QNAP [ Duplicati ] Free backup software to store encrypted backups online
Je viens d'installer Duplicati (Apache85) sur mon TS-869Pro hier soir (j'ai acheté le module Apcahe85 à cette occasion, qui est d'ailleurs lent, je ne sais pas si c'est normal).
Toutefois, l'interface web n'est pas accessible sur le port "8216".
J'ai réinstallé le package plusieurs fois, sans correction.
En le relançant manuellement en SSH, j'ai ces erreurs :
[/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85] # ./DuplicatiDN85.sh start
other ELF already added to QPKG
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-source-tool' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-source-tool.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-server-util' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-server-util.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-service' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-service.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/webroot/ngclient/assets/duplicati-logo.svg' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/webroot/ngclient/assets/duplicati-logo.svg.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-database-tool' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-database-tool.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-sync-tool' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-sync-tool.bin': Bad address
mv: cannot move '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-secret-tool' to '/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-secret-tool.bin': Bad address
Renaming complete.
Copying complete.
/share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-server.bin: error while loading shared libraries: /share/CACHEDEV1_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati-server.bin: cannot open shared object file: No such file or directory
Cela peut expliquer que cela ne fonctionne pas bien.
Par la suite, j'ai installé "DotNET9 SDK" (à cause du nom du package Duplicati), mais pas mieux.
Pourrai-je avoir de l'aide ? :)
J'ai commencé avec HBS et rlocne (via un mount Pcloud) à sauvegarder mon NAS, mais je trouve cela assez hasardeux comme méthode et HSB semble avoir des limites par rapport à mes fichiers.
Je m'oriente vers cette solution, qui j'espère ce sera meilleurs, mais il faudrait qu'elle fonctionne ;).
Bonne journée
Mon
Renaming complete.
Copying complete.
Bonne journée
J'avais oublié, mon QTS est 4.3.4.
Je pense simplement que ton NAS est vraiment trop vieux, la gamme x69 a plus de 10 ans a présent et ce firmware n'est plus maintenu...
Je sais bien qu'il est vieux, et je pense à le changer , mais pour de multiples raison, mais il fonctionne et répond à un besoin de stockage ;).
En tout cas, Apache85 fonctionne. C'est dommages pour ces erreurs de '' move''.
Pourrais-je corriger ? Le faire d'une autre manière ?
Bon, je me répond à moi même.
Au final, même si l'interface web et que tout n'est pas parfait, je suis passé uniquement sur Rclone sur mon TS-869 Pro, en ligne de commande et script.
Même si je dérive dans cette réponse, c'est pour indiquer que mon petit processeur Atom est anémique pour le chiffrement. Je me suis donc fait un sacré cadeaux de fin d'année... Un nouveau NAS QNAP, même si les dimensions de ce dernier ne me convienne pas trop. Mais cela sera du long terme, autant que les 2 autres si possible, voir plus :).
Sans vouloir froisser personne, même si un firmware est "trop vieux", il est encore totalement intéressant de faire durer les anciens systèmes, même s'il faut faire des concessions en fonctionnalités ou en temps.
je viens d'acheter Apache85 afin d'installer Duplicati sur mon NAS Qnap TS-664.
J'utilise le dernier firmware 5.2.9.3451.
J'ai pu installer le paquet Apache85 sans problème, il semble être installé, cependant Duplicati ne fonctionne pas.
L'installation se fait sans problème.
Comment savoir si Apache85 est correctement installé? J'ai vu un fichier test.php dans le dossier /Web/htdocs mais je ne peux l'ouvrir en mettant l'ip du NAS.
Il y a t'il une préconfiguration à faire?
merci d'avance
réponse à moi même. QuFirewall bloquait les connexions sur le NAS sur ces ports là. Après avoir fait une règle d'exception, les applications sont disponibles.
I have purchased Apache81, 83 and 84). Can you PM me Apache82 and Apache85? I can PM you 81, 83 and 84 if it is of any use to you. I am tired of buying it and having to upgrade to fix an app...thanks for your consideration.
Je viens d'acheter Apache85 pour faire fonctionner Duplicati, mais celui-ci ne fonctionne pas. L'adresse IP-NAS:8216 ne renvoi rien.
Voici les lots
[/share/MD0_DATA/.qpkg/DuplicatiDN85] # ./DuplicatiDN85.sh restart
./DuplicatiDN85.sh: line 105: kill: (7384) - No such process
killall: duplicati-server.bin: no process killed
killall: duplicati-server: no process killed
/share/MD0_DATA/.qpkg/DuplicatiDN85/duplicati/duplicati.bin already exists. Skipping renaming and copying.
A serious error occurred in Duplicati: System.Exception: Failed to create, open or upgrade the database.
Error message: Unable to determine database format: Object cannot be cast from DBNull to other types.
 ---> Duplicati.Library.Interface.UserInformationException: Unable to determine database format: Object cannot be cast from DBNull to other types.
 ---> System.InvalidCastException: Object cannot be cast from DBNull to other types.
   at System.DBNull.System.IConvertible.ToInt32(IFormatProvider provider)
   at Duplicati.Library.SQLiteHelper.DatabaseUpgrader.UpgradeDatabase(IDbConnection connection, String sourcefile, String schema, IList`1 versions)
   at Duplicati.Library.SQLiteHelper.DatabaseUpgrader.UpgradeDatabase(IDbConnection connection, String sourcefile, Type eltype)
   at Duplicati.Server.Program.GetDatabaseConnection(IApplicationSettings applicationSettings, Dictionary`2 commandlineOptions, Boolean silentConsole, Boolean changeDbEncryption)
   at Duplicati.Server.Program.Main(IApplicationSettings applicationSettings, String[] _args)
Voici les lots
Je me réponds à moi-même : après une désinstallation - réinstallation le logiciel est tombé en marche !
