Qnap [ Composer ] [ 1.3.2 ] Dependency Management for PHP an Addon for Qapache
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
Source : https://getcomposer.org
Download : http://www.qnapclub.eu/index.php?act=detail&qpkg_id=402
universal with Qapache support : http://www.qoolbox.fr/Composer_1.3.2.qpkg.zip
Dependency :
Qapache
CACert
Note :
install automatically composer to Qapache $PATH (/opt/Qapache/bin/composer) and remove on qpkg stop to keep it up to date
Internet Connection is required to use this qpkg
to let composer find php and be able to be exectued, you need to add Qapache/bin to NAS $PATH
export PATH=/opt/Qapache/bin:$PATH
   ______
  / ____/___  ____ ___  ____  ____  ________  _____
 / /   / __ \/ __ `__ \/ __ \/ __ \/ ___/ _ \/ ___/
/ /___/ /_/ / / / / / / /_/ / /_/ (__  )  __/ /
\____/\____/_/ /_/ /_/ .___/\____/____/\___/_/
                    /_/
Composer version 1.3.2 2017-01-27 18:23:41
Usage:
  command [options] [arguments]
Options:
  -h, --help                     Display this help message
  -q, --quiet                    Do not output any message
  -V, --version                  Display this application version
      --ansi                     Force ANSI output
      --no-ansi                  Disable ANSI output
  -n, --no-interaction           Do not ask any interactive question
      --profile                  Display timing and memory usage information
      --no-plugins               Whether to disable plugins.
  -d, --working-dir=WORKING-DIR  If specified, use the given directory as working directory.
  -v|vv|vvv, --verbose           Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debug
Available commands:
  about           Short information about Composer
  archive         Create an archive of this composer package
  browse          Opens the package's repository URL or homepage in your browser.
  clear-cache     Clears composer's internal package cache.
  clearcache      Clears composer's internal package cache.
  config          Set config options
  create-project  Create new project from a package into given directory.
  depends         Shows which packages cause the given package to be installed
  diagnose        Diagnoses the system to identify common errors.
  dump-autoload   Dumps the autoloader
  dumpautoload    Dumps the autoloader
  exec            Execute a vendored binary/script
  global          Allows running commands in the global composer dir ($COMPOSER_HOME).
  help            Displays help for a command
  home            Opens the package's repository URL or homepage in your browser.
  info            Show information about packages
  init            Creates a basic composer.json file in current directory.
  install         Installs the project dependencies from the composer.lock file if present, or falls back on the composer.json.
  licenses        Show information about licenses of dependencies
  list            Lists commands
  outdated        Shows a list of installed packages that have updates available, including their latest version.
  prohibits       Shows which packages prevent the given package from being installed
  remove          Removes a package from the require or require-dev
  require         Adds required packages to your composer.json and installs them
  run-script      Run the scripts defined in composer.json.
  search          Search for packages
  self-update     Updates composer.phar to the latest version.
  selfupdate      Updates composer.phar to the latest version.
  show            Show information about packages
  status          Show a list of locally modified packages
  suggests        Show package suggestions
  update          Updates your dependencies to the latest version according to composer.json, and updates the composer.lock file.
  validate        Validates a composer.json and composer.lock
  why             Shows which packages cause the given package to be installed
  why-not         Shows which packages prevent the given package from being installed
About
Composer is a tool for dependency management in PHP. It allows you to declare the libraries your project depends on and it will manage (install/update) them for you.
Dependency management
Composer is not a package manager in the same sense as Yum or Apt are. Yes, it deals with "packages" or libraries, but it manages them on a per-project basis, installing them in a directory (e.g. vendor) inside your project. By default it does not install anything globally. Thus, it is a dependency manager. It does however support a "global" project for convenience via the global command.
This idea is not new and Composer is strongly inspired by node's npm and ruby's bundler.
Suppose:
You have a project that depends on a number of libraries.
Some of those libraries depend on other libraries.
Composer:
Enables you to declare the libraries you depend on.
Finds out which versions of which packages can and need to be installed, and installs them (meaning it downloads them into your project).
