Synology Firmware DSM 7.0.1-42218 Update 6
Administreur
2 311
293
(2023-01-04)
Important notes​
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to update it manually.
    • Your DSM is working fine without having to update. The system evaluates service statuses and system settings to determine whether it needs to update to this version.
  2. Depending on your Synology NAS model, this update will restart the device.
  3. AAC-encoded content can be decoded and natively played back by most end devices, such as smartphones, tablets, computers, and smart TVs. Server-side transcoding of AAC-encoded content has been a redundant and resource-consuming process that was removed in DSM 7.0 starting from this version.
  4. When users select Outlook as the system notification service provider, they will need to sign in with OAuth 2.0, which is a safer authentication method. Previously configured Outlook accounts will be migrated to "Custom SMTP server". We strongly recommend re-configuring the settings for authentication to ensure your Outlook account security.
  5. Advanced Media Extensions must be updated to version 1.1.2-0301 to be compatible with this update.
  6. Video Station must be updated to version 3.0.5-2503 to be compatible with this update.
  7. Audio Station must be updated to version 7.0.3-5401 to be compatible with this update.
  8. Media Server must be updated to version 2.0.4-3150 o be compatible with this update.
Compatibility & Installation​
  1. The following drives will be updated automatically to the latest firmware version to fix an unexpected issue that may occur during repair or other read/write operations: HAT5300-4T (firmware version 1401 and 1402), HAT5300-16T (firmware version 1401), HAT5310-8T (firmware version 1401), and HAS5300-16T (firmware version 1401).
Fixed Issues​
  1. Fixed multiple security vulnerabilities. (Synology-SA-22:23)
Notes importantes​
  1. Votre NAS de Synology ne peut pas vous informer de cette mise à jour du DSM pour les raisons suivantes. Si vous souhaitez mettre à jour votre DSM dans cette version, veuillez cliquer ici pour la mettre à jour manuellement.
    • Votre DSM fonctionne bien sans avoir à mettre à jour. Le système évalue les états des services et les paramètres du système pour déterminer s'il doit être mis à jour à cette version.
  2. En fonction de votre modèle de NAS Synology, cette mise à jour redémarre l'appareil.
  3. Le contenu codé par AAC peut être décodé et minimisé de manière native par la plupart des appareils finaux, tels que les smartphones, les tablettes, les ordinateurs et les téléviseurs intelligents. Le transcodage côté serveur du contenu encodé AAC a été un processus redondant et consommateur de ressources qui a été supprimé dans le DSM 7.0 à partir de cette version.
  4. Lorsque les utilisateurs sélectionnent Outlook comme fournisseur de services de notification système, ils devront se connecter avec OAuth 2.0, qui est une méthode d'authentification plus sûre. Les comptes Outlook précédemment configurés seront migrés vers le "serveur SMTP personnalisé". Nous vous recommandons vivement de reconfigurer les paramètres d'authentification pour assurer la sécurité de votre compte Outlook.
  5. Les extensions multimédias avancées doivent être mises à jour dans la version 1.1.2-0301 pour être compatibles avec cette mise à jour.
  6. Video Station doit être mise à jour à la version 3.0.5-2503 pour être compatible avec cette mise à jour.
  7. Audio Station doit être mise à jour vers la version 7.0.3-5401 pour être compatible avec cette mise à jour.
  8. Media Server doit être mis à jour vers la version 2.0.4-3150 o être compatible avec cette mise à jour.
Compatibilité et installation​
  1. Les lecteurs suivants seront automatiquement mis à jour vers la dernière version du micrologiciel pour résoudre un problème inattendu qui pourrait se produire pendant la réparation ou d'autres opérations de lecture/écriture: HAT5300-4T (firmware version 1401 et 1402), HAT5300-16T (firmware version 1401), HAT5310-8T (firmware version 1401) et HAS5300-16T (firmware version 1401).
Problèmes fixes​
  1. Correction de multiples vulnérabilités de sécurité. (Synology-SA-22:23)
Source : https://www.synology.com/fr-fr/releaseNote/DSM
Réactions: maxou56 et MilesTEG
A mettre rapidement à jour pour combler les failles de sécurité, Dommage que l'on ai pas le détail des failles touchant nos NAS révélé pendant cet événement ( le Pwn2Own)
Ha, les bretons 😅 Ils ralentissent même l'internet 😝
PS : j'aime la Bretagne, j'y vais souvent en vacances 😇 Tu es de quel coin @maxou56 ? Je vais souvent dans le Finistère là où j'ai de la famille ;)
  • Haha
Réactions: maxou56
