QNAP Module Mediainfo
cedart a dit:
J'ai la dernière version de Qffmepg.
Quand je tape la command j'ai un retour prefix : "command not found"
Cédart
[~] # /opt/Qffmpeg/bin/mediainfo --Help
MediaInfo Command line,
MediaInfoLib - v0.7.72
Usage: "MediaInfo [-Options...] FileName1 [Filename2...]"
Options:
--Help, -h
                    Display this help and exit
--Help-Output
                    Display help for Output= option
--Help-AnOption
                    Display help for "AnOption"
--Version
                    Display MediaInfo version and exit
--Full , -f
                    Full information Display (all internal tags)
--Output=HTML
                    Full information Display with HTML tags
--Output=XML
                    Full information Display with XML tags
--Output=...y
                    Template defined information Display
--Info-Parameters
                    Display list of Inform= parameters
--Language=raw
                    Display non-translated unique identifiers (internal text)
--LogFile=...
                    Save the output in the specified file
--BOM
                    Byte order mark for UTF-8 output
--Ssl_CertificateFileName=...
                    File name of the SSL certificate.
                    The default format is "PEM" and can be changed
                    with --Ssl_CertificateFormat.
--Ssl_CertificateFormat=...
                    File format of the SSL certificate.
                    Supported formats are "PEM" and "DER"
--Ssl_PrivateKeyFileName=...
                    File name of the SSL private key.
                    with --Ssl_PrivateKeyFormat.
                    Note: private key with a password is not supported.
--Ssl_PrivateKeyFormat=...
                    File format of the SSL private key.
--Ssl_CertificateAuthorityFileName=...
                    File name of the SSL certificate authorities
                    to verify the peer with.
--Ssl_CertificateAuthorityPath=...
                    Path of the SSL certificate authorities
--Ssl_CertificateRevocationListFileName=...
                    File name of the SSL certificate revocation list.
                    The format is "PEM"
--Ssl_IgnoreSecurity=...
                    Does not verify the authenticity of the peer's certificate
                    Use it at your own risks
--Ssh_PublicKeyFileName=...
                    File name of the SSH private key.
                    Default is $HOME/.ssh/id_rsa.pub or $HOME/.ssh/id_dsa.pub
                    if the HOME environment variable is set, and just
                    "id_rsa.pub" or "id_dsa.pub" in the current directory
                    if HOME is not set.
                    Note: you need to set both public and private key.
--Ssh_PrivateKeyFileName=...
                    Default is $HOME/.ssh/id_rsa or $HOME/.ssh/id_dsa
                    "id_rsa" or "id_dsa" in the current directory
                    if HOME is not set.
--Ssh_KnownHostsFileName=...
                    File name of the known hosts
                    The format is the OpenSSH file format (libssh2)
                    Default is $HOME/.ssh/known_hosts
                    "known_hosts" in the current directory
                    if HOME is not set.
--Ssh_IgnoreSecurity
                    (you don't need to accept the key with ssh first)
Prefix c'est pour dire le répertoire d'installation ;)
merci de ton aide le WE
je vais essayer
J'ai vraiment du mal avec le code... c'est normal au lycée, le club informatique était sur Goupil 286 :D
cédart
j'ai un retour de serveur.
J'aurais du prendre serveur en 2e langue.
[~] # [~] # /opt/Qffmpeg/bin/mediainfo --Help MediaInfo Command line, MediaInfoLib -
v0.7.72 Usage: "MediaInfo [-Options...] FileName1 [Filename2...]" Options: --Help, -
h Display this help and exit --Help-Output Di
splay help for Output= option --Help-AnOption Display help for "A
nOption" --Version Display MediaInfo version and exit --Full , -
f Full information Display (all internal tags) --Output=HTML
Full information Display with HTML tags --Output=XML
Full information Display with XML tags --Output=...y Template
defined information Display --Info-Parameters Display list of In
form= parameters --Language=raw Display non-translated unique id
entifiers (internal text) --LogFile=... Save the output in the sp
ecified file --BOM Byte order mark for UTF-8 output --Ssl_Certif
icateFileName=... File name of the SSL certificate.
The default format is "PEM" and can be changed with --Ssl_
CertificateFormat. --Ssl_CertificateFormat=... File format of the
SSL certificate. Supported formats are "PEM" and "DER" --Ssl_Pri
vateKeyFileName=... File name of the SSL private key.
l_PrivateKeyFormat. Note: private key with a password is not supp
orted. --Ssl_PrivateKeyFormat=... File format of the SSL private
key. Supported formats are "PEM" and "DER" --Ssl_CertificateAutho
rityFileName=... File name of the SSL certificate authorities
to verify the peer with. --Ssl_CertificateAuthorityPath=...
Path of the SSL certificate authorities to verify the
peer with. --Ssl_CertificateRevocationListFileName=... File name
of the SSL certificate revocation list. The format is "PEM" --Ss
l_IgnoreSecurity=... Does not verify the authenticity of the peer
's certificate Use it at your own risks --Ssh_PublicKeyFileName=.
.. File name of the SSH private key. Default
is $HOME/.ssh/id_rsa.pub or $HOME/.ssh/id_dsa.pub if the HOME env
ironment variable is set, and just "id_rsa.pub" or "id_dsa.pub" i
n the current directory if HOME is not set. N
ote: you need to set both public and private key. --Ssh_PrivateKeyFileName=...
File name of the SSH private key. Default is $HOME/
.ssh/id_rsa or $HOME/.ssh/id_dsa if the HOME environment variable
is set, and just "id_rsa" or "id_dsa" in the current directory
if HOME is not set. Note: you need to set both
public and private key. Note: private key with a password is not
supported. --Ssh_KnownHostsFileName=... File name of the known h
osts The format is the OpenSSH file format (libssh2)
Default is $HOME/.ssh/known_hosts if the HOME environment
variable is set, and just "known_hosts" in the current directory
if HOME is not set. --Ssh_IgnoreSecurity Doe
s not verify the authenticity of the peer (you don't need to acce
pt the key with ssh first) Use it at your own risks
juste cette ligne suffira
le reste c'est la sortie quand tu tapes /opt/Qffmpeg/bin/mediainfo --Help (qui te donne les flags de la commande)
8-)
Un Grand MERCI !!
Cela fonctionne.
Merci pour tout ce que tu fais pour les utilisateurs et le temps passé.
Très bon WE.
J'y retourne
Cédart
Je ne sais pas ce que fait cedart, mais j'ai l'impression que son installation est aux petits oignons en terme de vidéo :lol:
Avec plusieurs TO d'images, il faut que j'arrive à valoriser mon fond et le conserver dans de bonne condition.
La prochaine étape c'est le podcast
