Qnap [ SuiteCRM ] [ 8.2.1.0 ]The open source alternative to SalesForce
 Security
CVE: Pending - XSS Vulnerability
CVE: Pending - Fixed Dependency
CVE: Pending - Fixed stored XSS vulnerability
CVE: Pending - Fixed file check bypass
CVE: Pending - Improved file upload checks
 Bug Fixes
PR: 8642 - Issue: 5107 - Fix Inline edit date/datetime issue
PR: 7999 - Prevent securitygroups mass assign damage
PR: 8571 - Remove duplicate code in users detailviewdefs
PR: 8514 - Implement effective opcache file clearing
PR: 8700 - Various problems in PHPDocs throughout the codebase.
PR: 9068 - Issue: 9067 - Fix the drop down width
PR: 9093 - Add Additional api filter option like
PR: 9090 - User menu alignment
PR: 8570 - Issue: 6051 - Modulebuilder labels edit fixes
PR: 9088 - Update JQuery JS Library to v3.6.0
PR: 9000 - Issue: 8999 - Hardcoded 'by' label in calls
PR: 9035 - Issue: 9034 - Business Hours does not work in non-english languages
PR: 8910 - Update the V8 Api to allow for upload of documents similar to notes
PR: 9010 - Add missing 'view task' label on calendar
PR: 9003 - Issue: 8894 - Add missing label for calendar dashlet
PR: 9032 - Prevent Notice Error During Import
PR: 8206 - Issue: 8182 - Update updateTimeDateFields to handle undefined dates
PR: 9076 - Issue: 9075 - Removing deleted related beans via link
PR: 8988 - Improve upon solution which doesn’t cache incomplete beans
PR: 7884 - Issue: 6800 - Elasticsearch: Elastic index name is hardcoded
PR: 9060 - Project Form action should not be changed if delete is not confirmed
PR: 9059 - Issue: 8676 - New Scheduled Reports does not run
PR: 9079 - Issue: 2645 - Calendar quick create ignores required fields
PR: 9054 - Add missing scheduler label for trimSugarFeeds
PR: 9070 - Fix php compatibility issues
PR: 8974 - Issue: 8956 - Email compose body not shown in detail view
PR: 9096 - Issue: 7772 - Only index ElasticSearch when enabled
PR: 9101 - Fix LangText exception breaking ElasticSearch
PR: 8513 - Issue: 8472 - No or not complete Searchresults using elasticsearch engine
PR: 8981 - Issue: 8916 - Misspelled elasticsearch labels
PR: 9080 - Update config for google/apiclient at composer.json
7.11.9
QoolBox a dit:
 Security
 Bug Fixes
