Thank you!!
Backup, uninstall, complete reinstall and restore settings (folder /share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/data) did the trick.
After confirming new installation from .qpkg worked fine with old settings I stopped the server and manually updated to v0.9.6beta9. Starting it again from command line performed some updates and ended up working.
Below CLI output:
Below CLI output:
/share/CACHEDEV1_DATA/.qpkg/QBazarr] # ./QBazarr.sh start
fatal: not a git repository (or any parent up to mount point /share)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Requirement already satisfied: pip in /share/CACHEDEV1_DATA/.qpkg/QBazarr/lib/python3.8/site-packages (21.1.2)
WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: https://pip.pypa.io/warnings/venv
Collecting gevent>=21
Downloading gevent-21.1.2-cp38-cp38-manylinux2010_x86_64.whl (6.3 MB)
|████████████████████████████████| 6.3 MB 114 kB/s
Collecting gevent-websocket>=0.10.1
Downloading gevent_websocket-0.10.1-py3-none-any.whl (22 kB)
Requirement already satisfied: lxml>=4.3.0 in /share/CACHEDEV1_DATA/.qpkg/QBazarr/lib/python3.8/site-packages (from -r /share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/requirements.txt (line 3)) (4.4.2)
Requirement already satisfied: numpy>=1.12.0 in /share/CACHEDEV1_DATA/.qpkg/QBazarr/lib/python3.8/site-packages (from -r share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/requirements.txt (line 4)) (1.20.3)
Requirement already satisfied: webrtcvad-wheels>=2.0.10 in /share/CACHEDEV1_DATA/.qpkg/QBazarr/lib/python3.8/site-packages (from -r /share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/requirements.txt (line 5)) (2.0.10.post2)
Collecting greenlet<2.0,>=0.4.17
Downloading greenlet-1.1.0-cp38-cp38-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (164 kB)
|████████████████████████████████| 164 kB 7.5 MB/s
Collecting zope.interface
Downloading zope.interface-5.4.0-cp38-cp38-manylinux2010_x86_64.whl (259 kB)
|████████████████████████████████| 259 kB 7.6 MB/s
Requirement already satisfied: setuptools in /share/CACHEDEV1_DATA/.qpkg/QBazarr/lib/python3.8/site-packages (from gevent>=21->-r /share/CACHEDEV1_DATA/.qpkg/QBazarr/bazarr/requirements.txt (line 1)) (41.2.0)
Collecting zope.event
Downloading zope.event-4.5.0-py2.py3-none-any.whl (6.8 kB)
Installing collected packages: zope.interface, zope.event, greenlet, gevent, gevent-websocket
Attempting uninstall: greenlet
Found existing installation: greenlet 0.4.15
Uninstalling greenlet-0.4.15:
Successfully uninstalled greenlet-0.4.15
Attempting uninstall: gevent
Found existing installation: gevent 1.4.0
Uninstalling gevent-1.4.0:
Successfully uninstalled gevent-1.4.0
Successfully installed gevent-21.1.2 gevent-websocket-0.10.1 greenlet-1.1.0 zope.event-4.5.0 zope.interface-5.4.0
[/share/CACHEDEV1_DATA/.qpkg/QBazarr] # Bazarr starting...
[/share/CACHEDEV1_DATA/.qpkg/QBazarr] # 2021-05-25 16:56:36,599 - root (7f134dc3b7d0) : INFO (signalr_client:45) - BAZARR SignalR client for Sonarr is connected and waiting for events.
2021-05-25 16:56:36,664 - root (7f134dc3b7d0) : INFO (server:37) - BAZARR is started and waiting for request on http://0.0.0.0:6767
2021-05-25 16:56:36,695 - root (7f133540fd00) : INFO (signalr_client:108) - BAZARR SignalR client for Radarr is connected and waiting for events.
