[ RainLoop ] [ 1.12.1.0 ] SIMPLE, MODERN & FAST WEB-BASED EMAIL CLIEN
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Avatar du membre
QoolBox
Représentant de QNAP
Professionnel : Oui
Contact :
Message par QoolBox » 19 févr. 2016 17:18
Source : http://www.rainloop.net
https://qnapclub.eu/fr/qpkg/274
Note :
To access admin panel, use URL of the following kind: http://NAS_IP/RainLoop/?admin
Default login is "admin", password is "12345".
FEATURES
Modern user interface.
Complete support of IMAP and SMTP protocols including SSL and STARTTLS.
Sieve scripts (Filters and vacation message).
Minimalistic resources requirements.
Direct access to mail server is used (mails are not stored locally on web server).
Allows for adding multiple accounts to primary one, simultaneous access to different accounts in different browser tabs is supported. Additional identities.
Administrative panel for configuring main options.
Really simple installation and update (the product is updated from admin panel).
Integration with Facebook, Google, Twitter and Dropbox.
Managing folders list.
Simple look'n'feel customization.
Configurable multi-level caching system.
Extending functionality with plugins installed through admin panel.
Perfect rendering of complex HTML mails.
Drag'n'drop for mails and attachments.
Keyboard shortcuts support.
Autocompletion of e-mail addresses.
Modifié en dernier par QoolBox le 02 sept. 2018 15:50, modifié 9 fois.
Tryphon
Re: [ RainLoop ] [ 1.9.4.398 ] SIMPLE, MODERN & FAST WEB-BASED EMAIL CLIENT
Message par Tryphon » 19 févr. 2016 19:29
Je prends !
Merci beaucoup, très sympa.
Les fiches contact sont trop minimalistes mais j'ai cru comprendre que l'équipe RainLoop proposera mieux prochainement.
TS-559, TS653 8Go, NMP1000
DualBoot
Message par DualBoot » 20 févr. 2016 09:00
Je connaissais un peu Rainloop, intéressant de pouvoir le tester sure NAS.
Sent from my GT-N8000 using Tapatalk
Synology DS 213j - 2 * 2To WD Red | QNAP TS-253 Pro - 2 * 4To WD Red - 8GB
giopas
Maître Jedi
Professionnel : Non
Message par giopas » 21 févr. 2016 17:07
Est-ce qu'il serait possible de l'utiliser pour accéder à gmail? Est-ce que dans ce cas il faudrait tjrs utiliser une connection SSL?
Sent from my A0001 using Tapatalk
Qnap TS-253Pro 16Gb RAM - Single Storage Pool: 2 wred 4TB (RAID 1)
Qnap TS-453A 16Gb RAM - Single Storage Pool: 4 wred 4TB (RAID 5)
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Message par QoolBox » 21 févr. 2016 17:16
giopas a écrit :Est-ce qu'il serait possible de l'utiliser pour accéder à gmail? Est-ce que dans ce cas il faudrait tjrs utiliser une connection SSL?
je pense que oui et également utiliser SSL
giopas
Maître Jedi
Professionnel : Non
Message par giopas » 21 févr. 2016 17:25
Mon problème serait comme d'hab de devoir uniquement utiliser la porte 80 avec un reverse proxy en http...
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Message par QoolBox » 21 févr. 2016 18:27
je ne le fait pas écouter sur un port lambda, il écoute par défaut sur 80 ou 8080/RainLoop ;)
j'ai pensé à toi, tu as vu :mrgreen:
giopas
Maître Jedi
Professionnel : Non
Message par giopas » 21 févr. 2016 19:41
Excellent, 1000 kudos!! :-)
giopas
Maître Jedi
Professionnel : Non
Message par giopas » 22 févr. 2016 11:45
Merci, j'ai configuré gmail, ainsi je peux lire/écrire les nouveaux émails privés même derrière un corporate firewall ;-)
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Message par QoolBox » 22 févr. 2016 12:15
de la bombe :mrgreen:
Répondre
Retourner vers « Applications tierces »
Qui est en ligne
Utilisateurs parcourant ce forum : Google [Bot] et 4 invités
