QNAP [ Unmanic ][ 0.2.3 ] simple tool for optimising your video library to a single format
QoolBox
Représentant QNAP
2 Janvier 2014
10 800
191
173
52
www.qnap.com
Oui
Source : https://github.com/Josh5/unmanic
Download :
Apache80 :
Apache81 : Apache82 :
QPKG integration :
Listen on port 8888
if installed, it use ffmpeg version from Qffmpeg or ffmpeg Static qpkg, if not will use the one installed on your NAS by default
logs/config : /opt/Unmanic/.unmanic
About :
Unmanic provides you with the following main functions:
A scheduler built in to scan your whole library for files that do not conform to your configured video presets. Videos found with incorrect formats are then queued for conversion.
A folder watchdog. When a video file is modified or a new file is added in your library, Unmanic is able to check that video against your configured video presets. Like the first function, if this video is not formatted correctly it is added to a queue for conversion.
A handler to manage multiple file conversion tasks at a time using ffmpeg
A Web UI to easily configure your preferred video presets and monitor the progress of your library conversion.
I've installed UnManic v0.2.3, I have your Apache82 installed. When I launch UnManic it launches to my Nas with port 8888 and says it can't connect. I've stopped all other apps on the NAS, and rebooted the NAS. Still no change, Brave and Firefox are unable to connect to UnManic.
SJ
SJ
Hi which NAS and Fw please ?
please give me the output in SSH for /etc/init.d/UnManic82/UnManic82.sh restart
