Synology [Tuto] Installation de Speedtest-Tracker en Docker sur un NAS Synology ( docker-compose )
zigzag08 a dit:
en ssh j'ai ça :
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/speedtest/json": dial unix /var/run/docker.sock: connect: permission denied
mais ce ne comprend ce qui ne va pas...
Il faut etre root avant de faire la commande :
Pour passer en root :
sudo su -
autant pour moi! :)
j'ai ça :
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 10-adduser: executing...
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
Brought to you by linuxserver.io
https://www.linuxserver.io/donate/
GID/UID
User uid:    1026
User gid:    100
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 20-config: executing...
[cont-init.d] 20-config: exited 0.
[cont-init.d] 30-keygen: executing...
generating self-signed keys in /config/keys, you can replace these with your own keys if required
Generating a RSA private key
writing new private key to '/config/keys/cert.key'
[cont-init.d] 30-keygen: exited 0.
[cont-init.d] 40-config: executing...
Starting 2019/12/30, GeoIP2 databases require personal license key to download. Please manually download/update the GeoIP2 db and save as /config/geoip2db/GeoLite2-City.mmdb
[cont-init.d] 40-config: exited 0.
[cont-init.d] 50-speedtest: executing...
Ookla GDPR and EULA accepted. Downloading Speedtest CLI.
Connecting to install.speedtest.net (151.101.2.219:443)
saving to 'speedtest.tgz'
speedtest.tgz         21% |******                          |  192k  0:00:03 ETA
speedtest.tgz        100% |********************************|  908k  0:00:00 ETA
'speedtest.tgz' saved
You may only use this Speedtest software and information generated
from it for personal, non-commercial use, through a command line
interface on a personal computer. Your use of this software is subject
to the End User License Agreement, Terms of Use and Privacy Policy at
these URLs:
        https://www.speedtest.net/about/eula
        https://www.speedtest.net/about/terms
        https://www.speedtest.net/about/privacy
License acceptance recorded. Continuing.
Ookla collects certain data through Speedtest that may be considered
personally identifiable, such as your IP address, unique device
identifiers or location. Ookla believes it has a legitimate interest
to share this data with internet providers, hardware manufacturers and
industry regulators to help them understand and create a better and
faster internet. For further information including how the data may be
shared, where the data may be transferred and Ookla's contact details,
please see our Privacy Policy at:
       http://www.speedtest.net/privacy
Copying latest site files to config
Database file not found! Creating empty database
Env file not found! Creating .env file
Running database migrations
Migration table created successfully.
Migrating: 2014_10_12_000000_create_users_table
Migrated:  2014_10_12_000000_create_users_table (0.42 seconds)
Migrating: 2019_08_19_000000_create_failed_jobs_table
Migrated:  2019_08_19_000000_create_failed_jobs_table (0.13 seconds)
Migrating: 2020_04_03_104234_create_email_verifications_table
Migrated:  2020_04_03_104234_create_email_verifications_table (0.11 seconds)
Migrating: 2020_04_03_105113_create_active_sessions_table
Migrated:  2020_04_03_105113_create_active_sessions_table (0.11 seconds)
Migrating: 2020_04_08_120837_create_speedtests_table
Migrated:  2020_04_08_120837_create_speedtests_table (0.09 seconds)
Migrating: 2020_04_08_125647_create_jobs_table
Migrated:  2020_04_08_125647_create_jobs_table (0.18 seconds)
Migrating: 2020_05_18_211812_create_settings_table
Migrated:  2020_05_18_211812_create_settings_table (0.36 seconds)
Migrating: 2020_06_20_164502_update_speedtests_table
Migrated:  2020_06_20_164502_update_speedtests_table (0.27 seconds)
Migrating: 2020_06_21_171849_add_notifications_settings
Migrated:  2020_06_21_171849_add_notifications_settings (0.2 seconds)
Migrating: 2020_06_28_235331_update_speedtests_add_manual_column
Migrated:  2020_06_28_235331_update_speedtests_add_manual_column (0.07 seconds)
Migrating: 2020_07_03_095049_update_speedtest_add_failed_column
Migrated:  2020_07_03_095049_update_speedtest_add_failed_column (0.07 seconds)
Migrating: 2020_07_06_105930_add_graph_settings
Migrated:  2020_07_06_105930_add_graph_settings (0.46 seconds)
Migrating: 2020_07_07_215412_add_notification_agent_settings
Migrated:  2020_07_07_215412_add_notification_agent_settings (0.19 seconds)
Migrating: 2020_08_12_123941_add_healthchecks_settings
Migrated:  2020_08_12_123941_add_healthchecks_settings (0.13 seconds)
Migrating: 2020_08_21_133343_add_authentication_settings
Migrated:  2020_08_21_133343_add_authentication_settings (0.06 seconds)
Migrating: 2020_08_21_204656_add_conditional_notifications_settings
