QTS 5.2.11.3683 build 20261114
HS-251+,S2
QMiroPlus-201W
QAI-h1290FX
QBoat Sunny
QBoat-300
QGD-1600P,QGD-1600
QGD-1602P,QGD-1602
QGD-3014-16PT
TS-453S Pro,TS-853S Pro
TS-432XeU
TS-531P
TS-216,TS-416
TS-231P3,TS-431P3
TS-231P2,TS-431P2
TS-431XU,TS-831XU,TS-1231XU,TS-431XU-RP,TS-831XU-RP,TS-1231XU-RP,TS-431XeU
TS-932X,TS-832X,TS-332X,TS-532X,TS-932PX,TS-832PX,TS-432X,TS-632X
TS-133,TS-233,TS-433,D4 Rev-C,TS-216G,D2 Rev-C
TS-433eU
TS-1635
TS-1635AX
TS-435XeU
TS-231+,TS-431+,TS-131P,TS-231P,TS-431P,TS-131K,TS-231K,TS-431K,D2,D4,D4 Rev-B
TS-AI642
TS-251A,TS-451A,D2 Pro,D4 Pro
TS-251B
TS-451U
TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-453BT3,TS-253Be,TS-453Be
TS-253E,TS-453E
TS-1655,TS-855X
TS-855eU,TS-855eU-RP,TS-h1655XeU-RP
TS-564,HS-264,TBS-464,TS-262C,TS-462C,TS-264C,TS-464C,TS-364,TS-464,TS-664,TS-262,TS-462,TS-264,TS-464C2,TS-262A,TS-462A
Qu805,Qu605,Qu405,TS-h665,TS-h865,TBS-465X
TS-h765eU,TS-h665U,TS-h665U-RP,TS-h1465U-RP,TS-h1065eU,TS-h1065eU-RP
TS-466C
TS-h966TX
TS-467X,TS-667X,TS-867X
TVS-472XT,TVS-672XT,TVS-872XT,TVS-672N,TVS-872N,TVS-872X,TVS-672X
TS-h1073BXeU,TS-h1073BXeU-RP,TS-h673BXU,TS-h673BXU-RP,TS-h1473BXU-RP,TS-h1873BXU-RP
TVS-h474,TVS-h674,TVS-h874,TVS-h874X,TVS-h674T,TVS-h874T
TBS-h574TX
TVS-675
TS-h1277AFX,TVS-h877AX,TVS-h1277AX,TVS-h1677AX
TS-h1277AXU-RP,TS-h1677AXU-RP,TS-h3077AFU,TS-h2477AXU-RP,TS-h1077AFU
TVS-882T,TVS-1282T,TVS-682,TVS-882,TVS-1282,TVS-682T,TVS-1282T3,TVS-882BR,TVS-882BRT3
TVS-882ST,TVS-882ST3
TVS-1582TU
TS-1685,TS-h886,TS-h686
TS-h3088XU-RP
TDS-h2489FU,TDS-h2489FU R2
TDS-16489U
TDS-h6889AXU-RP
TS-h1290FX
TS-h2490FU,TS-h1090FU
TS-328,TS-428,TS-230,D2 Rev-B
TS-551
TS-473,TS-673,TS-873
TVS-951X,TVS-951N
TS-i410X,TS-410E
QMiroPlus-201W
QAI-h1290FX
QBoat Sunny
QBoat-300
QGD-1600P,QGD-1600
QGD-1602P,QGD-1602
QGD-3014-16PT
TS-432XeU
TS-531P
TS-216,TS-416
TS-231P3,TS-431P3
TS-231P2,TS-431P2
TS-433eU
TS-1635
TS-1635AX
TS-435XeU
TS-AI642
TS-251B
TS-451U
TS-253E,TS-453E
TS-1655,TS-855X
TS-466C
TS-h966TX
TBS-h574TX
TVS-675
TVS-1582TU
TS-h3088XU-RP
TDS-16489U
TDS-h6889AXU-RP
TS-h1290FX
TS-551
TVS-951X,TVS-951N
TS-i410X,TS-410E
Notes importantes
- Si votre appareil exécute actuellement une version antérieure à QTS 5.2.9, une invite de confirmation « downgrade» peut apparaître lorsque vous mettez à jour manuellement QTS à 5.2.10 ou version ultérieure. L'invite n'affecte pas la mise à jour. Vous pouvez procéder en toute sécurité à la mise à jour. Cette invite n'apparaît pas lors de l'utilisation de Live Update.
Mises à jour de sécurité
- Appliquer plusieurs mises à jour de sécurité pour améliorer davantage la sécurité du système (CVE-2026-109618, CVE-2026-109619, CVE-2026-119618, CVE-2026-86640).
Amélioration
- Les mises à jour en direct sur les appareils JBOD de la série TR et TL informent désormais les utilisateurs des mises à jour importantes, pas nécessairement les dernières mises à jour.
Correction de problèmes
- Correction d'un problème où les utilisateurs ne pouvaient pas connecter le NAS à un PC via le port USB QuickAccess et ne pouvaient pas obtenir l'adresse IP du NAS.
- Correction d'un problème où les membres de l'organisation nouvellement ajoutés ne pouvaient pas se voir attribuer le rôle de "Device Admin".
- Correction d'un problème où un e-mail de vérification en 2 étapes envoyait un code de sécurité incomplet qui ne contenait que 1 chiffre (un code de sécurité complet devrait contenir 6 chiffres).
- Correction d'un problème où le NAS ne répondait pas et où les clients de NFS se figeaient lorsque Qtier était soumis à une charge de travail intense.
- Correction d'un problème où les mises à jour automatiques du micrologiciel cessaient de fonctionner après la mise à jour de QTS à 5.2.9.3410.
- Correction d'un problème où les listes déroulantes dans Resource Monitor continuaient à s'étendre si les utilisateurs continuaient à cliquer sur les menus.
- Correction d'un problème où le service SNMP s'éteignait lors de l'interrogation d'OID spécifiques après la mise à jour de QTS vers 5.2.9.3499.
- Correction d'un problème où la fenêtre Gestion du volume affichait la taille/les fichiers/dossiers comme 0 après la mise à jour de QTS à 5.2.10.
- Correction d'un problème où les lecteurs de l'enceinte d'extension TR-004 se réveillaient de manière inattendue même lorsque le NAS n'accédait pas aux données du lecteur.
- Correction d'un problème de traduction allemand dans la fenêtre Gestion du volume.
- Correction d'un problème où un administrateur délégué ne pouvait pas désactiver le compte d'un autre utilisateur.
- Correction d'un problème pour améliorer la stabilité du système lors du transfert de fichiers via SMB.
- Correction d'un problème qui empêchait les utilisateurs d'appliquer le certificat Let's Encrypt dans le Panneau de configuration.
- Correction d'un problème de traduction japonais dans les paramètres WebDAV.
- Correction d'un problème de débordement de tampon pour améliorer la stabilité du système.
- Correction d'un problème où les utilisateurs ne pouvaient pas monter une clé USB externe via NFS après avoir réinséré le lecteur dans QTS 5.2.9.3499.
- Correction d'un problème pour améliorer les vitesses de téléchargement de fichiers de HTTPS.
- Correction d'un problème d'allocation de tampon pour améliorer la stabilité du système sous des charges de travail d'E/S élevées.
QTS 5.2.11.3683 build 20261114 | Notes d'information
Vous pouvez obtenir toutes les notes de version des systèmes d’exploitation QNAP ici
