Source : https://github.com/pymedusa/Medusa
Download :
Apache80 https://www.myqnap.org/product/medusa80/
Apache81 https://www.myqnap.org/product/medusa81/
about :
Automatic Video Library Manager for TV Shows. It watches for new episodes of your favorite shows, and when they are posted it does its magic
Exclusive features
Supports TVMaze and TMDB indexers
Manual search episodes (you choose what to snatch based on all kind of info: provider, seeds, release group)
Manual search for subtitles (useful when subtitle has low score because of typo in filename or alternative title)
Uses 'guessit' library to parse and enrich existing info (more precise than regexes)
Improved Anime shows support
Faster DailySearcher|Backlog|Find propers as we only process new items. Already processed items are discarded.
Option to clean Kodi library when replacing existing files
Better quality explanations and consistent quality code in all threads
See on the fly if your backlogged episodes will be increased/reduced while changing qualities
Postpone Post Processing until Medusa downloads wanted subtitle (useful to only show media if subtitle available)
Clean up any leftover files/folders if media file is deleted
Nightly showupdater updates only the season of the show, which has been updated by the indexer, for tvdb and tmdb.
Features
Kodi/XBMC library updates, poster/banner/fanart downloads, and NFO/TBN generation
Sync your shows with Trakt. Keep shows/episode updated in Trakt watchlist
Configurable automatic episode renaming, sorting, and other processing
Easily see what episodes you're missing, are airing soon, and more
Automatic torrent/nzb searching, downloading, and processing at the qualities you want
Largest list of supported torrent and nzb providers, both public and private
Can notify Kodi, XBMC, Growl, Trakt, Twitter, and more when new episodes are available
Searches TheTVDB.com and AniDB.net for shows, seasons, episodes, and metadata
Episode status management allows for mass failing seasons/episodes to force retrying
DVD Order numbering for returning the results in DVD order instead of Air-By-Date order
Allows you to choose which indexer to have Medusa search its show info from when importing
Automatic XEM Scene Numbering/Naming for seasons/episodes
Available for any platform, uses a simple HTTP interface
Specials and multi-episode torrent/nzb support
Automatic subtitles matching and downloading
Improved failed download handling
DupeKey/DupeScore for NZBGet 12+
Real SSL certificate validation
