QNAP 5.0.1.2137 build 20220826 Release Candidate
schwinny
6 Janvier 2018
365
144
108
QTS 5.0.1.2137 build 20220826 Release Candidate
[Applicable Models]
- HS-251+,S2
- QMiroPlus-201W
- Mustang-F100,Mustang-V100,Mustang-200-i7-1T-32G-R10,Mustang-200-i5-1T-32G-R10,Mustang-200-C-8G-R10,Mustang-200
- QBoat Sunny
- QGD-1600P
- QGD-1602P
- QGD-3014-16PT
- TS-453S Pro,TS-853S Pro
- TS-531P
- TS-216,TS-416
- TS-128A,TS-228A,TS-212P3,TS-130,D1 Rev-B
- TS-231P3,TS-431P3
- TS-231P2,TS-431P2
- TS-831X,TS-531X,TS-431X,TS-431X2,TS-431X3,TS-431KX
- TS-431XU,TS-831XU,TS-1231XU,TS-431XU-RP,TS-831XU-RP,TS-1231XU-RP,TS-431XeU
- TS-932X,TS-832X,TS-332X,TS-532X,TS-932PX,TS-832PX
- TS-432XU-RP,TS-432XU,TS-832XU-RP,TS-832XU,TS-1232XU-RP,TS-1232XU,TS-432PXU,TS-432PXU-RP,TS-832PXU,TS-832PXU-RP,TS-1232PXU,TS-1232PXU-RP
- TS-133,TS-233,TS-433
- TS-1635
- TS-1635AX
- TS-435XeU
- TS-231+,TS-431+,TS-131P,TS-231P,TS-431P,TS-131K,TS-231K,TS-431K,D2,D4,D4 Rev-B
- TS-251,TS-451,TS-651,TS-851,TS-451S,TS-251+,TS-451+,TS-351,D2 Pro Rev-B,D4 Pro Rev-B
- TS-251A,TS-451A,D2 Pro,D4 Pro
- TS-251B
- TS-451DeU,TS-453DU,TS-453DU-RP,TS-853DU-RP,TS-1253DU-RP
- TS-451U
- TS-253 Pro,TS-453 Pro,TS-653 Pro,TS-853 Pro,TS-453mini,IS-453S
- TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-253Be,TS-453Be,TS-453BT3
- TS-853BU,TS-853BU-RP,TS-1253BU,TS-1253BU-RP,TS-453BU,TS-453BU-RP
- HS-453DX,TBS-453DX,TS-251D,TS-253D,TS-653D,TS-453D,TS-451D,TS-453Dmini,TS-451D2
- TBS-453A,TS-253A,TS-453A,TS-653A,TS-853A,D6 Pro,D8 Pro
- TS-453U,TS-853U,TS-1253U,TS-453U-RP,TS-853U-RP,TS-1253U-RP,R4
- TVS-463,TVS-663,TVS-863,TVS-863+,TS-563,TS-963X,TS-963N
- TS-463U,TS-463U-RP,TS-863U,TS-863U-RP,TS-1263U,TS-1263U-RP,TS-463XU,TS-463XU-RP,TS-863XU,TS-863XU-RP,TS-1263XU,TS-1263XU-RP
- TS-564,HS-264,TBS-464,TS-262C,TS-462C,TS-264C,TS-464C,TS-364,TS-464,TS-664
- TS-464U,TS-464U-RP,TS-1264U-RP,TS-464eU,TS-864eU,TS-864eU-RP
- TVS-471,TVS-671,TVS-871,TVS-871T
- TVS-871U-RP,TVS-1271U-RP,TVS-471U-RP,TVS-471U,R8
- TVS-672N,TVS-872N,TVS-872X,TVS-672X,TVS-472X,TVS-472XT,TVS-672XT,TVS-872XT
- TVS-872XU,TVS-872XU-RP,TVS-1272XU-RP,TVS-1672XU-RP,TVS-2472XU-RP,TVS-972XU,TVS-972XU-RP
- TVS-473,TVS-673,TVS-873,TVS-473e,TVS-673e,TVS-873e
- TS-h973AX,TS-473A,TS-673A,TS-873A
- TS-873AU,TS-873AU-RP,TS-1273AU-RP,TS-1673AU-RP,TS-873AeU,TS-873AeU-RP
- TS-873U,TS-1273U,TS-1673U,TS-873U-RP,TS-1273U-RP,TS-1673U-RP
- TVS-675
- TVS-h875U,TVS-h875U-RP,TVS-h1275U-RP,TVS-h1675U-RP
- TS-1277,TS-877,TS-677,TS-1677X
- TS-877XU,TS-877XU-RP,TS-1277XU-RP,TS-1677XU-RP,TS-2477XU-RP,TS-977XU-RP,TS-977XU,TS-h1277XU-RP,TS-h977XU-RP,TS-h1677XU-RP,TS-h2477XU-RP
- TS-EC880 Pro,TS-EC1080 Pro,TVS-EC880,TVS-EC1080,TVS-EC1080+
- TS-EC880U,TS-EC1280U,TS-EC1680U,TS-EC2480U R2,TVS-EC1280U-SAS-RP R2,TVS-EC1580MU-SAS-RP R2,TVS-EC1680U-SAS-RP R2,TVS-EC2480U-SAS-RP R2,TS-EC2480U,TS-EC880U R2,TS-EC1280U R2,TS-EC1680U R2,TVS-EC1280U-SAS-RP,TVS-EC1580MU-SAS-RP,TVS-EC1680U-SAS-RP,TVS-EC2480U-SAS-RP,R12,R16,R24
