Forum des NAS
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Modérateur : QoolBox
#100473
Source
: https://github.com/davidnewhall/unpackerr
Download : x86,amd64,arm7,arm64
https://www.qnapclub.eu/fr/qpkg/1073
Integration
Daemon launched on QPKG startup
before use edit /opt/Unpackerr/unpackerr.conf to fit on your need and restart QPKG from Appcenter
About
This application runs as a daemon on your download host. It checks for completed downloads and extracts them so Radarr, Lidarr, Sonarr, and Readarr may import them. There are a handful of options out there for extracting and deleting files after your client downloads them. I just didn't care for any of them, so I wrote my own. I wanted a small single-binary with reasonable logging that can extract downloaded archives and clean up the mess after they've been imported.
Installation
Note: Requires access to your download location. Make sure you set the path variables correctly in the configuration. Even if they're set incorrectly this app makes a best effort attempt to locate your downloads.
Hello tous le monde, J'ai suivi le tuto dans ce l[…]
Oui tout ça est activé mais rien &ag[…]
Ikoula
