Source : https://github.com/dweidenfeld/plexdrive
Download : x86 (fw 4.2.6) / arm64 / x31 /x41 /x19 /x64
https://qnapclub.eu/index.php?act=detail&qpkg_id=505
About :
Plexdrive allows you to mount your Google Drive account as read-only fuse filesystem, with direct delete option on the filesystem.
The project is comparable to projects like rclone, google-drive-ocamlfuse or node-gdrive-fuse, but optimized for media streaming e.g. with plex
Please note that plexdrive doesn't currently support writes (adding new files or modifications), it only supports reading existing files and deletion.
[~] # plexdrive --help
Usage of plexdrive:
--cache-file string
Path the the cache file (default "/share/homes/admin/.plexdrive/cache.bolt")
--chunk-check-threads int
The number of threads to use for checking chunk existence (default 2)
--chunk-load-ahead int
The number of chunks that should be read ahead (default 3)
--chunk-load-threads int
The number of threads to use for downloading chunks (default 2)
--chunk-size string
The size of each chunk that is downloaded (units: B, K, M, G) (default "10M")
-c, --config string
The path to the configuration directory (default "/share/homes/admin/.plexdrive")
-o, --fuse-options string
Fuse mount options (e.g. -fuse-options allow_other,...)
--gid int
Set the mounts GID (-1 = default permissions) (default -1)
--max-chunks int
The maximum number of chunks to be stored on disk (default 8)
--refresh-interval duration
The time to wait till checking for changes (default 1m0s)
--root-node-id string
The ID of the root node to mount (use this for only mount a sub directory) (default "root")
--uid int
Set the mounts UID (-1 = default permissions) (default -1)
--umask value
Override the default file permissions
-v, --verbosity int
Set the log level (0 = error, 1 = warn, 2 = info, 3 = debug, 4 = trace)
--version
Displays program's version information
