QNAP [ MistServer CE ] [ 2.13 ] MistServer is a full-featured, next-generation streaming media toolkit for OTT
QoolBox
Représentant QNAP
2 Janvier 2014
10 754
185
173
51
www.qnap.com
Oui
Source : https://mistserver.org/
Download :
https://www.qnapclub.eu/fr/qpkg/614
About :
MistServer is a full-featured, next-generation streaming media toolkit for OTT (internet streaming)
login : admin / pass : qnap
config and log inside /opt/MistServer
It takes care of all the annoying little problems you come across in media streaming projects, allowing you to focus on what makes your product or service unique. The MistServer software and our accompanying services allow anyone to quickly gain and keep a competitive edge.
MistServer helps you reduce your costs for media streaming by allowing you to leverage our experience and well-tested software toolkit to assist your efforts. You will save time because your team no longer has to solve all the problems associated with media streaming. This includes device compatibility, protocol implementations, and hooking the media delivery into your other systems for monitoring and access control.
Furthermore, our engineering team is available to assist you with all media-related matters, including informing you of other options than just the ones we provide. Because all our services come at a flat monthly fee, you can be sure of receiving honest advice for all situations.