Migrated:  2020_08_21_204656_add_conditional_notifications_settings (0.39 seconds)
Migrating: 2020_08_28_192136_add_show_failed_tests_setting
Migrated:  2020_08_28_192136_add_show_failed_tests_setting (0.09 seconds)
Migrating: 2020_09_10_231121_add_widget_card_settings
Migrated:  2020_09_10_231121_add_widget_card_settings (0.23 seconds)
Migrating: 2020_12_19_211232_add_schedule_enabled_setting
Migrated:  2020_12_19_211232_add_schedule_enabled_setting (0.06 seconds)
Migrating: 2020_12_19_234248_add_app_name_setting
Migrated:  2020_12_19_234248_add_app_name_setting (0.08 seconds)
Migrating: 2020_12_20_001345_add_custom_healthchecks_setting
Migrated:  2020_12_20_001345_add_custom_healthchecks_setting (0.07 seconds)
Generating app key
Application key set successfully.
Generating JWT secret
jwt-auth secret [ouVkXAjjBBglNKDfmOJ3gDbTLKI68f5DCbuc1p5wezM5Zxpn1EvwEAdz8eIyHrd4] set successfully.
Slack webhook is unset
Telegram chat id and bot token unset
Base path is unset
AUTH variable not set. Disabling authentication
Clearing old jobs from queue
[cont-init.d] 50-speedtest: exited 0.
[cont-init.d] 99-custom-files: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-files: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
{"type":"log","timestamp":"2021-08-10T04:05:04Z","message":"Error: [104] Cannot read from socket: Connection reset by peer","level":"error"}
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
using keys found in /config/keys
Database file exists
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-11 09:08:28.490] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-11 09:08:28.490] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-11 09:08:28.490] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-11T07:08:28Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-11 09:08:47.221] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-11 09:08:47.221] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-11 09:08:47.221] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-11T07:08:47Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
{"type":"log","timestamp":"2021-08-11T08:00:11Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-11T08:00:12Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-08-11T10:08:38Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-08-11T13:05:15Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-12T13:00:05Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
[2021-08-13 19:50:29.770] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:50:29.770] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:50:29.770] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:50:29.771] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:50:29Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:51:28.630] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:51:28.630] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:51:28.630] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:51:28.631] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:51:28Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-13 19:52:55.702] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:52:55.702] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:52:55.702] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:52:55.703] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:52:55Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:53:54.686] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:53:54.686] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:53:54.686] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:53:54.687] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:53:54Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[2021-08-13 19:55:25.822] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:55:25.822] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:55:25.822] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:55:25.823] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:55:25Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:56:27.430] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:56:27.430] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:56:27.430] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:56:27.431] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:56:27Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 19:57:45.462] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 19:57:45.462] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 19:57:45.462] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 19:57:45.463] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T17:57:45Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
[2021-08-13 20:00:15.894] [error] Configuration - Couldn't connect to server (Network is unreachable)
