Firmware DSM 6.1.4-15217-3- Synology
DSM 6.0, DSM 6.1, DSM 6.2, DSM 7.0...
Répondre
Avatar du membre
Esteban
Grand Maître Jedi
Professionnel : Non
Message par Esteban » 13 déc. 2017 13:29
Version: 6.1.4-15217-3
(2017-12-13)
Important Note
The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
This update will restart your Synology NAS.
Fixed Issues
Fixed multiple security vulnerabilities pertaining to OpenSSL (CVE-2017-3735, CVE-2017-3736, CVE-2017-3737, CVE-2017-3738).
Enhanced the stability of the Apollo Lake platform BIOS.
Fixed an issue with abnormal transfer rates for LUNs when backing up to an external storage device.
Fixed an issue where DSM may shutdown incorrectly when iSCSI Block LUN services are overloaded.
Improved the error handling mechanism for the SSD cache when volumes crash.
Enhanced the stability of the upgrade process for SHA clusters.
Enhanced volume expansion process stability after an improper shutdown.
Enhanced system efficiency for calculating large numbers of user and group privilege settings.
Fixed an issue where Microsoft Office documents may fail to save when Windows 10 Fall Creators Update is installed.
https://usdl.synology.com/download/DSM/ ... k/15217-3/
Via Tapatalk
DS218+ (6.2) 2Gb + 8Gb (CT102464BF186D-1866)
DS215j (6.2) Off Site Backup
Freebox V6 en Bridge - Ubiquiti ERx - Borne AP AC LR - Cams HikVision + Dlink - EATON 800VA
OS des NAS - Base de telechargement Synology - Tuto VPN sur Synology
titis14
Re: DSM 6.1.4-15217 update 3 - Synology
Message par titis14 » 13 déc. 2017 15:51
J'ai fais la mise à jour ce matin elle n'est plus proposé ?
Synology DS216+II + 4Go de ram + 2x WD Red 3To + onduleur Eaton 5S 550
Synology RS814 + 4Go de ram + 4x WD Entreprise 2To + onduleur Nitram elite pro 1500
Avatar du membre
Esteban
Grand Maître Jedi
Professionnel : Non
Message par Esteban » 13 déc. 2017 15:58
C’est bon ... ils l’ont remise
Via Tapatalk
Répondre
Retourner vers « Firmwares DSM »
Qui est en ligne
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 2 invités
