source : jdownloader.org
Download : x31, x41 ,arm64, x86, x64
https://qnapclub.eu/fr/qpkg/524
Dependency : QJDK8
Note :
On First Install QPKG doesnt start automatically
1 ) be sure to be registered first an account on https://my.jdownloader.org
2 ) Log in SSH with your Putty / Terminal with admin account and type command 'jd2'
after some download and install enter your credential (registered on https://my.jdownloader.org)
basically ---> hit Y when request
the mail adress and your password
once done just close terminal... and Start JDownloader2 QPKG
start managing your JDownloader over https://my.jdownloader.org (you can also hit the open qpkg button will redirect you on the website)
About :
[en] JDownloader is a free, open-source download management tool with a huge community of developers that makes downloading as easy and fast as it should be.
[fr] JDownloader est un outil de gestion de téléchargement gratuit et open-source avec une énorme communauté de développeurs qui rend le téléchargement aussi facile et rapide qu'il devrait l'être.
