QNAP Any Version of Dolibarr does not install in QNAP TS-233
confeder8
8 Mars 2025
9
I have tired of trying installing all versions of Dolibar in my QNAp NAS TS-233 without success.
It is neither installed from Repo, nor from manual install. Whether I have purchased Apache 8.2.x and 8.3.x as well.
Is any one here to help me on above subject
Now i have installed Apache81 too from MyQnap Store, but still the issue persists. Please someone help me on this, i badly need this application to run on my QNAP NAS TS-233.
x33 are arm_64 , file should be Dolibarr21_82_21.0.0.0_arm_64.qpkg
data file error are generally due to transmission issue on download
here is md5 if you want verify
8c95cd225b5f13671dc4485f34ef0b8c Dolibarr21_82_21.0.0.0_arm_64.qpkg
here is md5 if you want to verify
Thanks a lot for the reply. Shall i install All versions of Apache (ie Apache81, Apache82, Apache83) or the latest version will be back compatible.
Please guide
Regards
Nope. I have failed to install Dolibarr in my NAS. Installing from Repo is running indefinite time and does not install. Manual install always shows "File Format Error.
I have tried withn re-initializing my NAS and after fresh install, same issue persists. I have downloaded several times from Repo and tried manual install but without success.
HDD are in compatibility list, and you use original memories (not sure if you can upgrade it here).
Yes It is not an issue of HDD Compatibility. I have manually uploaded Dolibarr latest from the Dolibarr.org in public directory and installed, it is installing as well working as desired.
but sorry to say - your dolibarr never installed / worked. My Apache81, 82 and 83 purchase is in vein and seems wastage of money.
Also most /none of your App support QnapCloudLink.. so it is all togather a wrong decission to have the Apache Versions.
8 months later ... the QPKG are not intended to be used over Cloudlink. i have no problem here with dolibarr on local network
