Qnap [ QPyload ] [ 0.4.9 ] [Git 180305] Download Manager Embedded Version
Normalement cela devrai ressembler a ca :
816	13.03.2018 13:05:02	INFO	Added package Fire-pyLoad containing 1 links
817	13.03.2018 13:05:02	INFO	Download starts: https://uptobox.com/qqa4dd82m94k
818	13.03.2018 13:05:02	WARNING	HOSTER UptoboxCom[15]: Plugin may be unstable
819	13.03.2018 13:05:02	INFO	ACCOUNT UptoboxCom: Relogin user `cel*******`...
820	13.03.2018 13:05:03	INFO	ACCOUNT UptoboxCom: Grabbing account info for user `cel*******`...
821	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Grabbing link info...
822	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Link name: calcul EFFECTIF vierge modele22.xlsm
823	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Link size: 73.51 KiB (75274 bytes)
824	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Link status: online
825	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Processing url: https://uptobox.com/qqa4dd82m94k
826	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Looking for direct download link...
827	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Direct download link not found
828	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Checking for link errors...
829	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: No errors found
830	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Processing as premium download...
831	13.03.2018 13:05:03	INFO	HOSTER UptoboxCom[15]: Downloading file...
832	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: File saved
833	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: Checking download...
834	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: File is OK
835	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: Checking file (with built-in rules)...
836	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: Checking file (with custom rules)...
837	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: Checking for link errors...
838	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: No errors found
839	13.03.2018 13:05:04	INFO	HOSTER UptoboxCom[15]: No errors found
840	13.03.2018 13:05:04	INFO	Download finished: calcul EFFECTIF vierge modele22.xlsm
841	13.03.2018 13:05:04	INFO	Package finished: Fire-pyLoad
a première vue ton pyload utilise le mauvais plugin de DL; j'ai essayer 3 fois et j'ai toujours le même résultat; peut être un problème plus profond. Dsl de pas pouvoir t'aider vue que j'arrive pas a reproduire ton problème.
desinstallé et reinstallé voici le 1 er package
56 13.03.2018 15:18:27 INFO Download starts: https://uptobox.com/qqa4dd82m94k
57 13.03.2018 15:18:27 WARNING HOSTER UptoboxCom[1]: Plugin may be unstable
58 13.03.2018 15:18:27 INFO HOSTER UptoboxCom[1]: Grabbing link info...
59 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Link name: calcul EFFECTIF vierge modele22.xlsm
60 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Link size: 73.51 KiB (75274 bytes)
61 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Link status: en ligne
62 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Processing url: https://uptobox.com/qqa4dd82m94k
63 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Looking for direct download link...
64 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Direct download link not found
65 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Checking for link errors...
66 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: No errors found
67 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Processing as free download...
68 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Downloading file...
69 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: File saved
70 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Checking download...
71 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: File is OK
72 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Checking file (with built-in rules)...
73 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Checking file (with custom rules)...
74 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: Checking for link errors...
75 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: No errors found
76 13.03.2018 15:18:28 INFO HOSTER UptoboxCom[1]: No errors found
77 13.03.2018 15:18:28 INFO Download finished: calcul EFFECTIF vierge modele22.xlsm
78 13.03.2018 15:18:28 INFO Package finished: test1
79 13.03.2018 15:18:28 INFO ADDON ExtractArchive: Check package: test1
LA tout est ok
voici le 2 eme log avec le meme lien mais en test 2
195 13.03.2018 15:24:04 INFO Download starts: qqa4dd82m94k
196 13.03.2018 15:24:04 WARNING HOSTER XFileSharing[2]: UptoboxCom | Plugin may be unstable
197 13.03.2018 15:24:04 INFO ACCOUNT UptoboxCom: Grabbing account info for user `vin*******`...
198 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Grabbing link info...
199 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Link name: qqa4dd82m94k
200 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Link size: N/D
201 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Link status: demarrage
202 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Processing url: https://uptobox.com/qqa4dd82m94k
203 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Looking for direct download link...
204 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Direct download link detected
205 13.03.2018 15:24:04 INFO HOSTER XFileSharing[2]: UptoboxCom | Downloading file...
206 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | File saved
207 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | Checking download...
208 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | File is OK
209 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | Checking file (with built-in rules)...
210 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | Checking file (with custom rules)...
211 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | Checking for link errors...
212 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | No errors found
213 13.03.2018 15:24:05 INFO HOSTER XFileSharing[2]: UptoboxCom | No errors found
214 13.03.2018 15:24:05 INFO Download finished: qqa4dd82m94k
215 13.03.2018 15:24:05 INFO Package finished: test 2
216 13.03.2018 15:24:05 INFO ADDON ExtractArchive: Check package: test 2
la ça bloque..
Celena-007 a dit:
merci quand même mais du coup je vois pas d ou peut provenir le problème surtout qu'avant (il ya qqs jours) cela fonctionnait bien
fugitif a dit:
j'ai écrit sur Gitub et voici la réponse:
Disable XFileSharing plugin
Comment faire?
Avec la nouvelle Interface sa donne ca : Screenshot-2018-3-14 Config - pyLoad Webinterface(1).png
et tu passe Activated sur Off
Mais c'est vraiment étrange car j'ai réessayer sa marche a tout les coup chez moi ...
j'ai pas du tout la même interface que toi (au niveau graphisme).
Je vois où c'est je teste ce soir merci
QoolBox a dit:
Source : https://pyload.github.io
Download :
[Actual Version ]
https://qnapclub.eu/fr/qpkg/189
Note :
user : qnap
pass : qnap
for automatic update from Git install first CACert QPKG
this version is an embedded version 4.10 Ready (actual Master Branch), this is version is from Stable Github Branch
added : unrar 5.3.2, Zip60,
all optional plugins available
About :
pyLoad is a fast, lightweight and full featured download manager for many One-Click-Hoster, container formats like DLC, video sites or just plain http/ftp links. It aims for low hardware requirements and platform independence to be runnable on all kind of systems (desktop pc, netbook, NAS, router).
Despite its strict restriction it is packed full of features just like webinterface, captcha recognition, unrar and much more.
Un grand merci à toi !!
