Synology Update DSM 7.1.1-42962 Update 5
MilesTEG
6 Septembre 2020
3 895
927
313
Nouvelle salve de MAJ pour DSM sur nos NAS, avec la version 7.1.1-42962 Update 5 : https://www.synology.com/fr-fr/releaseNote/DSM#7_1
Version en anglais :
Version: 7.1.1-42962 Update 5​
(2023-04-12)
Important notes​
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to update it manually.
    • Your DSM is working fine without having to update. The system evaluates service statuses and system settings to determine whether it needs to update to this version.
  2. Depending on your Synology NAS model, this update will restart the device.
  3. Users of HD6500 can now create a Btrfs volume of up to 1 PB. This update automatically converts existing volumes that use the Btrfs (Peta Volume) file system to Btrfs. However, to create a volume larger than 200 TB, a RAID 6 storage pool and at least 64 GB of system memory are still required.
What’s New​
  1. Updated OpenSSL to version 1.1.1t to fix multiple security vulnerabilities (CVE-2023-0286, CVE-2023-0215, CVE-2022-4450, CVE-2022-4304).
Fixed Issues​
  1. Fixed an issue where users couldn't access DSM via the Bonjour service.
  2. Fixed stability issue of QuickConnect connections.
  3. Fixed an issue where Synology mobile apps remained signed in after users ended all connections following a password change.
  4. Fixed an issue of space reclamation not running according to the set schedule.
  5. Fixed a display issue concerning the notification about incompatible network interface cards.
Remarques :
Version traduite en français :
(2023-04-12)
Notes importantes​
  1. Votre Synology NAS peut ne pas vous informer de cette mise à jour DSM pour les raisons suivantes. Si vous souhaitez mettre à jour votre DSM vers cette version maintenant, veuillez cliquer ici pour le mettre à jour manuellement.
    • Votre DSM fonctionne correctement sans avoir à mettre à jour. Le système évalue les états de service et les paramètres système pour déterminer s’il doit effectuer une mise à jour vers cette version.
  2. Selon votre modèle de Synology NAS, cette mise à jour redémarrera l’appareil.
  3. Les utilisateurs de HD6500 peuvent désormais créer un volume Btrfs allant jusqu’à 1 Po. Cette mise à jour convertit automatiquement les volumes existants qui utilisent le système de fichiers Btrfs (Peta Volume) en Btrfs. Toutefois, pour créer un volume supérieur à 200 To, un pool de stockage RAID 6 et au moins 64 Go de mémoire système sont toujours nécessaires.
Quoi de neuf​
  1. Mise à jour d’OpenSSL vers la version 1.1.1t pour corriger plusieurs vulnérabilités de sécurité (CVE-2023-0286, CVE-2023-0215, CVE-2022-4450, CVE-2022-4304).
Problèmes résolus​
  1. Correction d’un problème où les utilisateurs ne pouvaient pas accéder à DSM via le service Bonjour.
  2. Correction du problème de stabilité des connexions QuickConnect.
  3. Correction d’un problème où les applications mobiles Synology restaient connectées après que les utilisateurs aient mis fin à toutes les connexions suite à un changement de mot de passe.
  4. Correction d’un problème de récupération d’espace qui ne fonctionnait pas selon le calendrier établi.
  5. Correction d’un problème d’affichage concernant la notification concernant les cartes d’interface réseau incompatibles.
Remarques :
Compte tenu des failles touchant OpenSSL, je n'ai pas attendu que le NAS daigne bien vouloir me la proposer, je l'ai fait manuellement.
Pour le moment rien à signaler.
Quelqu'un serait nous dire la version d'OpenSSL utilisée dans DSM6.2 ?
Dans un shell, voir si plusieurs binaires d'openssl sont présents.
Par exemple sur DSM 7.x :
Bash:
type -a openssl
openssl is /bin/openssl
openssl is /usr/bin/openssl
On vérifie s'il s'agit de deux versions distinctes ou non en comparant les inodes. S'ils sont identiques, cela indique un lien dur et donc qu'il n'existe qu'un seul binaire :
Bash:
ls -alhi /bin/openssl
269850 -rwxr-xr-x 1 root root 710K mars   2 04:33 /bin/openssl
ls -alhi /usr/bin/openssl
269850 -rwxr-xr-x 1 root root 710K mars   2 04:33 /usr/bin/openssl
Puis pour afficher la version :
Bash:
openssl version
OpenSSL 1.1.1t  7 Feb 2023
Je possède un Synology ds118 et celui ci ne me propose pas cette update.
Puis je faire cette maj manuellement ou ne suis je pas concerné.
Ai je intérêt à le mettre à jour.
Merci pour l’info.
Pour DSM 6.2.4-25556 Update 6:
openssl version
OpenSSL 1.0.2u-fips  20 Dec 2019
Edit:
Pour SRM 1.3.1-9346 Update 4
openssl version
OpenSSL 1.1.1n  15 Mar 2022
Pour SRM 1.2.5-8227 Update 8
openssl version
Bash:
type -a openssl
Bash:
Bash:
openssl version
Pourquoi il y a deux fichiers identiques pour le binaire openssl ??
Même version et tout...
De
Bonsoir , merci d' avoir fait la traduction de la mise a jour en Francais ,
De rien mais ce n’est pas moi qui ait traduit c’est mon navigateur Edge 😊
Normalement la VF arrive quelques jours après la publication en anglais.