- TVS-682,TVS-882,TVS-1282,TVS-882BR,TVS-882T,TVS-1282T,TVS-682T,TVS-1282T3,TVS-882BRT3
- TVS-1582TU
- TS-883XU,TS-883XU-RP,TS-1283XU-RP,TS-1683XU-RP,TS-983XU,TS-983XU-RP,TS-2483XU-RP,TS-h1283XU-RP,TS-h2483XU-RP,TS-h1683XU-RP
- TS-1685,TS-h886,TS-h686
- TES-3085U,TES-1885U,TS-1886XU-RP,TS-h1886XU-RP,TS-h1886XU-RP R2
- TS-2888X,TVS-h1688X,TVS-h1288X
- TS-h3088XU-RP
- TDS-16489U
- TS-h2490FU,TS-h1090FU
- TS-328,TS-428,TS-230,D2 Rev-B
- TS-551
- TS-473,TS-673,TS-873
- TVS-951X,TVS-951N
- GM-1000,TNS-h1083X,TNS-h1083X (A Side),TNS-h1083X (B Side)
- TS-i410X, TS-410E
- TS-253E,TS-453E
- TS-h1290FX
- TVS-882ST,TVS-882ST3
[Important Notes]
- This is a release candidate for QTS 5.0.1.
- Out-of-the-box QTS 5.0.1 automatically installs security updates by default. Nevertheless, if you update the firmware from QTS 5.0.0 to 5.0.1, QTS will keep your existing firmware update settings. We recommend checking your firmware update settings in Control Panel > Firmware Update.
[Fixed Issues]
- Fixed an issue where NAS startup time would become much longer in QTS 5.0.0.2055 if users disabled system cache for the system volume.
[Known Issues]
- QTS and QuTS hero with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.0.1 or QuTS hero h5.0.1 for the time being.
- Thunderbolt connection between the NAS and Mac sometimes cannot automatically resume after users restart the NAS.
- Users cannot connect to the destination NAS of a Snapshot Replica job if their usernames contain a space.
- After waking up from sleep, the TS-x51 and TS-x53 models cannot detect external drives that do not support sleep mode.
- Network connection issues may occur when users add both 10 GbE ports of the QXG-10G2SF-CX4 network expansion card to a virtual switch.
- Users sometimes cannot switch between different FEC (Forward Error Correction) modes for the QXG-25G2SF-CX6LX network expansion card.
- On some earlier NAS models with ARM processors, heavy I/O operations may cause network connection issues for the QNA-UC5G1T USB-to-Ethernet adapter.
Réactions: FX Cachem
MAJ en cours chez moi ;)
sans soucis de chargement comme sur la beta 2 et 3
a bien bloqué sur 38% pendant un moment (MAJ KERNEL mais c'était un Problem de refresh de mon navigateur) --> refresh --> OK !
redémarrage en cours, je vous tiens au courant si soucis !
Et comment il s'appel ton navigateur ?
SAFARI :)
c une beta ? ou non ?
PAS tout a fait.
voici la définition d'une RC
Une version admissible, généralement désignée par le terme anglais Release Candidate (souvent abrégé en RC), est une version du logiciel qui est, du côté pratique, candidate à être la version « finale » ou « stable » dudit logiciel. Elle est mise à disposition à des fins de « tests de dernière minute » visant à déceler les toutes dernières erreurs subsistant au sein du programme.
Traduction --> SI PAS DE BUG ---> CA SERA LA DEFINITIVE
