QNAP [ Audiobookshelf ] Audiobookshelf is a self-hosted audiobook and podcast server.
QoolBox
Représentant QNAP
2 Janvier 2014
10 748
185
173
51
www.qnap.com
Oui
banner.svg
Source : https://github.com/advplyr/audiobookshelf
Download :
requirements : ffmpeg qpkg
Features
Fully open-source, including the android & iOS app (in beta)
Stream all audio formats on the fly
Search and add podcasts to download episodes w/ auto-download
Multi-user support w/ custom permissions
Keeps progress per user and syncs across devices
Auto-detects library updates, no need to re-scan
Upload books and podcasts w/ bulk upload drag and drop folders
Backup your metadata + automated daily backups
Progressive Web App (PWA)
Chromecast support on the web app and android app
Fetch metadata and cover art from several sources
Basic ebook support and e-reader (experimental)
Merge your audio files into a single m4b w/ metadata and embedded cover (experimental)
Réactions: Fabwiss
A chaque tentative d'ajout d'un répertoire et du scan j'ai un message d'erreur "Socket Failed to Connect" .
Je viens de tester j'ai également le message d'erreur Socket Failed to Connect sur la version 2.0.22.1
tu as bien ffmpeg installé ?
tu as quelques chose dans les logs :
/opt/Audiobookshelf/metadata/logs
verifie que le lien symbolique de ffmpeg est bien in inscrit de /opt
v2.2.1 Latest
Added​
  • Multi-region audible providers using audnexus api #731
  • Chapter editor option to shift all chapters by X seconds #927
Fixed​
  • Crash when quick matching audible book with tags (Issue #1030) by @Undergrid in #1031
  • Escape ebook URLs properly #1039
  • Authors page to only include library items from the current library #1049
  • Tone error on arm64 docker image #1035
  • Setting book chapters from audio files will always use first audio file embedded chapters if it has them #1052
  • Library edit modal stays loading when switching tabs
Changed​
  • Update tone to v0.1.1
  • Downloaded podcast episode filenames will use the episode title only (no longer prefixes episode num)
  • iTunes matching will correctly split authors correctly with format "author a, author b & author c" #1022
  • Scanner folder name parsing series sequence supports decimal starting with . (e.g. Vol .5)
  • Scanner folder name parsing series sequence will cast to a number (removes leading zeros)
  • Podcast download file requests timeout after 30s #1050
  • Number of backups to keep tooltip #1041
  • Debian package service runs as group "audiobookshelf"
Réactions: lexdev42
v2.2.2 Latest
Added​
  • Series page filter & sort options #712
  • Hold Shift key to select range of items #1020
  • New library icons #1075
  • Support for webm and webma audio files #1079
  • Chapter lookup multi-region support
Fixed​
  • Embedding meta tags when a description starts with a double quote #1044 (by @keaganhilliard in #1110)
  • Embedding meta tags changing chapter times #1060 (fixed in tone v0.1.2)
  • Multi-select dropdowns show X for removing items #1055
  • Collection covers not loading
  • Local covers not showing in book edit modal covers tab
  • Parsing pubDate for podcast RSS feeds #1072
  • Opening PDFs
  • Comic reader for comics that have subfolders #811
  • Debian package incorrect wget invocation #1092
  • Sorting ignore prefixes (by @ruoti in #1111)
Changed​
  • Update tone to v0.1.2
  • Podcast auto-download episode schedule includes setting for max episodes to download #1091
  • Collapsed series show green line when entire series is finished #1062
  • Collections page book list shows authors (& fixes for mobile screens) #943
  • Book scanner fallback to using comment tag for book description
  • Default library view is now detail view (previously named alternate view)
  • Book chapter editor: Lookup chapter modal shows # of chapters found vs current # of chapters #1070
  • Comic reader: improved sorting for pages
  • For debian installs add note to folder picker that this is not fully implemented
Merci bien j'ai réinstallé une version antérieur , en espérant que le dev donne une solution au problème.