[2021-08-13 20:00:15.894] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-13 20:00:15.895] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
[2021-08-13 20:00:15.896] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-13T18:00:15Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
No MaxMind license key found; exiting. Please enter your license key into /etc/conf.d/libmaxminddb
run-parts: /etc/periodic/weekly/libmaxminddb: exit status 1
{"type":"log","timestamp":"2021-08-14T20:00:43Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
{"type":"log","timestamp":"2021-08-15T06:00:07Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-08-15T22:30:07Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
[2021-08-17 20:30:08.331] [error] Configuration - Couldn't resolve host name (HostNotFoundException)
[2021-08-17 20:30:08.331] [error] Configuration - Cannot retrieve configuration document (0)
[2021-08-17 20:30:08.331] [error] ConfigurationError - Could not retrieve or read configuration (Configuration)
{"type":"log","timestamp":"2021-08-17T18:30:08Z","message":"Configuration - Could not retrieve or read configuration (ConfigurationError)","level":"error"}
{"type":"log","timestamp":"2021-08-18T10:30:40Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
{"type":"log","timestamp":"2021-08-20T02:30:04Z","message":"Error: [104] Cannot read from socket: Connection reset by peer","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
wget: bad address 'geolite.maxmind.com'
run-parts: /etc/periodic/monthly/geoip: exit status 1
[2021-09-01 12:00:04.108] [error] Limit reached:
<html>
<head><title>429 Too Many Requests</title></head>
<body>
<center><h1>429 Too Many Requests</h1></center>
<hr><center>openresty</center>
</body>
</html>
[2021-09-01 12:30:02.590] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 13:00:04.163] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 13:30:03.236] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 14:00:03.180] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 14:30:05.045] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 15:00:03.634] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 15:30:03.691] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:00:04.038] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:24:05.590] [error] Limit reached:
<html>
<body>
</body>
</html>
[2021-09-01 16:30:03.730] [error] Limit reached:
<html>
<body>
</body>
</html>
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
[2021-09-01 16:56:30.048] [error] Limit reached:
<html>
<body>
</body>
</html>
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-09-02T11:30:06Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-09-04T11:00:43Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-09-05T23:00:09Z","message":"Error: [110] Cannot open socket: Timeout occurred in connect.","level":"error"}
[fix-attrs.d] done.
usermod: no changes
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
Je te remercie.
J'ai redémarrer et ça fonctionne pour l'instant. On verra combien de temps!
Au prochain bug je réinstallerai tout proprement, au pire ça fera pas de mal.
Ca fait plaisir d'etre aidé, surtout si rapidement, en tant que newbe en docker :plusun:
Je galère depuis plusieurs heures pour installer le docker, ou plutôt, pour avoir des résultats de test autres que les croix rouges :
- créer les répertoires : ok
- installation via docker-compose : ok
- j'arrive à : To accept the message please run speedtest interactively or use the following:
speedtest --accept-license
- j'ai été copier le fichier speedtest trouvé sur :
- je tente un : sudo docker exec -it speedtest bash et j'arrive dans le containeur (root@1XXXXXbb2a78)
- je lance speedtest --accept-license et il répond : bash: speedtest: command not found
- alors je fait : php /config/www/artisan speedtest:eula et (alleluia ???) Acceping EULA
- je relance le containeur (ou pas) mais j'ai toujours des croix rouges
C'est clairement un problème d'acceptation de licence et je ne comprends pas comment lancer la manœuvre dans l'interface DSM
En fait, c'est toujours :
Et je ne trouve pas comment lancer l'instruction speedtest --accept-license
Afin de comprendre un peu mieux, qu'est-ce qui ne marche pas exactement ?
Tu n'arrives pas à avoir accès à l'interface du tout ?
Ou l'interface s'ouvre mais ni les tests manuels ni les tests automatiques ne marche ?
Oui les speedtest manuel fonctionne ?
L'interface c'est ok, mais les test manuels ou automatiques finissent avec une croix rouge comme résultat
Je viens de faire une nouvelle installation sur un autre nas :
Premier test provoqué : croix rouges
Je lance : sudo docker logs speedtest
Réponse : sh: /config/www/app/Bin/speedtest: not found
Je pense que, comme pour l'autre, je n'ai pas le bon fichier "speetest" à aller placer manuellement dans config/www/app/Bin
Merci...
