QNAP [ TransmissionBT 4 ] most powerful version of the renowned open-source torrent client
QoolBox
Représentant QNAP
2 Janvier 2014
10 803
191
173
52
www.qnap.com
Oui
source : https://github.com/transmission/transmission/
Apache84 : https://www.myqnap.org/product/transmissionbt-4-apache84/
Apache85 : https://www.myqnap.org/product/transmissionbt-4-apache85/
Unlock the ultimate torrenting experience with TransmissionBT 4, the latest and most powerful version of the renowned open-source torrent client. Designed for speed, simplicity, and efficiency, TransmissionBT 4 is the go-to solution for anyone serious about downloading and managing torrents, especially on a QNAP NAS.
Key Features:
  • Lightning-Fast Performance: With enhanced algorithms and optimized code, TransmissionBT 4 ensures rapid download speeds, making torrenting faster and more reliable than ever before.
  • User-Friendly Interface: TransmissionBT 4 boasts a clean and intuitive interface that makes managing your torrent downloads effortless, whether you're a beginner or a seasoned user.
  • Low Resource Usage: TransmissionBT 4 is engineered to be lightweight on your system, minimizing CPU and memory usage while maximizing performance. It's the perfect torrent client for multitasking without slowing down your computer or NAS.
  • Optimized for NAS QNAP: TransmissionBT 4 is fully compatible with QNAP NAS devices, providing a seamless torrenting experience on your network-attached storage. Leverage the power of TransmissionBT 4 on your QNAP NAS to efficiently manage large torrent downloads directly on your storage device.
  • Advanced Torrent Management: Take full control of your torrents with advanced features like selective downloading, bandwidth scheduling, and remote management, all within the easy-to-navigate dashboard of TransmissionBT 4.
  • Cross-Platform Compatibility: Available for Windows, macOS, Linux, and QNAP NAS, TransmissionBT 4 ensures that you can torrent seamlessly across all your devices.
Why Choose TransmissionBT 4 for Torrenting on QNAP NAS? TransmissionBT 4 is not just another torrent client; it's a comprehensive tool designed to make your torrenting experience as smooth and efficient as possible, especially on a QNAP NAS. Whether you're downloading large files or managing multiple torrents simultaneously, TransmissionBT 4 offers the stability, speed, and compatibility you need.
default password : qnap / qnap
config file : /opt/Transmission84/etc/settings.json
Hi Stephane,
I am writing this to strongly warn the community: DO NOT BUY this TransmissionBT 4 package. It is completely broken and a waste of money.
Here is why it is unusable:
  1. Settings are NOT persistent: The app suffers from "amnesia." Every single time the app or the NAS restarts, all configurations are lost. It reverts to factory defaults every time.
  2. Digital Cage / Locked Permissions: You cannot fix this manually because the settings.json file is locked with 0600 permissions. Even as an admin user via SSH/WinSCP, I get "Permission Denied" when trying to edit or even copy the file.
  3. Impossible to bypass: Since the system overrides any permission changes (0777 is refused), there is no way to bypass this flaw. You cannot set a custom download directory (it always resets to /share/Public), and you cannot automate anything.
This is a paid product, yet it prevents the owner from managing their own configuration. It is a major failure in software design. It is not worth the price, as it requires constant manual intervention after every reboot.
Please fix this fundamental flaw or stop selling this package in this state.
Hi Stephane,
Are you talking about https://www.myqnap.org/product/transmissionbt-4/ ?
This isn't the same app as the one in this thread.
Hi,
Is Apache85 package need for this version of Transmission package (v4.1.1)?
Hi yes, you have 2 links, Apache85 and Apache84
Hi, I mean, do I need puchase and install the individual Apache85 package first, and after the transmissionbt-4-apache85 package?
I tried to install only the Transmission package, but it is not worked correctly. I uninstalled it, but now, it has an install/setup issue. It can not start, just it try to download the Apache85 setup/install package from the cloud server, and it can not found it.
Thank you. :)
I think Transmission (stand-alone) will be abandoned; it's easier to use Apache85 for dependency updates and general updates of TransmissionBT.
The package is also lighter with Apache8x versions
Apache85 version: need Apache85 to be installed on NAS; it link the libs from Apache85 directory to TransmissionBT binaries
