Firmware DSM 6.2.2-24922-2
DSM 6.0, DSM 6.1, DSM 6.2, DSM 7.0...
Répondre
Kriss
Message par Kriss » 04 juil. 2019 18:16
Avatar du membre
Esteban
Grand Maître Jedi
Professionnel : Non
Re: Firmware DSM 6.2.2-24922-2
Message par Esteban » 04 juil. 2019 20:06
En complément :
Version: 6.2.2-24922-2
(2019-07-04)
Important Note
The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
This update will restart your Synology NAS.
In response to Gmail API changes, your DSM needs an update to this version to continue the functionality of sending notifications via Gmail. If you wish to skip this update, or if your Synology product model is not eligible to update to DSM 6.2, please refer to the following article which will guide you through the manual configuration: How to use Gmail SMTP server to send emails for DSM
Fixed Issues
Optimized the repair mechanism of RAID 6.
Enhanced the stability of Btrfs file system.
Enhanced the performance of the scheduled task to automatically empty the recycle bin.
Adjusted Gmail notification authentication mechanism to comply with the new Gmail API.
Fixed the issue where the public sharing link function might not work properly.
Fixed several issues which might result from the defective NVMe SSDs, such as system startup failure.
Fixed the issue where Google Chrome might autofill usernames and passwords into incorrect fields.
Fixed the issue where the encrypted shared folders could not be accessed under certain conditions.
Fixed the issue where the encrypted shared folders could not be mounted properly after system startup.
Fixed the issue where, after the restart of Synology NAS or the configuration of Synology High Availability, the domain service powered by Directory Server for Windows Domain might not work properly.
DS218+ (6.2.2) 2Gb + 8Gb (CT102464BF186D-1866)
DS215j (6.2.2) Off Site Backup
Ubiquiti ERx - Borne AP AC LR - Cams HikVision + Dlink - EATON 800VA
OS des NAS - Base de telechargement Synology - Tuto VPN sur Synology
JujuY
Message par JujuY » 12 juil. 2019 19:43
Un truc bizarre avec les fichiers .PAT, censés correspondre à la version DSM 6.2.2-24922-2
  • Pour un DS216J, disposant de la version DSM 6.2.2-24922, hors réseau Internet, j'obtiens un fichier nommé DSM_DS216j_24922.pat qui présente la même taille de fichier que la version DSM 6.2.2-24922. Lorsque je cherche à faire une installation manuelle, cela n’aboutit pas. Le dernier message est du style "Remarque : Vous ne pouvez pas revenir à une version antérieure de DSM. Le DSM installé doit être plus récent que le DSM actuel"
  • Pour un DS216I+ distant, j'ai voulu vérifier le fichier .PAT. Le téléchargement du fichier DSM_DS216+II_24922.pat est toujours en échec (ne se termine jamais malgré 4 tentatives).
  • Pour un DS918+, j'ai fait la mise à jour en automatique et j'ai bien la version DSM 6.2.2-24922-2, j'ai voulu vérifier le fichier .PAT. Le téléchargement DSM_DS918+_24922.pat est toujours en échec
DS918+ avec 2 x WD Red 10 To + 2 WD Red 4 To en SHR-1 (1 volume 15,7 To), onduleur MGE Ellipse 1000
DS216+II avec 2 x WD Red 10 To en SHR-1 (1 volume 9,1 To), onduleur MGE Protection Center 675 --> backup distant (non fonctionnel pour le moment)
Avatar du membre
Esteban
Grand Maître Jedi
Professionnel : Non
Message par Esteban » 12 juil. 2019 23:17
JujuY a écrit :
12 juil. 2019 19:43
Ca c'est etrange
JujuY a écrit :
12 juil. 2019 19:43
Je viens de le faire... ca marche... https://archive.synology.com/download/D ... k/24922-2/
JujuY a écrit :
12 juil. 2019 19:43
Ca fonctionne aussi...
reessaye pour voir ;o)
yogi_om
Message par yogi_om » 15 juil. 2019 09:50
j'ai eu exactement le même soucis pour le 415 Play... je suis passé par un lien fourni ici pour y accéder
JujuY
Message par JujuY » 18 juil. 2019 08:00
J'ai téléchargé le fichier DSM_DS216j_24922.pat à partir d'un autre PC sur une autre connexion Internet. J'arrive au même échec d'installation manuelle sur le DS216J
Le fichier synology_armada38x_ds216j.pat mis à disposition sur le site ci-dessous présente une taille 10 fois plus faible que le fichier "normal"
Kriss a écrit :
04 juil. 2019 18:16
Nouvelle MAJ : https://archive.synology.com/download/D ... k/24922-2/
J'ai pu téléchargé les fichiers DSM_DS216+II_24922.pat et DSM_DS918+_24922.pat avec succès à partir d'un autre PC sur une autre connexion Internet.
Répondre
Retourner vers « Firmwares DSM »
Qui est en ligne
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 2 invités