J'arrête le contaneur. Je copie le fichier et je relance
Plus de message disant que le fichier manque, mais :
"To accept the message please run speedtest interactively or use the following:
speedtest --accept-license"
Je lance un : docker exec -it speedtest bash
Puis : speedtest --accept-license et il répond "command not found"
Alors : "php /config/www/artisan speedtest:eula" : réponse "Accepting Eula"
Exit
Mais avec sudo docker logs speedtest j'ai toujours la demande d'approbation, et la croix rouge
Bonjour, de nouveau des problèmes de fonctionnement du docker speedtest tracker... qui est trop bien quand il fonctionne et donc manque quand ce n'est plus le cas!
J'ai 2 mesures sur 3 qui sont avec des croix rouges et les autres sont autour de 0mb, alors qu'en faisant un speedtest direct avec mon mac je suis autour de 60-80Mo...
J'ai sorti les logs suivants :
          _         ()
         | |  ___   _    __
         | | / __| | |  /  \
         | | \__ \ | | | () |
         |_| |___/ |_|  \__/
GID/UID
User uid:    1026
User gid:    100
Env file exists
Updating packages
fetch http://dl-cdn.alpinelinux.org/alpine/v3.13/main/x86_64/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.13/community/x86_64/APKINDEX.tar.gz
OK: 161 MiB in 175 packages
Installing dependencies from lock file (including require-dev)
Verifying lock file contents can be installed on current platform.
Nothing to install, update or remove
Package fzaninotto/faker is abandoned, you should avoid using it. No replacement was suggested.
Generating optimized autoload files
> Illuminate\Foundation\ComposerScripts::postAutoloadDump
> @php artisan package:discover --ansi
Discovered Package: barryvdh/laravel-ide-helper
Discovered Package: facade/ignition
Discovered Package: fideloper/proxy
Discovered Package: fruitcake/laravel-cors
Discovered Package: henrywhitaker3/laravel-actions
Discovered Package: laravel-notification-channels/telegram
Discovered Package: laravel/slack-notification-channel
Discovered Package: laravel/tinker
Discovered Package: laravel/ui
Discovered Package: nesbot/carbon
Discovered Package: nunomaduro/collision
Discovered Package: tymon/jwt-auth
Package manifest generated successfully.
90 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
Nothing to migrate.
App key exists
JWT secret exists
Base path is unset
[cont-init.d] done.
[services.d] done.
{"type":"log","timestamp":"2021-10-22T18:30:06Z","message":"Error: [110] Cannot open socket: Timeout occurred in connect.","level":"error"}
{"type":"log","timestamp":"2021-10-22T19:00:06Z","message":"Error: [110] Cannot open socket: Timeout occurred in connect.","level":"error"}
{"type":"log","timestamp":"2021-10-22T19:00:40Z","message":"Trying to get interface information on non-initialized socket.","level":"error"}
{"type":"log","timestamp":"2021-10-22T20:00:10Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-10-23T00:00:09Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-10-23T12:00:08Z","message":"Error: [11] Cannot read from socket: Resource temporarily unavailable","level":"error"}
{"type":"log","timestamp":"2021-10-24T07:30:07Z","message":"Error: [11] Cannot read: Resource temporarily unavailable","level":"error"}
[fix-attrs.d] done.
usermod: no changes
Avez-vous une idée d'où le problème peut venir?
Merci d'avance!
bonjour à tous,
j ai constaté depuis ce matin une "erreur server 500" lorsque je tente d’accéder au speedtest. J'ai tout effacé et recommencé la procédure décrite dans le tuto mais l'erreur persiste... Est ce un probleme lié à speedtest ou suis-je un cas isolé ?
Merci de votre aide,
cdt
Edit : Bon bah, ca a fonctionné, j'avais oublié tout simplement d'effacer l'ancien repertoire "config".
Réactions: FX Cachem et EVO
Merci pour le tuto ça fonctionne nickel, j'avais simplement une petite interrogation, vers quel serveur sont fait les speedtest et est-ce possible de le modifier ?
Je ne suis pas sur de moi mais je pense que le speedtest fonctionne sur le meme principe que le site, il va donc choisir de lui meme le serveur en fonction du ping ( donc souvent le plus pres de toi géographiquement parlant ).
Dans la description du conteneur, je n'ai pas vu d'options permettant de forcer cela sur un autre serveur.
