Bonjour, je voudrais installer un serveur Synology AD avec acces externe via DNS et nom de domaine OVH, après plusieurs essaie infructueux je me dirige vers votre communauté.
redirection OVH:
Synology directory server:
Message d'erreur resaux local, Administrator:
erreur lorsque je rejoind le domaine avec un autre PC en resaux externe:
log windows du pc externe:
02/27/2025 17:33:13:066 -----------------------------------------------------------------
02/27/2025 17:33:13:066 NetpValidateName: checking to see if 'ASUS-ANTHONY' is valid as type 1 name
02/27/2025 17:33:13:070 NetpCheckNetBiosNameNotInUse for 'ASUS-ANTHONY' [MACHINE] returned 0x0
02/27/2025 17:33:13:070 NetpValidateName: name 'ASUS-ANTHONY' is valid for type 1
02/27/2025 17:33:13:072 -----------------------------------------------------------------
02/27/2025 17:33:13:072 NetpValidateName: checking to see if 'ASUS-Anthony' is valid as type 5 name
02/27/2025 17:33:13:072 NetpValidateName: name 'ASUS-Anthony' is valid for type 5
02/27/2025 17:33:13:074 -----------------------------------------------------------------
02/27/2025 17:33:13:074 NetpValidateName: checking to see if 'actived.radislabs.com' is valid as type 3 name
02/27/2025 17:33:13:074 NetpValidateName: 'actived.radislabs.com' is not a valid NetBIOS domain name: 0x7b
02/27/2025 17:33:13:256 NetpCheckDomainNameIsValid [ Exists ] for 'actived.radislabs.com' returned 0x0
02/27/2025 17:33:13:256 NetpValidateName: name 'actived.radislabs.com' is valid for type 3
02/27/2025 17:33:34:285 -----------------------------------------------------------------
02/27/2025 17:33:34:285 NetpDoDomainJoin
02/27/2025 17:33:34:285 NetpDoDomainJoin: using current computer names
02/27/2025 17:33:34:285 NetpDoDomainJoin: NetpGetComputerNameEx(NetBios) returned 0x0
02/27/2025 17:33:34:285 NetpDoDomainJoin: NetpGetComputerNameEx(DnsHostName) returned 0x0
02/27/2025 17:33:34:285 NetpMachineValidToJoin: 'ASUS-ANTHONY'
02/27/2025 17:33:34:285 OS Version: 10.0
02/27/2025 17:33:34:285 Build number: 26100 (26100.ge_release.240331-1435)
02/27/2025 17:33:34:290 SKU: Windows 11 Professionnel
02/27/2025 17:33:34:290 Architecture: 64-bit (AMD64)
02/27/2025 17:33:34:293 NetpMachineValidToJoin: status: 0x0
02/27/2025 17:33:34:293 NetpJoinDomain
02/27/2025 17:33:34:293 HostName: ASUS-Anthony
02/27/2025 17:33:34:293 NetbiosName: ASUS-ANTHONY
02/27/2025 17:33:34:293 Domain: actived.radislabs.com
02/27/2025 17:33:34:293 MachineAccountOU: (NULL)
02/27/2025 17:33:34:293 Account: actived.radislabs.com\administrator
02/27/2025 17:33:34:293 Options: 0x25
02/27/2025 17:33:34:295 NetpValidateName: checking to see if 'actived.radislabs.com' is valid as type 3 name
02/27/2025 17:33:34:295 NetpValidateName: 'actived.radislabs.com' is not a valid NetBIOS domain name: 0x7b
02/27/2025 17:33:34:357 NetpCheckDomainNameIsValid [ Exists ] for 'actived.radislabs.com' returned 0x0
02/27/2025 17:33:34:357 NetpValidateName: name 'actived.radislabs.com' is valid for type 3
02/27/2025 17:33:34:357 NetpDsGetDcName: trying to find DC in domain 'actived.radislabs.com', flags: 0x40001010
02/27/2025 17:33:34:826 NetpDsGetDcName: failed to find a DC having account 'ASUS-ANTHONY$': 0x525, last error is 0x0
02/27/2025 17:33:34:835 NetpDsGetDcName: status of verifying DNS A record name resolution for 'radis.actived.radislabs.com': 0x0
02/27/2025 17:33:34:835 NetpDsGetDcName: found DC '\\radis.actived.radislabs.com' in the specified domain
02/27/2025 17:33:34:835 NetpJoinDomainOnDs: NetpDsGetDcName returned: 0x0
02/27/2025 17:33:34:835 NetpDisableIDNEncoding: using FQDN actived.radislabs.com from dcinfo
02/27/2025 17:33:34:838 NetpDisableIDNEncoding: DnsDisableIdnEncoding(UNTILREBOOT) on 'actived.radislabs.com' succeeded
