hi does Apache84 runs ? Kavita runs under another ELF (forced) due author build with higher libc, not sure 100% working on old TS-469 DeviceHello @QoolBox and @kavitareader
thank you for the Kavita version of Apache 84. I installed it on a QNAP T469 Pro. but when I try to access (localhost:15555) it does not load the UI, got a DNS error, like the port have not loaded the app. Any solution? I've tried to re-install, reboot, and nothing seems to work. Many thanks in advance!
