Qnap [ NextCloud ] [ 21.0.4 ] OwnCloud Fork
Re, Désolé, j'ai encore un problème...
Je ne suis vraiment pas doué en résolution de problème.
Alors j'ai voulu mettre à jour vers Nextcloud 21.0.1, j'étais en 21.0.0.
Par l'interface graphique, j'avais une erreur. Je suis donc passé par occ upgrade en ligne de commande.
Et voici ce que j'obtiens comme erreur :
Starting code integrity check...
An unhandled exception has been thrown:
TypeError: json_decode() expects parameter 1 to be string, bool given in /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/IntegrityCheck/Checker.php:447
Stack trace:
#0 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/IntegrityCheck/Checker.php(447): json_decode()
#1 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/IntegrityCheck/Checker.php(459): OC\IntegrityCheck\Checker->getResults()
#2 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/IntegrityCheck/Checker.php(531): OC\IntegrityCheck\Checker->storeResults()
#3 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/IntegrityCheck/Checker.php(606): OC\IntegrityCheck\Checker->verifyAppSignature()
#4 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/Updater.php(288): OC\IntegrityCheck\Checker->runInstanceVerification()
#5 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/Updater.php(132): OC\Updater->doUpgrade()
#6 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/core/Command/Upgrade.php(255): OC\Updater->upgrade()
#7 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/3rdparty/symfony/console/Command/Command.php(255): OC\Core\Command\Upgrade->execute()
#8 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/3rdparty/symfony/console/Application.php(1009): Symfony\Component\Console\Command\Command->run()
#9 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/3rdparty/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand()
#10 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/3rdparty/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun()
#11 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run()
#12 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/console.php(100): OC\Console\Application->run()
#13 /share/CACHEDEV1_DATA/.qpkg/NextCloud74/nextcloud/occ(11): require_once('/share/CACHEDEV...')
#14 {main}[/opt/NextCloud74/nextcloud] #
Je suis en Apache74 + Nextcloud74 sur un QNAP TS453A à jour.
Merci pour votre aide
Désolé pour le temps de réponse !
La désinstallation/réinstallation a fonctionné, j’espère que ça fonctionnera à la prochaine mise à jour.
Merci (une nouvelle fois) pour ton aide
Bonne soirée
