Qnap [ Domoticz ] [ 2022.2.14606 ] lightweight Home Automation System
I've tried to install the domoticz on a Container, but the error is still the same. I really need this QPKG.
Is there any way that can i help you Qoolbox?
released the 3.6390.1 (removed previous due some bug report)
fixed issue where symlink overwrite the executable on first install ( for unknown obvious reason on some system )
added the arm-x41 version
Hello Qoolbox,
When i try to do the update of 3.690.1 to the latest version (3.6441),i've got this message in the log, and the update is not done:
2017-01-23 13:56:07.591 Starting Upgrade progress...
2017-01-23 13:56:07.591 Starting: /share/CE_CACHEDEV1_DATA/.qpkg/domoticz/scripts/download_update.sh /share/CE_CACHEDEV1_DATA/.qpkg/domoticz/ /beta
2017-01-23 13:56:11.130 Executing script: /share/CE_CACHEDEV1_DATA/.qpkg/domoticz/scripts/update_domoticz
2017-01-23 13:56:26.291 Error: Error executing script command (/share/CE_CACHEDEV1_DATA/.qpkg/domoticz/scripts/update_domoticz /share/CE_CACHEDEV1_DATA/.qpkg/domoticz/). returned: 32512
Do you know why the update is not done?
Thanks!
SegundaChande a dit:
Hello Qoolbox! How can i compile it? Can i compile it from SSH? Or upgrade it from SSH?
no you cant... i compile 6390 from git
but idont want to compile it everyday.. everyday there is a new version... is the version you saw is an official stable ?
No, it's not an stable version, but there are many develops on domoticz, to the sensors that i've got and i would like to update any time i want.
Can you teach me how can i compile the code from GIT repo, and create the QPKG? If so, i can create my QPKG from my own, and not boring you...
Salut tout le monde, QoolBox
Bon, j'ai installé la version http://www.positiv-it.fr/QNAP/APP/domoticz_3.5985_x86_64.qpkg.zip
J'ai voulu me connecter dessus http://mon_nas:8885 (j'ai essayé d'autre port aussi ... sans succès)
je suis allé dans "shellinabox", dans le répertoire /opt/domoticz, puis j'ai tapé la commande ./domoticz
le résultat est : ./domoticz: error while loading shared libraries: libusb-0.1.so.4: wrong ELF class: ELFCLASS32
Qu'est-ce qui se passe ?
Salut QoolBox,
Je suis désolé mais je ne comprends pas, aucune des versions disponible ne fonctionne avec la 4.2.3 ?
Dans le cas contraire, laquelle dois-je télécharger pour que cela fonctionne :
A - http://www.positiv-it.fr/QNAP/APP/Qdomoticz_2.4663_x86_64.qpkg.zip
B - http://www.positiv-it.fr/QNAP/APP/domoticz_3.4834_x86_64.qpkg.zip
C - http://www.positiv-it.fr/QNAP/APP/domoticz_3.5841_x86_64.qpkg.zip
D - http://www.positiv-it.fr/QNAP/APP/domoticz_3.5985_x86_64.qpkg.zip
E - x64 version http://www.positiv-it.fr/QNAP/APP/domoticz_3.6390.1_x86_64.qpkg.zip
F - x41 version http://www.positiv-it.fr/QNAP/APP/domoticz_3.6390.1_arm-x41.qpkg.zip
G - x64 version http://www.positiv-it.fr/QNAP/APP/domoticz_3.6635.0_x86_64.qpkg.zip
H - x41 version http://www.positiv-it.fr/QNAP/APP/domoticz_3.6635.0_arm-x41.qpkg.zip
Merci pour ton aide :)
