[Tuto] Installation et Configuration de CrowdSec avec le reverse proxy SWAG
Hello, le voici:
@axionman
Tu utilises des MODs dans ton compose ?
Il semblerait que ce soit un MOD qui ne veuille pas s'installer...
Montre voir ton docker-compose :)
Hello, le voici:
services:
  swag:
    image: lscr.io/linuxserver/swag:latest
    container_name: swag
    network_mode: swag
    cap_add:
      - NET_ADMIN
    environment:
      - PUID=1000
      - PGID=100
      - TZ=Europe/Paris
      - URL=xxxxxxxx.duckdns.org
      - VALIDATION=duckdns
      - SUBDOMAINS=wildcard
      - DUCKDNSTOKEN=xxxxxxxxxxxxx
      - DOCKER_MODS=linuxserver/mods:swag-dashboard|linuxserver/mods:swag-crowdsec
      - CROWDSEC_LAPI_URL=http://crowdsec:8080
    volumes:
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/swag/config:/config
    ports:
      - 743:443
      - 780:80
      - 81:81
    restart: unless-stopped
  crowdsec:
    container_name: crowdsec
    network_mode: swag
    image: crowdsecurity/crowdsec
    environment:
      - COLLECTIONS=crowdsecurity/nginx crowdsecurity/http-cve
      - GID=1000
    depends_on:
      - swag
    volumes:
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/swag/config/log/nginx:/var/log/nginx:ro
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/jellyfin/config/log:/var/log/jellyfin:ro
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/nextcloud/data/nextcloud.log:/var/log/nextcloud.log:ro
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/swag/crowdsec/acquis.yaml:/etc/crowdsec/acquis.yaml
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/swag/crowdsec/database:/var/lib/crowdsec/data/
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/swag/crowdsec/config:/etc/crowdsec/
    security_opt:
      - no-new-privileges=true
  uptime-kuma:
    image: louislam/uptime-kuma:1
    container_name: uptime-kuma
    volumes:
      - /srv/dev-disk-by-uuid-b431f2bc-7c9a-4e47-ab28-a33ec3998809/docker/uptime-kuma-data:/app/data
    dns:
      - 1.0.0.1
      - 1.1.1.1
    ports:
      - 3001:3001 # <Host Port>:<Container Port>
Suite à la dernière mise à jour de SWAG, le problème a disparu et tout fonctionne comme avant.
Merci à tous pour votre aide !
@Eirikr70 le mod maxmind fonctionne chez moi sans souci depuis la dernière MAJ (3.0.0-ls335)
Réactions: MilesTEG et EVO
j'au un doute sur l'emplacement du dossier décrit au tout début du tutorial.
Le dossier crowdsec est dans le dossier swag ou au même niveau ?
Pour moi chaque container doit avoir son propre dossier de configuration.
Le résultat serait le suivant :
/volume1/docker/swag
/volume1/docker/crowdsec
Pourtant à vous lire, dès les premières lignes on se dit qu'on va finir par avoir ce qui suit :
/volume1/docker/swag/crowdsec
Dans mon cas j'ai bien cette config :
C'est mon organisation a ce sujet, mais vous tres bien faire différemment.
Pour l'histoire, j'ai cette organisation car SWAG et Crowdsec font partie du même fichier docker-compose.yml qui est dans /swag , ce qui est le but également de la mise en place ici. On ne re-créer pas un fichier docker-compose mais on édit celui de notre SWAG pour rajouter Crowdsec avec.
Oui voila, c'est juste une histoire d'organisation personnel :) Perso je ne lance pas crowdsec sans swag, les deux sont lié dans le meme conteneur sur le meme bridge
Oui, l'important c'est de bien faire le lien entre Swag et Crowdsec, en créant un agent Crowdsec dans Swag et en vérifiant qu'il est bien actif via cscli bouncers list dans le conteneur Crowdsec. Pour ma part, j'ai aussi mis un agent sur l'hôte, en lien avec le pare-feu.
Finalement après avoir suivi le tuto, j'ai compris que l'un tirait en dépendance l'aute et ainsi de suite.
