Asustor Dialog (Beta)- Mainteneur MulMic - Développeur Thomas E. Dickey
Dami1
Représentant ASUSTOR
23 Décembre 2013
9 417
481
193
www.asustor.com
Oui
Pour contacter l'intégrateur, mainteneur : mueller_michael@mail.ru
site web : https://invisible-island.net/dialog/dialog.html
La flemme de traduire lol. Donc voici le descriptif Anglais ci-dessous
Disponible sur séries NAS AS6, AS70, AS50, AS51, AS61, AS62, AS31, AS32, AS63, AS64, AS52, AS53, AS65, AS71, AS66
Dialog is a program that will let you present a variety of questions or
display messages using dialog boxes from a shell script. These types
of dialog boxes are implemented (though not all are necessarily
compiled into dialog):
buildlist, calendar, checklist, dselect, editbox, form, fselect,
gauge, infobox, inputbox, inputmenu, menu, mixedform,
mixedgauge, msgbox (message), passwordbox, passwordform, pause,
prgbox, programbox, progressbox, radiolist, rangebox, tailbox,
tailboxbg, textbox, timebox, treeview, and yesno (yes/no).
You can put more than one dialog box into a script:
o Use the --and-widget token to force dialog to proceed to the next
dialog unless you have pressed ESC to cancel, or
o Simply add the tokens for the next dialog box, making a chain.
Dialog stops chaining when the return code from a dialog is
nonzero, e.g., Cancel or No (see DIAGNOSTICS).
Some widgets, e.g., checklist, will write text to dialog's output.
Normally that is the standard error, but there are options for changing
this: --output-fd, --stderr and --stdout. No text is written if
the Cancel button (or ESC) is pressed; dialog exits immediately in that
case.
case.
Le flemme de lire lol
Ça a l’air hors sujet, on ferme?
  • Haha
