QNAP [ Bazarr ] companion application to Sonarr and Radarr. It manages and downloads subtitles
Thanks, I will then do a backup config and reinstall.
Sent from my ONEPLUS A5000 using Tapatalk
Hi QoolBox, a new version has been released: 0.8.4.4. Would you be so kind to update the package?
Also, checking the built in auto update, it gives an error that may be related to the script, package location or permissions:
Message
Job "Update Bazarr from source on Github (trigger: interval[6:00:00], next run at: 2020-05-29 17:32:59 -03)" raised an exception
Exception
Traceback (most recent call last):
 File "/share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/bazarr/../libs/apscheduler/executors/base.py", line 125, in run_job
  retval = job.func(*job.args, **job.kwargs)
 File "/share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/bazarr/check_update.py", line 44, in check_and_apply_update
  g.fetch(\origin\)
 File "/share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/bazarr/../libs/git/cmd.py", line 548, in
  return lambda *args, **kwargs: self._call_process(name, *args, **kwargs)
 File "/share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/bazarr/../libs/git/cmd.py", line 1014, in _call_process
  return self.execute(call, **exec_kwargs)
 File "/share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/bazarr/../libs/git/cmd.py", line 825, in execute
  raise GitCommandError(command, status, stderr_value, stdout_value)
git.exc.GitCommandError: Cmd(\git\) failed due to: exit code(128)
 cmdline: git fetch origin
 stderr: \fatal: \origin\ does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.\
Thank you for your great work!
Hey there, it does not seems to work properly.
I got this error :
je l'ai fais un peu rapido dans le speed... ptet un bug.. pas sur de pouvoir le corrigé avant deux semaines (congés)
Hi, I was able to start new release from SSH command:
[/share/CACHEDEV1_DATA/.qpkg/QBazarr] # sh ./QBazarr.sh start
[/share/CACHEDEV1_DATA/.qpkg/QBazarr] # Bazarr starting...
2020-08-07 16:06:39,000 - root                             (7f5cfff1f700) :  INFO (init:57) - BAZARR installing requirements...
2020-08-07 16:07:10,455 - root                             (7f5cfff1f700) :  INFO (init:61) - BAZARR requirements installed.
2020-08-07 16:07:10,456 - root                             (7f5cfff1f700) :  INFO (init:67) - Bazarr is being restarted...
2020-08-07 16:07:46,793 - root                             (7ff59e86c700) :  INFO (server:38) - BAZARR is started and waiting for request on http://0.0.0.0:6767/
[b]fatal: bad revision 'HEAD'[/b]
Although it does throw some error.
Subsecuent startups (after stopping and killing the remaining processes) did not show the BAZARR installing requirements message.
Hope this helps
Gaudi a dit:
Hope this helps
yes
ca marche merci
foXaCe a dit:
Gaudi a dit:
Hope this helps
yes
ca marche merci
Great to know it helped you!
Pour ma part ca boucle :
25/08/2020 07:21:47|INFO |root |BAZARR requirements installed.|
25/08/2020 07:21:47|INFO |root |Bazarr is being restarted...|
25/08/2020 07:21:51|INFO |root |BAZARR installing requirements...|
2020-08-25 07:25:50,849 - root (7f0d5fe16700) : INFO (init:57) - BAZARR installing requirements...
2020-08-25 07:25:55,655 - root (7f0d5fe16700) : INFO (init:61) - BAZARR requirements installed.
2020-08-25 07:25:55,656 - root (7f0d5fe16700) : INFO (init:67) - Bazarr is being restarted...
Bazarr is restarting...
Thanks for your great work!!
A new version has been released: v0.9.0.3.
Can you please update?
Also, I have notices, and reported in previous posts that Jacket and Sonarr do auto update without issues, but Bazarr does not.
Would it be possible to fix the autoupdate feature in this release.
Error log is:
Message
Job "Update Bazarr from source on Github (trigger: interval[6:00:00], next run at: 2020-09-08 19:39:12 -03)" raised an exception
Exception
  g.fetch(\origin\)
Thank you
Hi @QoolBox, had you got the chance to take a look at the update and error reported?
It will be great to have the autoupdate working. This way every user should be able to update, without the need to update the QPKG package frequently.
Currently it does work for Jacket and Sonarr. I could not test for Radarr as they do not frequently release updates.
Thank you!
Hi, there is a new version released: 0.9.0.4.
Also, have you got the chance to check if the auto update can be fixed.
Error reported is:
Message
Job "Update Bazarr from source on Github (trigger: interval[6:00:00], next run at: 2020-10-05 23:41:28 -03)" raised an exception
Exception
  g.fetch(\origin\)
 stderr: \fatal: unable to access \https://github.com/morpheus65535/bazarr.git/\: error setting certificate verify locations:
 CAfile: /etc/ssl/certs/ca-certificates.crt
 CApath: none\
it is updated
/etc/ssl/certs/ca-certificates.crt seems missing on your NAS
install :
Apache73
Apache74
Qapache
CACert (QPerl)
one of this QPKG will generate /etc/ssl/certs/ca-certificates.crt
QoolBox a dit:
it is updated
install :
Apache73
Apache74
Qapache
CACert (QPerl)
Thanks!!
Is there any other way to generate the certificates?
Via SSH perhaps?
Regards