Donc ta logique d'embarquer crowsec dans swag n'est pas fausse non plus. J'ai préféré collé à ta logique.
Maintenant ou j'en suis ?
ça a l'air de fonctionner, les logs ne me renvoient pas d'erreur, mais mais ...
le dashboard ne fonctionne pas.
Comment je peux savor s'il tourne vraiment ? Je ne sais pas où j'ai pû merder.
Eirikr70, pour ma part c'est ok ;)
docker exec -it cc46e643bbbd cscli bouncers list
Name IP Address Valid Last API pull Type Version Auth Type
bouncer-swag 172.18.0.2 ✔️ 2024-11-28T21:15:41Z crowdsec-nginx-bouncer v1.0.8 api-key
La seule erreur que je vois est la suivante :
swag | nginx: [error] [lua] crowdsec.lua:62: init(): error loading captcha plugin: no recaptcha site key provided, can't use recaptcha
Et le seul point que je ne comprends pas est le suiant :
C'est pas vraimenet une erreur, meme si elle est placé comme telle, c'est plutot un warning, puisque recaptcha n'est pas configuré, alors le module captcha n'est pas chargé. Pas de probleme en soi. J'ai la meme chose puisque je n'utilise pas cela.
Faudra que je m'y penche un jour.
On lui dit que l'adresse de crowdsec est le service "crowdsec", on aurai pu aussi indiquez l'ip interne du conteneur, mais le fait de mettre le nom du service permet d'etre plus générique. C'est pour tous pareil :)
ok compris l'erreur.
C'est dans ton tuto ;) rien de méchant, l'URL est en HTTP sur le port 3000.
Je ferai pareil.
Mais quand le tuto dit que ça doit marcher, alors je test test test ....REFAIS ... jusqu'à tant que ça marche. Si tu corriges ça sauvera du temps certainement pour des nouveaux comme moi.
En tout cas, bravo, je suis content, j'ai échangé mon reverse proxy par défaut de syno par swag, fail2ban et crowdsec.
Je me tate pour aller plus loin avec authelia.
Je pense que je vais surtout préciser que je ne maintien plus la partie Dashboard , elle restera dispo pour "historique" juste avec un spoiler. Mais je pense que ce n'est pas pertinent de l'afficher comme un élément indispensable a Crowdsec.
Réactions: Eirikr70
Je suis parfaitement aligné avec les conseils d' @EVO : le tableau de bord est d'un intérêt limité ou plutôt :LOL: je ne suis même pas arrivé à le configurer ...
Pour ce qui est de cscli bouncers list, ta restitution est bonne. Il faut que tu vérifies (sauf au démarrage du conteneur où ça peut prendre quelques minutes) que l'heure affichée pour "Last API Pull" soit de l'ordre d'une minute avant ton heure d'interrogation (en temps universel). S'il y a un décalage important ou pas d'heure affichée, c'est que tu as un problème.
En tous cas bravo pour ton montage : Crowdsec offre une couche de sécurité vraiment très appréciable.
Si comme moi, vous avez SWAG cassé apres une mise à jour :
1012#1012: failed to load the 'resty.core' module (https://github.com/openresty/lua-resty-core); ensure you are using an OpenResty release from https://openresty.org/en/download.html (reason: /usr/share/lua/common/resty/core/base.lua:24: ngx_http_lua_module 0.10.27 required) in /config/nginx/nginx.conf:98
C'est un probleme avec le mod crowdsec et la maj alpine, re-créer le conteneur SWAG en bloquant la version du mod sur 1.0.8 en attendant une véritable résolution de la part de linuxserver.
linuxserver/mods:swag-crowdsec-1.0.8
Edit : La vrai valeur pour la version semble etre linuxserver/mods:swag-crowdsec-v1.0.8
Réactions: axionman et MilesTEG
Cool, merci pour la solution ;)
Sinon, il me semble avoir vu passer à un moment donné que SWAG pouvait avoir une version off-line des MODs, dans le cas où le net ne fonctionnerait pas pour les télécharger...
Je ne me rappelle plus s'il y avait quelque chose à paramétrer, ni où se trouvait cette info...
