Synology pb avec wordpress suite passage 7.2
  • Auteur du sujet Auteur du sujet math
math
13 Novembre 2019
49
4
23
Suite au passage de dsm en 7.2 je n'accède plus a wordpress (qui lui est passé en de 5.9 en 6.1.1)
j'ai ce message qui pour moi est très peu compréhensible.
Si l'un de vous à une idée...
Fatal error: Cannot redeclare wp_add_global_styles_for_blocks() (previously declared in /volume1/web_packages/wordpress/wp-includes/global-styles-and-settings.php:211) in /volume1/web_packages/wordpress/wp-content/plugins/gutenberg/lib/compat/wordpress-6.1/get-global-styles-and-settings.php on line 11Call Stack: 0.0000 364056 1. {main}() /volume1/web_packages/wordpress/index.php:0 0.0001 364368 2. require('/volume1/web_packages/wordpress/wp-blog-header.php') /volume1/web_packages/wordpress/index.php:17 0.0001 364784 3. require_once('/volume1/web_packages/wordpress/wp-load.php') /volume1/web_packages/wordpress/wp-blog-header.php:13 0.0002 365568 4. require_once('/volume1/web_packages/wordpress/wp-config.php') /volume1/web_packages/wordpress/wp-load.php:50 0.0002 366224 5. require_once('/volume1/web_packages/wordpress/syno-wp-config-custom.php') /volume1/web_packages/wordpress/wp-config.php:82 0.0002 367360 6. require_once('/volume1/web_packages/wordpress/wp-settings.php') /volume1/web_packages/wordpress/syno-wp-config-custom.php:9 0.0209 2103864 7. include_once('/volume1/web_packages/wordpress/wp-content/plugins/gutenberg/gutenberg.php') /volume1/web_packages/wordpress/wp-settings.php:447 0.0209 2103912 8. gutenberg_pre_init() /volume1/web_packages/wordpress/wp-content/plugins/gutenberg/gutenberg.php:20 0.0209 2104216 9. require_once('/volume1/web_packages/wordpress/wp-content/plugins/gutenberg/lib/load.php') /volume1/web_packages/wordpress/wp-content/plugins/gutenberg/gutenberg.php:73
There has been a critical error on this website.
J'ai déjà signaler ici que depuis le passage à DSM 7.2 le serveur web avait subit pas mal de modification :
Tu peux maintenant passer par "Wordpress -docker " directement via web station , mais je suppose que comme moi tu as dû installé wordpress via le centre de paquets ? ma version de Wordpress est également en 6.1.1 , mais mon site ( expérimental) fonctionne tjrs .
Vérifie si tes dossiers sont tjrs au bon endroit
J'ai l'intention de basculer sur la version "docker " de Wordpress d'ici peu , car le pactage de synology accuse souvent un retard dans les mises à jour.
avez vous installé wordpress manuellement, sans passer par les pack, car à priori, c'est le pack qui à foiré lors de la mise à jour
@zypos Du coup, le dossier web, il sert toujours ?
Je ne suis pas spécialiste ; et je n'ai pas eu le temps de décortiquer le nouveau service Web ; mais à priori oui .
Le dossier Web c'est le serveur par défaut tu peux tjrs y mettre des pages web ; d'ailleurs Synology fourni avec les nouveaux NAS une page d'acceuil standard incluse dans ce dossier .
Si tu instale Wordpress via le centre de paquet il se trouve dans : /web_package comme avant .
Si tu installe Wordpress en docker cela doit (je suppose) se trouver dans /web_package/docker
Et si tu instale Wordpress manuellement : je préfère donner ma langue au chat :p
Actuellement je me retrouve avec le serveur web par défaut et le serveur " wordpress" dans le dossier Web_packages/wordpress avec deux nom de domaines différents .
l'install de wordpress se fait sur le dossier web, et l'installation est la même que sur un serveur pro
oui, tu décompresse les fichiers dans le dossiers web ou si tu as plusieurs site, dans un autre répertoire créé sur le dossiers web, ça dépend comment tu gère ton site, si tu as un forum et d'autres choses
comment cela fait très longtemps, je ne me souvient plus quel fichier il faut faire appel pour installer wordpress, mais normalement, si wordpress est installé à la racine du dossier web, pour lancer l'installation, c'est sous ce lien :
tu peut récupérer tes anciennes info de connexion dans wp-config.php
// ** MySQL settings - You can get this info from your web host ** // /** The name of the database for WordPress */ define('DB_NAME','wordpress'); -----> nom de la base de donné /** MySQL database username */ -----> utilisateur créé dans phpmyadmin ou mariadb define('DB_USER','root'); /** MySQL database password */ define('DB_PASSWORD','************'); -----> mot de passe de l'utilisateur de phpmyadmin ou mariadb /** MySQL hostname */ define('DB_HOST', 'localhost:/run/mysqld/mysqld10.sock'); -----> pour utilisation local, c'est marqué dans mariadb /** Database Charset to use in creating database tables. */ define('DB_CHARSET', 'utf8'); /** The Database Collate type. Don't change this if in doubt. */ define('DB_COLLATE', '');
Réactions: zypos
Salut, bizarre le forum ne m'a pas prévenu de vos réponses...
Mes fichiers sont bien présents dans web_package/wordpress
J'ai bien fait l'install via le centre de paquet et moi aussi je voulais changer pour être plus à jour.
J'ai aussi un autre mini site web codé à la main avec mes élèves dans le dossier web.
Pensez vous que je peux installer wordpress dans web/monsite et récupérer les fichiers qui sont dans web_package/wordpress ?
oui, mais il faudra modifier dans le panneau de configuration de wordpress (je ne sais plus où il est) la direction de wordpress (ndd/monsite)
Effectivement j'ai le même souci et je n'arrive pas à trouver de solution :unsure:
J'ai le même message d'erreurs. Je suis actuellement avec mariaDB10, apache 2.4 et avec PHP8.0. J'ai repris les fichiers d'un de mes sites en les mettant dans mon dossier /web. J'ai modifié le wp-config.php avec la nouvelle connections pour maraDB et impossible d'accéder au site.
J'avoue que je débute et je suis un peu paumé avec toutes ces histoires... Si qqn aurait une solution ? :)
