Traduction manuelle:
- Corrige un probleme de volume demonté non proprement lors d'un reboot anormal lors d'une conversion SHR ou d'expension de capacité SHR
- Corrige un probleme de reboot anormal lors de la replication de Snapshot lors d'un grosse charge CPU
- Corrige des petits bugs
Dispo la :
https://archive.synology.com/download/DSM/criticalupdate/update_pack/23824-6/
ersion: 6.2.1-23824-6
(2019-02-19)
Important Note
The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
This update will restart your Synology NAS.
Fixed Issues
Fixed an issue where abnormal reboot while converting SHR type or expanding SHR capacity may cause the storage volume not to be properly mounted.
Fixed an issue where the completion of Snapshot Replication under high load environment may result in abnormal reboot.
Minor bug fixes.
Dispo la :
