[ Twonky Official ] [ 8.5.1] DLNA Server [ Trial ]
- Padawan
Re: [ QTwonky ] [ 8.4.2] DLNA Server [ Trial ]
the official one is working for me, and I do have a valid License
Regards Simon
TS-473-32GB QM2-2P QXG-10G1T • TVS-463-16GB QM2-2S10G1TB • TS-459 Pro 2GB • TS-121 •
Network: VM Hub 3.0 <500/35> • UniFi USG Pro4 • UniFi USW-16-150W / USW-8-60W • UniFi CloudKey G2+ • UAP AC Pro / AC Lite • Dell 7050 MFF
- QoolBox
- Représentant de QNAP
- Professionnel : Oui
- Contact :
Strange... i have valid licence purchase for a 6.3 version was working until 8.3...
but cant register anymore when clicking on setting.. tried 3 different account for registration.. i am stuck
- Padawan
Have you tried their own qpkg? does it behave in the same way?
Regards Simon
- QoolBox
- Contact :
yes tried my qpkg and official one.. same also tried change browser
- Padawan
Only thing I can suggest is check you license with https://smartlynx.lynxtechnology.com/user/login.php if it looks ok, then raise a support call with Twonky.
help@twonky.com
help@twonky.com
Regards Simon
- QoolBox
- Contact :
Thanks Simon,
I will check it later
Problem while using the latest Twonky on my QNAP NAS.
Im using QNAP TS-251 with Firmware QTS 4.3.3 and Twonky 8.4.2 x64.
Bevor updating the QNAP Firmware to 4.3.3 i used Twonky since a long time (it runs perfect), now i must use this version an did buy the licence key.
Twonky runs, but when my NAS was rebooted my Twonky lost all settings.
Whats wrong?
What can i do to fix this Problem (other Version?).
Whats wrong?
- QoolBox
- Contact :
Please dont use QTwonky
use TwonkyServerEU from QnapClub Repo
i am not mainting this one anymore
Thank You for your Post, i tried the TwonkyEU version. But the Version there is also not so good. The EUversion has a very high CPU Load after the scanningprocess 99-100% ;-(
Does Twonky 8.3 Working with Qnap firmware 4.3.3 as it currently does work with 4.3.2.
I installed this package on firmware 4.3.2 - TwonkyServerEU_8.3_x86_64.qpkg and it works fine.
Will I need to update the license to Twonly 8.4.2 if I update to firmware 4.3.3 from 4.3.2 ????
Qui est en ligne
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 11 invités
