main
# bullseye-updates, to get updates before a point release is made;
# see https://www.debian.org/doc/manuals/debian-reference/ch02.en.html#_updates_and_backports
deb http://deb.debian.org/debian/ bullseye-updates main contrib non-free
deb-src http://deb.debian.org/debian/ bullseye-updates main contrib non-free
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
ls /etc/apt/sources.list.d/ vous donne bien :docker.list openmediavault-kernel-backports.list openmediavault-local.list openmediavault-os-security.list openmediavault.list
cat /etc/apt/sources.list.d/openmediavault.list :deb http://packages.openmediavault.org/public/ shaitan main
deb https://openmediavault.github.io/packages/ shaitan main
# deb http://downloads.sourceforge.net/project/openmediavault/packages/ shaitan main
omv-salt deploy run apt
