Version: 1.2.4-8081 Update 1 (24 septembre 2020) pour RT2600AC MR2200AC RT1900AC
Paradise
5 Février 2020
283
120
83
Important Note
The update will be available for selected regions within the following weeks, although the release time in each region may vary slightly.
Fixed Issues
Fixed the issue where SRM might not work properly when values of QoS were close to those of Internet bandwidth.
Fixed the issue where users might fail to access devices within the same local network via Synology Router's public IP address.
Fixed the issue where SRM might not be updated to the latest version.
Fixed the issue where users might fail to access SRM via L2TP VPN.
Fixed the issue where the Guest Network settings might not be applied properly.
Fixed the issue where devices might fail to connect to Wi-Fi points when devices on the guest network were not allowed to access the local network.
Fixed the issue where the option of center alignment at the Login Style tab might not be available after SRM was updated to version 1.2.4.
Security Updates
Fixed a security vulnerability (Synology-SA-20:22).
Fixed a security vulnerability regarding Qualcomm's lbd service (CVE-2020-11117).
https://www.synology.com/fr-fr/releaseNote/RT2600ac
Download
https://www.synology.com/fr-fr/support/download/RT2600ac#firmware
https://www.synology.com/fr-fr/support/download/MR2200ac#firmware
https://www.synology.com/fr-fr/support/download/RT1900ac#firmware
