QNAP QTS4.2.0 Build 0910 RC2
QoolBox
Représentant QNAP
2 Janvier 2014
10 793
191
173
52
www.qnap.com
Oui
arrivé imminente
QTS4.2.0 Build 0910
[Bug Fixes]
- Fails to list files in File Station.
- Fixed potential CGI script vulnerabilities. Users are strongly urged to upgrade their NAS firmware with this release.
- Fixed Apache HTTP Server vulnerability.
- Fails to log into NAS after setting up 2-step verification.
- Fails to mount a USB device connected via a USB hub.
- After setting a bridge of a VPN Server to the default Gateway and connecting a VPN Client to the VPN Server, users will be unable to connect to the internet.
- Unnecessary attributes may be displayed after connecting to Google Drive/Microsoft OneDrive in File Station and right clicking on its folder.
- Videos will not be smoothly played when streaming via Airplay from the File Station toolbar.
- A cloned VM will be unable to boot up with Read/Write cache enabled if using a Block-based thin LUN.
- HGST HUS726020AL5210 (12Gbps SAS) drives may be missing when performing iometer tests for a certain period of time.
- The file base iSCSI LUN will be missing in the cloned volume of a snapshot clone.
- If a RAID 5 pool is expanded in Storage Management, the expanded HDD becomes a spare HDD.
- 250T/144T cannot be created on block-based thin LUNs.
- There are excessive samba processes after changing Windows ACL permissions and launching File Station.
- TS-269H models occasionally fail to copy files to Dropbox.
- When using Microsoft Edge, Surveillance Station will identify it as Internet Explorer.
- After upgrading to Surveillance Station 5.1.0.1, the default recordings folder in the playback path will be missing.
- Surveillance Station cannot display all the playback channels.
- Surveillance Station fails to generate event logs if changing SMTP server settings in Event Management.
- Fails to execute zip files when uploading them via FTP to the NAS when "Advanced Folder Permission" is enabled in File Station.
- Fails to apply new permissions for non-Administrator groups in File Station's permissions setup page.
- The owner and user list fields cannot display long usernames in File Station's permissions setup page.
- The Guest Access Rights in File Station's folder permissions always shows "-2" regardless of what value you give it.
[Note]
- QTS 4.2 is the final major firmware release for the following NAS models:
 TS-410U, TS-412U, TS-410, TS-112, TS-212, TS-412, TS-110, TS-219, TS-210, TS-119, TS-419U, TS-419P, SS-439 Pro, SS-839 Pro, TS-239H, TS-239 Pro, TS-439 Pro, TS-439U-RP/ SP, TS-639 Pro, TS-509 Pro, TS-809 Pro, TS-809U-RP
Quoi du ts-x53 pro?
Edit: oui elle est dispose. En plus mnt j'ai reçu la notif dans qts pour devenir beta tester. Je crois qu'il s'agit d'une nouvelle fonctionnalité vu tous les retours reçus par qnap par toute la communauté pendant le betatesting de 4.2..
Ici ca tourne sans problemes
J'ai detecté que mes settings de UPS on't été reseté.
Mon nas est conencté par usb a mon UPS, apres le firmware update, la coche "Network UPS" était selectioné a la place... pas grande chose, pour le reste tout a l"ere stabile.
J'ai quand meme remarque aussi une pteite nuisance: Depuis les beta's 4.2 je remarque que dans le file station il trie les fichier par "Modified date" a la place de "Alphabet A-z"
Ce qui est tres etrange et contra-intuitive, car linux,windows et Macinotsh montrent toujours les fichiers trie par nom A-Z
