[ SheepIT ] [ 5.600.2884 ] A free distributed renderfarm for Blender
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Répondre
Avatar du membre
QoolBox
Représentant de QNAP
Professionnel : Oui
Contact :
Message par QoolBox » 11 mai 2018 19:37
Source : https://www.sheepit-renderfarm.com
Download : x64 (more if requested but dont see the interest to port it on ARM)
https://qnapclub.eu/fr/qpkg/581
HDStation Version: https://qnapclub.eu/fr/qpkg/582
Note :
Dependency : QJDK8
warpper command sheepit added to NAS $PATH to simplify life
example :
Code : Tout sélectionner
[/] # sheepit -ui
Option "-ui" takes an operand
Usage:
--no-systray : Don't use systray
--show-gpu : Print available CUDA devices and exit
--verbose : Display log
--version : Display application version
-cache-dir /tmp/cache : Cache/Working directory. Caution,
everything in it not related to the
render-farm will be removed
-compute-method CPU : CPU: only use cpu, GPU: only use gpu,
CPU_GPU: can use cpu and gpu (not at
the same time) if -gpu is not use it
will not use the gpu
-config VAL : Specify the configuration file
-cores 3 : Number of cores/threads to use for
the render
-extras VAL : Extras data push on the authentication
request
-gpu CUDA_0 : CUDA name of the GPU used for the
render, for example CUDA_0
-login LOGIN : User's login
-memory N : Maximum memory allow to be used by
renderer (in MB)
-password PASSWORD : User's password
-priority N : Set render process priority (19
lowest to -19 highest)
-proxy http://login:password@host:port : URL of the proxy
-rendertime N : Maximum time allow for each frame (in
minute)
-request-time 2:00-8:30,17:00-23:00 : H1:M1-H2:M2,H3:M3-H4:M4 Use the 24h
format. For example to request job
between 2am-8.30am and 5pm-11pm you
should do --request-time 2:00-8:30,17:
00-23:00 Caution, it's the requesting
job time to get a project not the
working time
-server URL : Render-farm server, default https://cl
ient.sheepit-renderfarm.com
-ui VAL : Specify the user interface to use,
default 'swing', available 'oneLine',
'text', 'swing' (graphical)
Example: java com.sheepit.client.standalone.Worker
About :
Collaborative
Instantly become a worker to help other users render.
550 machines are connected on average.
Free
Free registration.
Free project adding.
Free rendering.
User-friendly
Manage your project easily on a web based admin panel.
Real time updates on your projects.
No need to have Blender to help render.
GPU supported
CPU and GPU are supported.
:mrgreen:
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Re: [ SheepIT ] [ 5.600.2884 ] A free distributed renderfarm for Blender
Message par QoolBox » 12 mai 2018 19:40
HDStation version added
Répondre
Retourner vers « Applications tierces »
Qui est en ligne
Utilisateurs parcourant ce forum : Baidu [Spider] et 8 invités
