Qnap [NZBHydra2 ] [ 5.1.0 ] Usenet meta search
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
source : https://github.com/theotherp/nzbhydra2
Download : x64 and arm64
Apache80 : https://www.myqnap.org/product/nzbhydra2-apache80/
Apache81 : https://www.myqnap.org/product/nzbhydra2-apache81/
Apache82 : https://www.myqnap.org/product/nzbhydra2-apache82/
About :
NZBHydra 2 is a meta search for NZB indexers. It provides easy access to a number of raw and newznab based indexers. You can search all your indexers from one place and use it as indexer source for tools like Sonarr or CouchPotato.
Searches Anizb, BinSearch, NzbIndex and any newznab compatible indexers. Merges all results, filters them by a number of configurable restrictions, recognizes duplicates and returns them all in one place
Add results to nzbget or sabnzbd
Support for all relevant media IDs (IMDB, TMDB, TVDB, TVRage, TVMaze) and conversion between them
Query generation, meaning a query will be generated if only a media ID is provided in the search and the indexer doesn't support the ID or if no results were found
Compatible with Sonarr, Radarr, nzbget, sabnzbd, NZB 360, CouchPotato, Mylar, LL, Sickbeard, Jackett/Cardigann, Watcher, etc.
Search and download history and extensive stats, e.g. indexer response times, download shares, NZB age, etc.
Authentication and multi-user support
RSS support with configurable cache times
Torrent support:
For GUI searches, allowing you to download torrents to a blackhole folder
A separate TORZNAB compatible endpoint for API requests, allowing you to merge multiple trackers
Extensive configurability
Migration of database and settings from v1
Hi,
does somebody else have problems to update the application within the current QPKG?
When updating within the application, the config and backup ist being created but the application won't load after afterwards.
After manually disabling and re-activating the QPKG in the appstore, the version of the application is still the old one.
Best regards
Lenny
2.4.1 was the last working one, where an update worked - some versions before that also had the same problem.
2.5.1 did not work
2.5.2 was just released - will try that now - UPDATE: not working either it looks to be some JAVA error
The updated QPKG updated to 2.5.1 but it won't update to 2.5.2 either, but it fails to download - it is a different error than before
UPDATE 2. The download problem seems to be resolved - seemed to be a github error or so. Nevertheless the update progress is not working. Also when simply restarting the app the app timesout and has to be manually restarted in the appstore. The log is a s follows
Update 3. The App starts after the failed update attempt as follows:
Starting NzbHydra on MNAS01 with PID 13001 (/share/MD0_DATA/.qpkg/NZBHydra2/lib/core-2.5.1-exec.jar started by admin in /share/MD0_DATA/.qpkg/NZBHydra2)
2019-04-16 13:43:39.395  INFO --- [0.0-5076-exec-1] org.nzbhydra.update.UpdateManager        : [Search: 646505, IP: XXX] Starting process to update to v2.5.2
2019-04-16 13:43:49.945  INFO --- [0.0-5076-exec-1] org.nzbhydra.update.UpdateManager        : [Search: 646505, IP: XXX] Creating backup before shutting down
2019-04-16 13:43:49.948  INFO --- [0.0-5076-exec-1] org.nzbhydra.backup.BackupAndRestore     : [Search: 646505, IP: 9XXX] Deleting old backups if any exist
2019-04-16 13:43:49.961  INFO --- [0.0-5076-exec-1] org.nzbhydra.backup.BackupAndRestore     : [Search: 646505, IP: XXXX] Deleting backup file /share/MD0_DATA/.qpkg/NZBHydra2/data/backup/nzbhydra-2019-03-19 07-09-57.zip because it's older than 4 weeks
2019-04-16 13:43:50.073  INFO --- [0.0-5076-exec-1] org.nzbhydra.backup.BackupAndRestore     : [Search: 646505, IP: 9XXX] Creating backup
2019-04-16 13:43:50.074  INFO --- [0.0-5076-exec-1] org.nzbhydra.backup.BackupAndRestore     : [Search: 646505, IP: 9XXXX] Backing up database to /share/MD0_DATA/.qpkg/NZBHydra2/data/backup/nzbhydra-2019-04-16 13-43-50.zip
2019-04-16 13:44:17.928  INFO --- [0.0-5076-exec-1] org.nzbhydra.backup.BackupAndRestore     : [Search: 646505, IP: 9XXXX] Successfully wrote backup to file /share/MD0_DATA/.qpkg/NZBHydra2/data/backup/nzbhydra-2019-04-16 13-43-50.zip
2019-04-16 13:44:17.929  INFO --- [0.0-5076-exec-1] org.nzbhydra.update.UpdateManager        : [Search: 646505, IP: 9XXXXX] Shutting down to let wrapper execute the update
2019-04-16 13:44:18.234  INFO --- [       Thread-6] org.nzbhydra.NzbHydra                    : Shutting down
2019-04-16 13:44:18.308  INFO --- [       Thread-6] com.zaxxer.hikari.HikariDataSource       : HikariPool-1 - Shutdown initiated...
2019-04-16 13:44:28.317  INFO --- [       Thread-6] com.zaxxer.hikari.HikariDataSource       : HikariPool-1 - Shutdown completed.
QoolBox a dit:
updated
if error still persist, may be better to open an issue on the Github Author
thnx.
But it didn't work, I even uninstalled and freschly installed the app. Even there the update or a normal restart is not working....
Really strange.
Can you update without a problem? Version 2.5.5. was just released, maybe you can check, if it updates on your installation.
Anyways best regards and I will hope that somebody will be able to fix the problem (I will contact the github maintainer as well).
Lenny
