QNAP [ BedRock Connect ] [ 1.19.63.01 ] Join any server IP on Xbox One, Nintendo Switch, and PS4
QoolBox
Représentant QNAP
2 Janvier 2014
10 800
191
173
52
www.qnap.com
Oui
68747470733a2f2f692e696d6775722e636f6d2f48397a567a47542e706e67
Source : https://github.com/Pugmatt/BedrockConnect
Downloadx86, x64, armv7, arm64
Requirement / Setup
QJDK8 as dependency
Listen on port 19132
About
On Minecraft Bedrock Edition, players on Xbox One, Nintendo Switch, and PS4 are limited to playing on 'Featured Servers' approved by Mojang/Microsoft. These players are not able to join servers via an IP/address. This is an issue for me and others, as the server community on Java edition was one of the major parts that made Minecraft what it was, and what also made what the servers that are now considered 'Mojang Server Partners' what they are today. I wanted to fix this, so I made a solution that anyone can setup easily.
BedrockConnect is an easy to use solution for Minecraft Bedrock Edition players on Xbox One, Nintendo Switch, PS4 to join any server IP, while also having access to a serverlist that allows you to manage a list of servers. It doesn't require any downloads, just a few changes to settings.
Here's the final result in action:
Here's tutorials to get it setup yourself. It takes only a few minutes to get setup:
Switch:
Xbox:
PS4: Although this is technically possible, I don't have a PS4 to make a tutorial video on. If anyone has a PS4 and would like to make a tutorial, send me the video and I'll put the link of the video here. :)
Source: https://github.com/Pugmatt/BedrockConnect
Download x86, x64, armv7, arm64
Requirement / Setup
QJDK8 as dependency
About
Switch:
Xbox:
PS4: Although this is technically possible, I don't have a PS4 to make a tutorial video on. If anyone has a PS4 and would like to make a tutorial, send me the video and I'll put the link of the video here.:)
Hi, could someone please tell me how to get to the server console for this?
dont think there is console, but you have a config.yaml to set option into the directory /opt/BedRockConnect
I am trying to disable pvp and enable coordinates. I have tried adding the commands to the server.properties file then stopping and starting the server but nothing seems to work.
For pvp i tried:
pvp=false
