QNAP QTS 4.3.3.0210 build 20170606
Mikiya
25 Octobre 2016
440
Une mise à jour passée inaperçue hier pourtant elle corrige quelques trucs importants, voila le changelog :
[Important Notes]
- QTS 4.3.x is the final available firmware update for the following models:
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Enhancements]
Added support for the USB 3.1 PCIe card USB-U31A2P01 on the following NAS models: TVS-463/663/863/863+, TS-563, TS-463U/863U/1263U, TVS-471/671/871, TVS-471U/671U/871U, TVS-682/882/1282, TVS-682T/882/1282T, and TES-1885U/3085U.
[Fixes]
- System logs do not display unexpected errors when users back up files from the NAS to external devices twice using Backup Station.
- Non-admin users in the administrator group can successfully log on to NAS again via SSH.
- Resource Monitor can correctly display CPU and memory usage when users enable version control for Qsync and then synchronize a large number of files.
- Users can directly open the folder of downloaded files when clicking a completed download task in Download Station.
- Users can no longer access the "Homes" folder via FTP when the folder permissions are denied.
- Users can still access the "Multimedia" folder and add media folders after uploading certain folders via File Station.
- Fixed a remote code execution vulnerability in Samba. (CVE-2017-7494)
- Fixed multiple security vulnerabilities regarding input validation and access control.
[Other Changes]
- In this update, data scrubbing is automatically scheduled to run every Sunday at 00:00. Data scrubbing checks the data integrity of all RAID 5 and RAID 6 groups on the NAS. Running this check at least once is recommended. Storage performance might be degraded while data scrubbing is running. You can modify the schedule at "Storage Manager" > "Global Settings" > "Data Scrubbing".
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
- Twonky Server is no longer supported. Use the DLNA Media Server built into QTS as your DLNA server.
- Download Station
Users can now be notified when downloads complete (instead of when download tasks complete).
- Virtualization Station
Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
Pour ma part sur 251+ elle s'est installée sans soucis (mais en manuel, en auto il ne la voyait pas).
[Important Notes]
[Enhancements]
[Fixes]
[Other Changes]
- Download Station
https://eu1.qnap.com/Storage/HS-210TurboNAS/HS-210_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/HS-251/HS-251_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/IS-400/IS-400_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-112TurboNAS/TS-112_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-119TurboNAS/TS-119_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-120TurboNAS/TS-120_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-121TurboNAS/TS-121_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-212TurboNAS/TS-212_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-219TurboNAS/TS-219_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-220TurboNAS/TS-220_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-221TurboNAS/TS-221_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-412TurboNAS/TS-412_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-420TurboNAS/TS-420_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-421TurboNAS/TS-421_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-469U-RP/TS-469U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-470U-RP/TS-470U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-531P/TS-531P_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-563/TS-563_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-869U-RP/TS-869U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-870U-RP/TS-870U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X31/TS-X31_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X31U/TS-X31U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-531X_831X/TS-X31X_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X31XU/TS-X31XU_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X35/TS-X35_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X51/TS-X51_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X51A/TS-X51A_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X51U/TS-X51U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X53/TS-X53_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X53A/TS-X53A_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X53B/TS-X53B_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X53BU/TS-X53BU_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X53S/TS-X53S_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X63U/TS-X63U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X80/TS-X80_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X80U/TS-X80U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X82/TS-X82_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X82S/TS-X82S_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X82U/TS-X82U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X85/TS-X85_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X85U/TS-X85U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TS-X89U/TS-X89U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TVS-X63/TVS-X63_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TVS-X71/TVS-X71_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TVS-X71U/TVS-X71U_20170606-4.3.3.0210.zip
https://eu1.qnap.com/Storage/TVS-X73/TVS-X73_20170606-4.3.3.0210.zip
Merci Mikiya, il y a effectivement de nombreuses informations importantes ! Une mise à jour importante qui est vivement recommandée.
Ah Ah Ah ! Avec Mikiya, vous avez publié à la même heure même minute... l'arrivée ce nouveau firmware. Je vais fusionner les sujets :lol:
Bizarre, j'ai le nouveau firmware qui m'est proposé automatiquement alors que mon NAS n'est pas dans la liste ( cf ma signature pour le modèle )
Je vais attendre un peu, dans le cas où il y a une coucouniette avec cette Maj :-p
P.S : il y avais un soucis avec HBS et le backup sur HDD externe, cette version règle le soucis ? ou on doit attendre une MAJ d'HBS ? Mci
Ishido a dit:
Tu peux developper stp ? je fais des backups hebdo sur un disque externe et je n'ai pas eu de souci avec la version actuelle de HBS ?
Ishido a dit:
Y a déjà ceci qui est résolu, ca ressemble a un de mes tickets. Je verrai demain si y a du mieux pour les backups HDD
Salut Guim, tu peux me dire ce qui est corrigé ? car j'ai pas compris la ligne que tu as quote, en anglais. Merci à toi.
Gravitys On en parle ici ( 3 ème message )
https://www.forum-nas.fr/viewtopic.php?f=19&t=6727&p=45396#p45396
https://forum.qnap.com/viewtopic.php?f=15&t=132060
Dans le changelog, ils disent que des messages inattendus n'apparaissent plus en cas de double backup usb.
Pour ma part, j'avais le backup qui se lancait en double quand je branchait le disque, et j'avais du coup des plantages.
Le support (Qoolbox) m'a fait recréer un nouveau job ce qui a résolu le problème, mais content de voir un fix à ce sujet, il devait y avoir un problème de fond même si on a pas su l'iddentifier.
D'après le topic sur le forum Qnap, cette mise à jour corrige d'autre problèmes (même si c'est pas mis dans le change log) comme c'était promis (correctif qui serait intégré dans la prochaine mise à jour)
https://forum.qnap.com/viewtopic.php?p=619719#p619719
Pour ma part, vendredi c'est jour du backup disque externe donc je vais tester
Ishido a dit:
Tu as testé Guim ?
J'ai pas d'amélioration de vitesse chez moi. C'est sans doute normal (800 000 fichiers à vérifier pour 450 go et USB2.0 :oops: )
Je suppose que ca améliore par contre grandement la vitesse de ceux qui ont des fichiers de 2 Go en moyenne (vu le topic sur le forum officiel)
