Source : https://github.com/adrianlopezroche/fdupes
Download :
fdupes (CLI) - MyQNAP
FDUPES is a program for identifying duplicate files residing within specified directories. TIP ME ! Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
www.myqnap.org
Note :
delivered with a WebUi, just launch a scan in /share for duplicate files and export in text file in your Public share (/share/Public/fdupes.output)
fdupes command line is automatically added to NAS $PATH for easy to manage over SSH
Warning : Scan process is very long ... and a big output file may crash the webui results display (just check results file directly within your share)
About :
Usage: fdupes [options] DIRECTORY...
-r --recurse for every directory given follow subdirectories
encountered within
-R --recurse: for each directory given after this option follow
subdirectories encountered within (note the ':' at
the end of the option, manpage for more details)
-s --symlinks follow symlinks
-H --hardlinks normally, when two or more files point to the same
disk area they are treated as non-duplicates; this
option will change this behavior
-n --noempty exclude zero-length files from consideration
-A --nohidden exclude hidden files from consideration
-f --omitfirst omit the first file in each set of matches
-1 --sameline list each set of matches on a single line
-S --size show size of duplicate files
-m --summarize summarize dupe information
-q --quiet hide progress indicator
-d --delete prompt user for files to preserve and delete all
others; important: under particular circumstances,
data may be lost when using this option together
with -s or --symlinks, or when specifying a
particular directory more than once; refer to the
fdupes documentation for additional information
-N --noprompt together with --delete, preserve the first file in
each set of duplicates and delete the rest without
prompting the user
-I --immediate delete duplicates as they are encountered, without
grouping into sets; implies --noprompt
-p --permissions don't consider files with different owner/group or
permission bits as duplicates
-o --order=BY select sort order for output and deleting; by file
modification time (BY='time'; default), status
change time (BY='ctime'), or filename (BY='name')
-i --reverse reverse order while sorting
-v --version display fdupes version
-h --help display this help message
Unless -1 or --sameline is specified, duplicate files are listed
together in groups, each file displayed on a separate line. The
groups are then separated from each other by blank lines.
When -1 or --sameline is specified, spaces and backslash characters (\)
appearing in a filename are preceded by a backslash character. For
instance, "with spaces" becomes "with\ spaces".
When using -d or --delete, care should be taken to insure against
accidental data loss. While no information will be immediately
lost, using this option together with -s or --symlink can lead
to confusing information being presented to the user when prompted
for files to preserve. Specifically, a user could accidentally
preserve a symlink while deleting the file it points to. A similar
problem arises when specifying a particular directory more than
once. All files within that directory will be listed as their own
duplicates, leading to data loss should a user preserve a file
without its "duplicate" (the file itself!).
