Qnap [ Ombi 3 ] [ 3.0.5223 ] Want a Movie or TV Show on Plex or Emby
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
Source : https://github.com/tidusjar/Ombi
Download :
https://qnapclub.eu/fr/qpkg/487
arm-x41 not compatible with TS-531P
arm-x41 require Apache74 as dependency
About :
Here are some of the features Ombi V3 has:
Now working without crashes on Linux.
Lets users request Movies and TV Shows (whether it being the entire series, an entire season, or even single episodes.)
Easily manage your requests
User management system (supports plex.tv, Emby and local accounts)
A landing page that will give you the availability of your Plex/Emby server and also add custom notification text to inform your users of downtime.
Allows your users to get custom notifications!
Secure authentication so you don't have to worry about those script kiddies
Will show if the request is already on plex or even if it's already monitored.
Automatically updates the status of requests when they are available on Plex/Emby
Slick, responsive and mobile friendly UI
Ombi will automatically update itself :)
Very fast system.
Integration
We integrate with the following applications:
Plex Media Server
Emby
Sonarr
Radarr (beta)
DogNzb
Couch Potato
Notifications
Supported notifications:
SMTP Notifications (Email)
Discord
Slack
Pushbullet
Pushover
Mattermost
je suis tout nouveau sur le forum et un vrai débutant en gestion des nas qnap.
jai tenté de faire tourner Ombi 3 sur mon nas , il fonctionne généralement bien,
mais il y a un bug qui a été corrigé dans le github du projet et je n'arrive pas a mettre la main sur les fichiers en question,
https://github.com/tidusjar/Ombi/commit/74def78b7326bd9353f08e217f47f3f2c2923288
j'ai donc plusieurs question,
comment puis je mettre la main sur les dossier d'installation du client de Ombi sur le nas,
(mes recherches en ssh ne mènent a rien).
et comment qts gere les app en général.
merci d'avance pour vos lumières :)
