QNAP TS-853A NEUF: pas possible de faire la MAJ du firmware
ech1965
16 Janvier 2016
73
Je viens de recevoir mon NAS de remplacement via AMAZON ( TS-853A)
Je l'ai configuré temporairement avec juste un disque de 500GB.
Après les assistants d'usage, je me connecte à l'interface de gestion et là... il me propose de faire la MAJ du frmware de 4.2.0 vers 4.2.1...
J'accepte là , patatra, elle rate.
Je cherche un peu et je trouve ce ficher de log
[~] # cat /tmp/update_fw.log
cksum=1955343900
Check RAM space available for FW update: OK.
Using 120-bit encryption - (QNAPNASVERSION4)
len=1048576
model name = TS-X53II
version = 4.2.1
IS_STORAGE_V2
boot/
bzImage
bzImage.cksum
config/
ec_force_boot
fw_info
initrd.boot
initrd.boot.cksum
libcrypto.so.1.0.0
libssl.so.1.0.0
qpkg.tar
qpkg.tar.cksum
rootfs2.bz
rootfs2.bz.cksum
rootfs_ext.tgz
rootfs_ext.tgz.cksum
sas_fw/
sas_fw/sas_updater
sas_fw/sas_fw_update.sh
sas_fw/BIOS.img
sas_fw/HBA.img
sas_fw/NAS.img
sas_fw/sas_fw.conf
tbs_ec_fw.BIN
ts_ec_fw.BIN
update/
update_ec.conf
update_ec.sh
update_img.sh
4.2.1 20160601
MODEL NAME = TS-X53II,new version = 4.2.1
limit version = 3.7.2
Allow upgrade
Allow upgrade
/mnt/HDA_ROOT/update
1+0 records in
1+0 records out
/sbin/tune2fs: Read-only file system while trying to open /dev/sda6
Couldn't find valid filesystem superblock.
tune2fs 1.41.4 (27-Jan-2009)
update nas sas hba firmware...
internal_sas_count = -1
done.
update sas bios...
done.
update pci-e sas hba firmware...
done.
Update image using HDD ...
bzImage cksum ... Pass
initrd.boot cksum ... Pass
rootfs2.bz cksum ... Pass
rootfs_ext.tgz cksum ... Pass
qpkg.tar cksum ... Pass
Update RFS1...
mke2fs 1.41.4 (27-Jan-2009)
/dev/sda2: Read-only file system while setting up superblock
mount: block device /dev/sda2 is write-protected, mounting read-only
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/bzImage': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/bzImage.cksum': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/initrd.boot': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/initrd.boot.cksum': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/rootfs2.bz': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/rootfs2.bz.cksum': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/rootfs_ext.tgz': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/rootfs_ext.tgz.cksum': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/qpkg.tar': Read-only file system
/bin/cp: cannot create regular file `/root/FLASH_RFS1/boot/qpkg.tar.cksum': Read-only file system
Checking bzImage ... Failed.
[Firmware Update] System update failed. Error code: FW999
ça parle à quelqu'un ?
J'ai ouvert un nouveau ticket chez qnap, mais ils ne travaillent pas la nuit ;-)
Bonne soirée
Etienne
ben fais une install manuel
c'est hyper simple et ca marche toujours
tu telecharges sur leur site
tu ouvres et tu dis au NAS ou c'est et tu laisse faire
Merci pour le tuyau..
Non ça ne marche pas toujours!
J'ai tenté la mise à jour manuelle via l'interface web : pareil
également la mise à jour manuelle via ssh en suivant cette procédure: http://wiki.qnap.com/wiki/Manually_Updating_Firmware pareil !
même message d'erreurs dans le log
d'autres idées ?
Bonne journée
Du neuf,
Jai retesté ce matin depuis un autre PC .. et !! youpie la MAJ automatique a marché MAIS!!!
J'ai ce message dans le log
Type	Date	Time	Users	Source IP	Computer name	Content
Error	2016/06/15	12:02:38	System	127.0.0.1	localhost	The second boot area on the flash is corrupted.
J'ai tenté de installer la MAJ (téléchargée sur mon pc) en passant par l'onglet 'Firmware update" ( désolé, le l'UI du NAS en français, c'est juste horrible) mais ça ne change rien
merci pour votre intérêt !
Etienne