02/27/2025 17:33:34:838 NetpJoinDomainOnDs: NetpDisableIDNEncoding returned: 0x0
02/27/2025 17:33:57:071 NetUseAdd to \\radis.actived.radislabs.com\IPC$ returned 64
02/27/2025 17:33:57:071 NetpJoinDomainOnDs: status of connecting to dc '\\radis.actived.radislabs.com': 0x40
02/27/2025 17:33:57:071 NetpJoinDomainOnDs: Function exits with status of: 0x40
02/27/2025 17:33:57:079 NetpResetIDNEncoding: DnsDisableIdnEncoding(RESETALL) on 'actived.radislabs.com' returned 0x0
02/27/2025 17:33:57:079 NetpJoinDomainOnDs: NetpResetIDNEncoding on 'actived.radislabs.com': 0x0
02/27/2025 17:33:57:079 NetpDoDomainJoin: status: 0x40
02/27/2025 17:33:57:083 -----------------------------------------------------------------
02/27/2025 17:33:57:083 NetpDoDomainJoin
02/27/2025 17:33:57:084 NetpDoDomainJoin: using current computer names
02/27/2025 17:33:57:084 NetpDoDomainJoin: NetpGetComputerNameEx(NetBios) returned 0x0
02/27/2025 17:33:57:084 NetpDoDomainJoin: NetpGetComputerNameEx(DnsHostName) returned 0x0
02/27/2025 17:33:57:084 NetpMachineValidToJoin: 'ASUS-ANTHONY'
02/27/2025 17:33:57:084 OS Version: 10.0
02/27/2025 17:33:57:084 Build number: 26100 (26100.ge_release.240331-1435)
02/27/2025 17:33:57:090 SKU: Windows 11 Professionnel
02/27/2025 17:33:57:090 Architecture: 64-bit (AMD64)
02/27/2025 17:33:57:094 NetpMachineValidToJoin: status: 0x0
02/27/2025 17:33:57:094 NetpJoinDomain
02/27/2025 17:33:57:094 HostName: ASUS-Anthony
02/27/2025 17:33:57:094 NetbiosName: ASUS-ANTHONY
02/27/2025 17:33:57:094 Domain: actived.radislabs.com
02/27/2025 17:33:57:094 MachineAccountOU: (NULL)
02/27/2025 17:33:57:094 Account: actived.radislabs.com\administrator
02/27/2025 17:33:57:094 Options: 0x27
02/27/2025 17:33:57:097 NetpValidateName: checking to see if 'actived.radislabs.com' is valid as type 3 name
02/27/2025 17:33:57:097 NetpValidateName: 'actived.radislabs.com' is not a valid NetBIOS domain name: 0x7b
02/27/2025 17:33:57:273 NetpCheckDomainNameIsValid [ Exists ] for 'actived.radislabs.com' returned 0x0
02/27/2025 17:33:57:273 NetpValidateName: name 'actived.radislabs.com' is valid for type 3
02/27/2025 17:33:57:273 NetpDsGetDcName: trying to find DC in domain 'actived.radislabs.com', flags: 0x40001010
02/27/2025 17:33:57:746 NetpDsGetDcName: failed to find a DC having account 'ASUS-ANTHONY$': 0x525, last error is 0x0
02/27/2025 17:33:57:856 NetpDsGetDcName: status of verifying DNS A record name resolution for 'radis.actived.radislabs.com': 0x0
02/27/2025 17:33:57:856 NetpDsGetDcName: found DC '\\radis.actived.radislabs.com' in the specified domain
02/27/2025 17:33:57:856 NetpJoinDomainOnDs: NetpDsGetDcName returned: 0x0
02/27/2025 17:33:57:856 NetpDisableIDNEncoding: using FQDN actived.radislabs.com from dcinfo
02/27/2025 17:33:57:873 NetpDisableIDNEncoding: DnsDisableIdnEncoding(UNTILREBOOT) on 'actived.radislabs.com' succeeded
02/27/2025 17:33:57:873 NetpJoinDomainOnDs: NetpDisableIDNEncoding returned: 0x0
02/27/2025 17:33:57:874 NetUseAdd to \\radis.actived.radislabs.com\IPC$ returned 64
02/27/2025 17:33:57:874 NetpJoinDomainOnDs: status of connecting to dc '\\radis.actived.radislabs.com': 0x40
02/27/2025 17:33:57:874 NetpJoinDomainOnDs: Function exits with status of: 0x40
02/27/2025 17:33:57:881 NetpResetIDNEncoding: DnsDisableIdnEncoding(RESETALL) on 'actived.radislabs.com' returned 0x0
02/27/2025 17:33:57:881 NetpJoinDomainOnDs: NetpResetIDNEncoding on 'actived.radislabs.com': 0x0
02/27/2025 17:33:57:881 NetpDoDomainJoin: status: 0x40
- Domaine principal OVH: radislabs.com il pointe via DDNS/DynHost vers mon ip publique (non fixe) et le syno AD (nom local RADIS).
- Sous domaine pour AD: actived.radislabs.com pointe vers le domaine principal.
- touts les port AD sont ouvert publique sur le server et box de plus le server est en DMZ.
redirection OVH:
