Qnap [ Apache Nifi ] [ 1.19.1 ] easy to use, powerful, and reliable system to process and distribute data
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
Source : https://nifi.apache.org/index.html
Download :
Dependency :
QJDK8
Note :
unzip, install within AppCenter
First launch can be long to make Webui Display (port 8780/nifi)
About :
Apache nifi supports powerful and scalable directed graphs of data routing, transformation, and system mediation logic. Some of the high-level capabilities and objectives of Apache NiFi include:
Web-based user interface
Seamless experience between design, control, feedback, and monitoring
Highly configurable
Loss tolerant vs guaranteed delivery
Low latency vs high throughput
Dynamic prioritization
Flow can be modified at runtime
Back pressure
Data Provenance
Track dataflow from beginning to end
Designed for extension
Build your own processors and more
Enables rapid development and effective testing
Secure
SSL, SSH, HTTPS, encrypted content, etc...
Pluggable role-based authentication/authorization
Credentials are generated on first install, inside logs
browse logs /opt/Nifi/logs/nifi-app.log (consider browsing with winscp easier way)
and search for :
Generated username
Generated password
should present like this
Generated Username [5cf8d1eb-6993-438f-b267-73f46396e285]
Generated Password [rFunbv13Fung2XKXwCpjFd+EckmZcNkB]
since this application is really heavy, it may takes several minutes to start and get webUI display
Thank you for this, I am learning Nifi and it's nice to have it available one-click :-D
If it's possible to add the update to version 1.40 to the long list of requests, I would appreciate it. Thank you!
