2026-08-05
source: https://www.qnap.com/fr-fr/release-notes/qts/5.2.10.3577/20260731?ref=nas_product
Applicable Models
- HS-251,HS-251+,S2
- QMiroPlus-201W
- QAI-h1290FX
Important Notes
- Starting from QTS 5.2.10, the following expansion card models are no longer supported : Mustang-200-i7-1T-32G-R10,Mustang-200-i5-1T-32G-R10,Mustang-200-C-8G-R10,Mustang-200
Security Updates
- Applied multiple security updates to further enhance system security.
Fixed Issues
- Fixed an issue where the system sometimes could not connect to an SNMP agent when the NAS had a large number of shared folders.
- Fixed a log management issue in Network & Virtual Switch to improve system stability.
- Fixed an issue where it would take a long time to create a shared folder in a folder that contained an enormous number of files.
- Fixed an issue where users could still retain SSH access even after being removed from the administrator group.
- Fixed an issue in Predictive Migration where removing a spare disk could not trigger a successful rebuild due to an incorrect disk status.
- Fixed an issue where the system would still delete a snapshot marked as permanent during a snapshot cleanup after a snapshot retention period.
- Fixed an issue where users could not unlock an encrypted shared folder whose folder name contained a white space.
- Fixed an issue where Control Panel would take a while to display the hardware information on the TS-832PX.
- Fixed an issue where users could not access the NAS via its IPv6 ULA (Unique Local Address).
- Fixed an issue where users could not operate the 5.2.9.3499 with the IR-004 remote control after updating firmware to 5.2.9.3499.
- Fixed an issue where users could not use HybridMount to mount a remote NAS via WebDAV on a NAS running firmware 5.2.9.3492.
- Fixed an issue in font loading that caused a delay when loading the QTS desktop.
- Fixed an issue where the NFS export entry for an external USB drive was not automatically restored after re-inserting the drive, thus preventing NFS clients from mounting the share.
