Qnap [ openSearchServer ] [ 1.5.14.0 ] Open-source Enterprise Grade Search Engine Software
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
source : www.opensearchserver.com
x64 version : www.qoolbox.fr/OpenSearchServer_1.5.14_x86_64.qpkg.zip
x41 version : www.qoolbox.fr/OpenSearchServer_1.5.14_arm-x41.qpkg.zip
Note :
Dependency : QJDK8
Listen on Port 9090
First launch can be long (first init) before access webui
About :
OpenSearchServer is a powerful, enterprise-class, search engine program. Using the web user interface, the crawlers (web, file, database, ...) and the REST/RESTFul API you will be able to integrate quickly and easily advanced full-text search capabilities in your application.
Search functions
Advanced full-text search features
Phonetic search
Advanced boolean search with query language
Clustered results with faceting and collapsing
Filter search using sub-requests (including negative filters)
Geolocation
Spell-checking
Relevance customization
Search suggestion facility (auto-completion)
Indexation
Supports 18 languages
Fields schema with analyzers in each language
Several filters: n-gram, lemmatization, shingle, stripping diacritic from words,…
Automatic language recognition
Named entity recognition
Word synonyms and expression synonyms
Export indexed terms with frequencies
Automatic classification
Document supported
HTML / XHTML
MS Office documents (Word, Excel, Powerpoint, Visio, Publisher)
OpenOffice documents
Adobe PDF (with OCR)
RTF, Plaintext
Audio files metadata (wav, mp3, AIFF, Ogg)
Torrent files
OCR over images
Crawlers
The web crawler for internet, extranet and intranet
The file systems crawler for local and remote files (NFS, SMB/CIFS, FTP, FTPS, SWIFT)
The database crawler for all JDBC databases (MySQL, PostgreSQL, Oracle, SQL Server, …)
Filter inclusion or exclusion with wildcards
Session parameters removal
SQL join and linked files support
Screenshot capture
Sitemap import
General
REST API (XML and JSON)
Monitoring module
Index replication
Scheduler for management of periodic tasks
how much time aprox., it could launch for the first time ??
coz for now it spent an hour and nothing appear !
QoolBox a dit:
mgk21cn a dit:
Hi Which NAS model, which Firmware, which QJDK8 version ?
thanks .. it worked finally after disable upnp port forward in qnapcloud
my nas ts251 qts>3.0 qjdk8
thanks again
